A subtle bug in a core JavaScript big‑number library has turned into a practical availability risk for Node.js applications: calling maskn(0) on a BN instance in versions of bn.js older than 5.2.3 can corrupt the object’s internal state and send commonly used methods such as toString() and divmod() into an infinite loop, hanging the host process indefinitely. This behavior was assigned CVE‑2026‑2739 and fixed in bn.js v5.2.3; operators and developers should treat it as a denial‑of‑service (DoS) risk and act quickly to remediate vulnerable deployments.
Neon cyber key with coded digits, an infinity loop, and a CVE-2026-2739 warning symbol.Background / Overview​
bn.js is a pure‑JavaScript implementation of arbitrary‑precision integers (a BigNum library) commonly used in cryptographic and blockchain code, as well as other packages that need reliable large‑integer math in JavaScript. It is widely distributed through npm and appears as a dependency—direct or transitive—across numerous libraries and SDKs in the Node.js ecosystem. According to npm metadata, bn.js continues to have tens of millions of weekly downloads across published versions, underscoring how broadly a defect in this package can propagate.
The newly cataloged CVE‑2026‑2739 describes a logic bug where invoking maskn(0) (or the in‑place variant imaskn(0) depending on call paths and code paths) results in a corrupted internal word/length representation inside the BN instance. Once corrupted, otherwise innocuous operations—formatting (toString), arithmetic helpers (divmod), and other common APIs—can enter an infinite loop because an internal exit condition is broken. That loop is not a bounded CPU spike but a hang: the Node.js process typically becomes unresponsive until the process is terminated or the container or scheduler kills it.
This is not a memory leak or remote code execution; it is availability damage. However, availability incidents are high‑impact in production: a single targeted call that reaches vulnerable code can stop a worker or server process, degrade throughput, or trigger cascading failures in a multi‑process architecture. The CVSS assessments published with the advisory place this at Medium severity (CVSS 3.1 ~5.3), reflecting the limited confidentiality/integrity risk but clear availability impact and the relatively low complexity for an attacker to trigger the condition if they can influence application inputs.
How the bug works (technical analysis)​
What maskn(n) is supposed to do​
At a conceptual level, maskn(k) and imaskn(k) are bit‑masking helpers: they keep only the lowest k bits of a big integer and either return a new BN (maskn) or update the BN instance in place (imaskn). These operations are normalizing: when k is 0, the intended result is the numeric value 0. The implementation manipulates the BN’s internal word array and a length field that indicates how many words are in use. If the word array and length are left inconsistent, later loops that iterate using length as the stop condition can become unbounded. (github.com)
The actual failure mode​
According to the upstream fix and the advisory details, calling maskn(0) (or triggering the imaskn code path) can leave the BN instance with an invalid length (for example, length set to zero but with words left in a shape that causes internal loops to run past the intended end), or otherwise fail to normalize the internal structure. Subsequent calls to toString(), divmod(), and other functions that iterate over the BN’s words rely on consistent invariants. With those invariants violated, the loops' exit condition becomes unreachable and execution never finishes. The project’s maintainers added a small but definitive guard in the code to ensure that when the masked length becomes zero the BN’s words and length are reset to the canonical zero representation—this is what ships in 5.2.3. (github.com)
Evidence in the upstream patch​
The upstream commit that closed the issue is explicit: the commit message “fix imaskn state (#317)” shows a compact code change that sets words[0] = 0 and length = 1 when the in‑place mask operation produces a zero length, followed by the existing strip/normalization logic. The patch also adds unit tests asserting that new BN(42).imaskn(0).toString() === '0' (and similar checks), which both document the intended behavior and ensure the bug does not reappear. Review of the commit and associated release tag confirms the fix was merged and released as v5.2.3. (github.com)
Scope and impact: where this matters​
Who is affected​
  • Any Node.js application that directly imports a vulnerable bn.js version (< 5.2.3) and calls maskn(0) (or that uses a library that calls that path).
  • Transitive dependents that include bn.js in their dependency graph—this is common in cryptography and blockchain stacks (elliptic, web3 toolchains, Ethereum SDKs, and other libraries) where big‑number arithmetic is routine. Examples of SDKs and packages in the wider ecosystem list bn.js among their dependencies, which makes transitive risk real in many ecosystems.
Attack surface and exploitation conditions​
  • Trigger complexity: Low–medium. The attacker needs the ability to provide or control an input that reaches code that eventually calls maskn with an argument of 0. In many projects, BN instances are created and manipulated based on external or user‑supplied values (addresses, integer fields, parsed binary data, cryptographic primitives). If application logic allows untrusted values to reach bn.js masking routines, a remote actor could induce the hang without authentication. Several advisory aggregators classify the attack vector as network (remote) and complexity as low.
  • Exploits in the wild: At the time of disclosure there were no widely reported, weaponized exploits in public threat feeds, and EPSS/KEV inclusion was not indicated. That does not reduce operational urgency: a DoS trigger in a high‑value service is a practical, low‑cost attack in many threat scenarios.
Realistic impact examples​
  • A web server that parses user‑provided numeric data and uses BN arithmetic in its handler could be taken down by a single malicious request that causes a worker process to hang, forcing the service to shed capacity or restart.
  • Long‑running background workers performing crypto operations on untrusted inputs could have their job queues held up indefinitely, creating backpressure.
  • Containerized microservices without CPU isolation or watchdogs may remain hung until manual intervention or until orchestrator liveness checks detect failure—if those checks are not configured to kill hung CPU‑bound tasks, service degradation may be prolonged.
Mitigation and remediation (practical steps)​
Immediate remediation is straightforward: upgrade bn.js to version 5.2.3 or newer. The upstream release contains the explicit fix described above. For many teams this single action removes the vulnerability from the dependency tree. (github.com)
Recommended steps for maintainers and operators:
  • Upgrade bn.js
  • For direct users: run your package manager to bump the version constraint to >= 5.2.3 and update lockfiles (npm, pnpm, yarn). For example, in npm: update package.json to allow 5.2.3+ and run an install to refresh package‑lock.json.
  • For transitive users: if bn.js is a transitive dependency, run an audit and a dependency resolution (npm update / yarn upgrade / pnpm update or use resolution/overrides fields) to ensure the tree includes 5.2.3. If a critical dependency pins an older bn.js, open a pull request to bump it or coordinate upstream with the maintainer to get a fix published. (github.com)
  • Rebuild and redeploy
  • After upgrading, rebuild any artifacts and images, restart processes, and confirm that the updated package is actually in the runtime image. Do not rely solely on package.json; validate the installed tree in the production artifact (node_modules or built bundle) as CI or build caches can sometimes retain older code.
  • Scan and audit
  • Run dependency scanners (npm audit, Snyk, OSS‑Vuln scanners, OSV, and your CI SCA) to locate every occurrence of bn.js in your supply chain. Treat each direct and transitive occurrence as a remediation target. Several public advisories and vulnerability databases have already ingested CVE‑2026‑2739, so automated tools should flag it if they’re up to date.
  • Harden runtimes and add detection
  • Configure process supervisors, orchestrator liveness probes, and CPU/time limits so that single worker hangs do not cascade into full service outages. For example, set appropriate liveness/readiness probes in container orchestrators and ensure that CPU throttling or watchdog restarts are in place for CPU‑bound infinite loops.
  • Consider runtime instrumentation to alert when a process becomes unresponsive without a growth in memory (command failure patterns for hung CPU loops differ from classic out‑of‑memory crashes).
  • Temporary workarounds where upgrade isn’t immediately possible
  • If an immediate upgrade is impossible (blocked by vendor constraints, distro packaging, etc.), apply mitigations such as strict input validation to prevent untrusted code paths from reaching maskn(0), or isolate services that use bn.js behind additional layers that validate or canonicalize numeric inputs.
  • Use dependency pinning or package‑manager overrides to force a rebuild that uses the patched version in confined builds. These are stopgaps and must be followed by a proper upgrade cycle as soon as feasible.
  • Coordinate with downstream vendors and distributions
  • If you rely on vendor‑built artifacts (OS distributions, packaged runtimes, SDKs), check vendor advisories and distro CVE trackers. Some distributions publish their own advisories and may already have backports; coordinate to obtain patched packages if available. Several vendor advisories and vulnerability aggregators list CVE‑2026‑2739 with recommended fixes.
Why this bug matters beyond the immediate fix: a critical supply‑chain lens​
bn.js sits in the critical path of many cryptographic and blockchain libraries. While this bug is not an authentication bypass or code‑execution vulnerability, its presence in transitively used packages amplifies the supply‑chain impact:
  • Cryptography and blockchain stacks often process untrusted inputs (raw transactions, user‑supplied numbers, or peer data) in server‑side code paths. That makes even a small API misuse a viable attack vector.
  • Large JavaScript projects frequently bundle dependencies into single artifacts for the browser or serverless runtimes. An old bn.js can creep into bundles and remain unnoticed until runtime—static package.json checks are helpful but not sufficient without verifying the final artifact.
  • Many organizations run dozens or hundreds of microservices. A single transitive vulnerable library can be present across dozens of distinct runtime images. Remediation thus requires inventory and coordinated rollout, not a single patch.
Security practitioners should therefore treat this as a canonical example of how a correctness bug in a low‑level utility can translate into real‑world availability damage across a supply chain of dependent software. Multiple vulnerability databases have already cataloged CVE‑2026‑2739 and recommended the upgrade to 5.2.3 as the primary corrective action.
Tests, forensics, and verification​
After you apply the upgrade, verify:
  • The runtime is using bn.js v5.2.3 (or later). Check your built artifact, node_modules, or the lockfile in the deployed image to make sure the patched code is present.
  • Run unit or integration tests that exercise BN functionality: create BN instances and call imaskn(0)/maskn(0) and then toString() and divmod() to confirm no hang occurs. Upstream added a small test asserting imaskn(0) yields '0'—mirroring that in your test suite is a valuable check. (github.com)
  • For production incidents where hangs occurred, gather process diagnostics (stack traces, CPU profiles, core dumps if permitted) to confirm that the call chain involved BN methods. This will help differentiate bn.js hangs from other causes of unresponsiveness.
If you need to demonstrate a proof‑of‑concept to triage, bear in mind that public PoC snippets were cited in advisories and vulnerability trackers; treat PoCs as potentially dangerous and follow responsible disclosure/handling policies. Several vulnerability trackers and advisories reference a gist that documents the condition; upstream addressed the code path rather than removing functionality.
Vendor and ecosystem response​
  • Upstream maintenance: The bn.js maintainer(s) merged a focused fix and shipped v5.2.3, adding unit tests to prevent regression. The commit and release show a minimal, surgical change to preserve intended behavior. (github.com)
  • Advisory aggregation: Several public vulnerability databases and vendor advisories have ingested the CVE and assigned a medium rating; entries include NVD, GitLab/GitHub advisory mirrors, Vulners, OSV/OpenCVE and other trackers. These sources converge on the same remediation: upgrade to 5.2.3.
  • Distribution: Linux distributions and package managers may publish their own packaging updates or backports; consult your distro CVE tracker or vendor advisory for a distro‑packaged fix if you consume bn.js via repository packages rather than npm. OpenCVE and other aggregators list references to the GitHub patch and to Snyk entries for further context.
Critical assessment: strengths of the response and remaining risks​
What the ecosystem got right
  • The fix was small, well‑scoped, and covered by unit tests—this reduces the chance of regressions while restoring the intended semantics. The upstream commit both corrected the state normalization and added tests to assert correct behavior for imaskn(0). (github.com)
  • Multiple vulnerability databases synchronized quickly to publish advisories and guidance, and the canonical fix was clearly identified (v5.2.3), making automated detection easier for downstream users and scanners.
Residual or broader risks to watch
  • Transitive exposure remains the dominant operational risk. Even though an upstream fix shipped, many build artifacts, containers, serverless bundles, or vendor SDKs may still contain the vulnerable code until each maintainer updates and redeploys. That potentially leaves production systems exposed for weeks or months depending on release cadence and operational practices.
  • Detection vs exploitation: a lack of public exploit reports should not lull teams into complacency. The attack vector is straightforward where untrusted numeric input reaches BN code paths, and availability attacks are low‑cost for adversaries compared with more complex integrity or confidentiality exploits.
  • Operational mitigations (process timeouts, watchdogs, CPU constraints) can reduce blast radius but are not a substitute for patching. A hardened runtime posture helps absorb incidents, but the root cause remains in the code if not upgraded.
Checklist — what to do now (quick reference)​
  • Developers:
  • Upgrade bn.js to >= 5.2.3 in your package.json and lockfile, rebuild artifacts, and run tests. (github.com)
  • If you consume prebuilt vendor SDKs, check vendor advisories and request patched releases if necessary.
  • Security teams / SREs:
  • Inventory all services and images to find bn.js occurrences (direct and transitive).
  • Prioritize high‑exposure services (internet‑facing servers, payment/crypto processing, identity services).
  • Deploy patched builds and cycle workers; validate that the updated artifact contains bn.js v5.2.3+.
  • Configure liveness probes and CPU watchdogs to limit the impact of any remaining unpatched processes.
  • Package maintainers:
  • Bump dependencies and publish patched releases rapidly if your package depends on bn.js and you cannot immediately upgrade downstreams.
  • Add tests exercising the masking API if you provide BN wrappers, ensuring your library does not surface the vulnerable call pattern.
Final thoughts — lessons for dependency hygiene​
CVE‑2026‑2739 is a reminder that correctness bugs in tiny, low‑level utilities can have outsized operational consequences when those utilities are widely reused. The fix here was non‑controversial and small, but the real operational work is in chasing transitive copies of old code out of build artifacts and production images.
Recommendations going forward:
  • Treat correctness issues in mathematical or parsing libraries as high‑impact risks—availability and resource exhaustion attacks are simple and effective.
  • Maintain an up‑to‑date dependency inventory (SBOMs) and check final artifacts, not just manifest files.
  • Integrate dependency scanning into CI/CD and automate enforcement of minimal acceptable versions for critical third‑party components.
  • Combine fast patching with runtime mitigations (watchdogs, probes, CPU quotas) so that single defects do not take down entire services.
If you run Node.js in production, verify your bn.js versions now and make patching a priority—this is a fast, testable remediation that removes a straightforward DoS vector across the ecosystem. (github.com)
Conclusion: CVE‑2026‑2739 is fixable and has been fixed upstream; the operational effort lies in sweeping your dependency graph, rebuilding artifacts, and ensuring runtime guards are in place so a single corrupt BN instance cannot stop your service. (github.com)
