When critical infrastructure depends on the seamless operation of digital devices, security vulnerabilities in foundational industrial products can have far-reaching effects across sectors and national borders. Recent advisories concerning the Siemens SIPROTEC and SICAM product families have again thrust cybersecurity for industrial control systems (ICS) into the spotlight. This in-depth analysis explores a high-severity flaw—tracked as CVE-2024-3596—in core Siemens devices, examining the technical underpinnings of the vulnerability, affected products, risk implications, enacted mitigations, and the broader impact on ICS security landscapes.
High-tech network equipment with a holographic shield icon symbolizes advanced cybersecurity protection.
Siemens SIPROTEC and SICAM: Nerves of Modern Power Networks​
SIPROTEC and SICAM are well-established within the energy sector and critical manufacturing environments. SIPROTEC, for instance, is widely recognized for its digital protection relays and automation solutions in substations, providing the intelligence required to monitor, control, and protect grids from faults and failures. SICAM complements with scalable energy automation solutions that range from substation automation to metering and grid management.
These products aren’t fringe components; they are deeply embedded in the nervous systems of power transmission, distribution, and critical industrial facilities worldwide—making them lucrative targets for adversaries seeking footholds in critical infrastructure environments.
Anatomy of the Vulnerability: CVE-2024-3596​
Technical Details: RADIUS and Message Integrity​
CVE-2024-3596 exposes a significant weakness in how affected Siemens products enforce message integrity during communications mediated by the Remote Authentication Dial-In User Service (RADIUS) protocol, as specified in RFC 2865.
The vulnerability arises due to improper handling of the MD5 Response Authenticator signature—integral to authenticating communication between the device (the client) and network access servers over RADIUS. Attackers who can intercept or inject RADIUS traffic can exploit weaknesses in the MD5 signature via a chosen-prefix collision. This essentially allows them to forge messages—most critically, the Access-Reject or Access-Accept responses—by exploiting the known cryptographic weaknesses of the MD5 hash function.
Key risk: An attacker, without legitimate credentials, may exploit this flaw to trick a vulnerable network access device into granting unauthorized network access—with whatever privileges the attacker desires.
Severity: Scoring the Threat​
This flaw has been evaluated with a CVSS v3.1 base score of 9.0 and a CVSS v4.0 base score of 9.1, both of which categorize it as a critical vulnerability. The primary drivers for this high score include the complexity (regarded as low for this vector), the potential for remote exploitation, and the significant impact on confidentiality, integrity, and availability if successfully exploited.
Vector highlights:
  • Attack Vector: Network (Remote)
  • Attack Complexity: Low
  • Privileges Required: None
  • User Interaction: None
  • Impact: High—potential for privilege escalation and unauthorized network access.
Who Is at Risk? Products in the Crosshairs​
The extent of exposure arises from the broad deployment footprint of affected products in critical infrastructure. According to Siemens advisories and corroborated by CISA, the following Siemens product families—when configured to use the RADIUS protocol—are vulnerable:
SIPROTEC 5​
Ranging from compact relays (7SX800) to advanced central processing modules (CP050/CP100/CP150/CP300), a vast number of SIPROTEC 5 device models and firmware versions are listed as impacted. This includes various models within 7SA, 7SD, 7SJ, 7SK, 7SL, 7SX, 7SY, 7UT, 6MD, 6MU, 7KE, 7SS, 7ST, 7UM, 7VE, 7VK, and 7VU product series.
SICAM Portfolio​
  • CPC80/CPCI85 Central Processing/Communication modules (all versions)
  • SICAM Q100 (prior to v2.70)
  • SICAM Q200 (all versions)
  • Powerlink IP (all versions)
  • SICAM GridPass (prior to v2.50)
  • SICORE Base System (all versions)
Additional Impact​
Given that these devices are deployed in substations, power plants, manufacturing plants, and as central nodes in the grid, an exploitation could ripple through essential energy delivery systems, potentially allowing attackers to bypass network access controls or even influence automated operations within protected environments.
Repeat deployments across different regions mean that this is a global issue, and not just localized to Siemens’ home market or select customers.
The Heart of the Exploit: Why MD5 Still Matters​
A significant portion of industrial product communications protocols were designed decades ago, in eras when cryptographic limitations and threats were less understood. MD5 was once the default cryptographic hash, but has been deprecated for security use since its vulnerabilities (particularly collision-based attacks) became well-publicized more than 15 years ago. Despite this, legacy support for MD5 lingers, especially in compatibility modes or as a default in certain ICS protocols—driven by the slow lifecycle of industrial asset upgrades.
The RADIUS protocol’s calculated Response Authenticator is meant to prevent replay or message forgery attacks, binding the integrity of the communication. However, a chosen-prefix collision attack—a technique with steadily reducing computational cost due to both algorithmic and hardware advances—permits a determined adversary to craft two RADIUS messages with different content but the same MD5 signature.
Practicality of the Attack​
While such attacks were once computationally prohibitive, advancements in hash collision techniques (as demonstrated in real-world MD5 exploitation and collision-finding tools) have made them achievable even for moderately resourced attackers. In the context of a power grid or industrial environment, a threat actor with proximity to the network (or via a compromised insider device) could inject maliciously crafted RADIUS packets to bypass authentication entirely.
Notably, the attack does not require knowledge of legitimate credentials—raising the risk for environments where RADIUS is a gatekeeper for privileged operations.
What Siemens and CISA Recommend: Mitigations and Best Practices​
Recognizing the gravity of the flaw, Siemens has responded with a two-pronged approach: issuing patched firmware for some products and workarounds for others while referencing universal security hygiene.
Vendor Patches and Updates​
Siemens recommends immediate updates where new firmware is available:
  • SICAM Q100: Update to v2.70 or later
  • SICAM GridPass: Update to v2.50 or later
  • SIPROTEC 5 6MD89 (CP300): Update to v9.68 or later
  • SIPROTEC 5 7ST85/7ST86 (CP300): Update to v9.68/v9.83 or later
The full details are provided in the official SSA-794185 Siemens advisory, bolstered by step-by-step upgrade guidance for IT staff responsible for power networks.
Workarounds and Network-Level Defenses​
For devices where immediate patching is not yet available, Siemens and CISA advise:
  • Limit RADIUS network exposure: Route RADIUS traffic through isolated, secured management networks or VLANs to limit opportunities for message interception or injection by unauthorized parties.
  • Leverage enhanced RADIUS security features: Configure RADIUS servers to mandate the Message-Authenticator attribute in all Access-Request packets. This additional layer complicates forgery attempts, even if MD5 weaknesses persist.
  • General network security posture: Implement strict network segmentation, firewalling, and monitoring in accordance with Siemens’ operational security guidelines and established best practices in ICS network security.
CISA’s Defensive Guidance​
CISA adds emphasis on a defense-in-depth strategy:
  • Conduct detailed risk assessments and impact analyses before introducing any changes.
  • Continually monitor for abnormal RADIUS or network activity indicative of tampering or exploitation attempts.
  • Consult technical guides for targeted intrusion detection and ICS-specific cybersecurity best practices.
How Real Is the Threat? Analysis and Context​
As of the latest advisories’ release, no known public exploitation attempts have been reported against this specific vulnerability. However, the theoretical and technical feasibility has been established—a growing pattern in ICS vulnerabilities where public proof-of-concept often lags initial disclosure by months, creating a dangerous window of opportunity.
Key concerns:
  • Criticality bias: Because of the vital nature of SIPROTEC/SICAM deployments, even a single successful attack could disrupt grid operations or enable broader lateral movement within operational networks.
  • Visibility gap: Attacks against authentication infrastructure are often stealthy and may remain undetected for long periods, particularly in environments lacking modern network monitoring or anomaly detection.
  • Patch cadence: Industrial environments frequently experience delayed upgrade cycles due to the necessity of rigorous validation, compliance requirements, and the risk of service interruption.
In summary: Given the flaw’s nature—simple exploitation and high impact—the window between public awareness and widespread patch adoption is a critical risk period for asset owners.
The Broader Picture: What This Reveals About ICS Security​
This vulnerability, while notable on its own merits, also highlights systemic challenges in ICS and operational technology (OT) security:
1. Legacy Technology Drag​
Many industrial environments still operate with legacy technology stacks, including protocols relying on deprecated cryptographic primitives like MD5. The slow pace of migration—rooted in the need for stability, certification, and long-term vendor support—creates enduring risk pockets.
2. Protocol-Level Security Gaps​
Industrial protocols often predate modern security practices. Even where patching is possible, underlying protocol weaknesses (example: lack of strong message integrity and authentication) persist. While Siemens and others introduce mitigations like required Message-Authenticator attributes, the ecosystem remains vulnerable until stronger cryptographic standards and protocol upgrades (such as RADIUS with SHA-2 support) become the norm.
3. Network Segmentation and Hygiene Are Non-Negotiable​
Best practices around network isolation, restricted access, and authentication hardening are consistently recommended—but real-world audits continue to reveal widespread flats networks, legacy system access, and insufficient monitoring in operational environments.
4. Vendor-Driven Security Response​
Siemens has acted promptly—reporting the flaw to CISA, documenting fixes for multiple products, and issuing alternative mitigations. However, the diversity and legacy depth of the affected product lines mean organizations cannot rely solely on vendor patches; proactive, defense-in-depth design must underpin industrial cybersecurity strategies.
Critical Analysis: Strengths, Gaps, and Future Risk​
Siemens Response: Transparent, But Not Complete​
Siemens has demonstrated a responsible disclosure process and provided timely updates and mitigations. Their advisories are detailed, offering concrete steps rather than vague guidance. This sets a strong example for ICS vendors.
However, not all affected models have immediate fixes, and some workarounds—while effective—may be challenging to implement in environments with rigid change management policies or limited network segmentation capabilities.
Systemic Weaknesses in ICS Protocols​
The persistence of vulnerabilities rooted in now-obsolete cryptographic algorithms (MD5, in this case) is concerning. Long-term, ICS product development roadmaps must prioritize stronger default cryptography—not only in firmware updates, but in protocol-level standards and industry-wide best practices.
Mitigation Complexity​
Recommendations such as restricting RADIUS to management networks or requiring the Message-Authenticator attribute are industry standard—but their success is contingent on the security maturity of the asset owner. ICS environments vary widely in their ability to implement such changes without risking business continuity.
Organizations with mature ICS security programs will already have these controls in place; those without may face significant lift in rapid compliance.
Potential for Unseen Exploitation​
The absence of known exploitation should not breed complacency. The criticality of the affected environments and the simplicity of the attack technique, once properly weaponized, make this a vulnerability with potentially long-term risk if left unmitigated.
Regulatory and Audit Implications​
With international regulatory focus on critical infrastructure security (e.g., NERC CIP in North America, EU NIS), asset owners must demonstrate a rapid, comprehensive response to advisories such as this. Audit trails, documentation of mitigation steps, and ongoing monitoring will be under scrutiny in the aftermath of such disclosures.
Recommendations for Asset Owners and Security Leaders​
  • Inventory and Assess: Immediately determine if affected Siemens SIPROTEC and SICAM products using RADIUS are deployed in your environment.
  • Apply Patches Where Available: Prioritize updates to patched versions in line with operational risk tolerance.
  • Implement Workarounds Where Necessary: Where updates are not possible, employ Siemens- and CISA-recommended mitigations as interim controls.
  • Review and Harden Network Segmentation: Isolate management and control-plane traffic—including RADIUS—from broader enterprise or production environments.
  • Monitor for Anomalous RADIUS Activity: Leverage network monitoring solutions to detect unusual authentication traffic or failed login patterns indicative of exploitation attempts.
  • Engage With Vendors and Integrators: Ensure ongoing communications with Siemens and product integrators to receive timely updates on patch availability and further advice.
  • Participate in Industry Information Sharing: Share findings and incidents with ISACs (Information Sharing and Analysis Centers) and CISA to support collective defense.
The Path Forward: Building ICS Security Resilience​
The disclosure and handling of CVE-2024-3596 may be seen as a case study in the ongoing tension between operational resilience and cybersecurity in the industrial realm. With adversaries increasingly targeting the authentication and access control layers of critical infrastructure, the industry must respond not just by patching individual flaws, but by modernizing its approach:
  • Push for default-strong cryptography in all industrial protocols.
  • Regularly audit all networked assets—especially those that still rely on cryptographic primitives known to be broken or weak.
  • Institutionalize rapid patching processes, even in change-averse environments, for vulnerabilities with clear, high-impact exploitability.
  • Adopt a “zero trust” operational mindset, assuming compromise is possible and designing defenses accordingly.
As of the latest advisory, there is no evidence of this vulnerability being actively exploited, but the risk is clear and present. Siemens’ SIPROTEC and SICAM are trusted foundations in the digital power grid and industrial automation. All stakeholders—vendors, utilities, plant operators, and security professionals—must treat this as a wake-up call, not just to remediate a single flaw, but to accelerate a holistic modernization of ICS security practices. This is not only a matter of cyber hygiene—it is essential to the reliable delivery of power, water, and manufacturing services upon which modern society depends.
As the industrial threat landscape continues to evolve, proactive vigilance, rapid response, and a willingness to confront embedded systemic risks are the only sustainable paths to resilience.
Source: CISA Siemens SIPROTEC and SICAM | CISA
