Cloud security graphic featuring Linux penguin, Bluetooth symbol, and CVE-2025-38303.
Microsoft’s brief advisory on CVE-2025-38303 confirms that Microsoft’s Azure Linux images include the upstream Linux Bluetooth code that was patched for the eir_create_adv_data crash, and Microsoft says it will update the CVE/VEX/CSAF product mapping if additional Microsoft products are later found to include the same upstream component.
Background / Overview​
CVE-2025-38303 is a Linux-kernel bug fixed upstream in July 2025 that affects the Bluetooth EIR (Extended Inquiry Response) advertising data path: the function eir_create_adv_data could attempt to add EIR_FLAGS and EIR_TX_POWER entries into an advertising buffer without checking whether they would fit, which can lead to a kernel oops (crash) under certain input conditions. The patch was merged into the stable kernel trees and distributed by downstream maintainers as part of normal stable-kernel updates. Independent distribution trackers and vendor advisories (Debian, Ubuntu, and others) list the fix and the package/kernel versions that include it, confirming that the vulnerability is an upstream Linux kernel defect and is addressed by updating kernels to the released fixed versions. Microsoft’s public wording makes two precise claims: (1) Microsoft has inspected the Azure Linux product family and found the implicated open-source code in that product’s artifacts, and (2) Microsoft will update the CVE record (and its machine-readable VEX/CSAF attestations) if additional Microsoft products are identified that include the same upstream component. That phrasing is a product‑scoped attestation — authoritative for Azure Linux as published, and procedural about further product mappings.
What the Linux-side technical record shows​
The bug and the upstream fix​
  • The defect lives in net/bluetooth/eir.c and related helper headers where EIR advertising fields are composed.
  • The problematic behavior: eir_create_adv_data could append both EIR_FLAGS and EIR_TX_POWER entries without verifying remaining buffer space, allowing malformed or unexpected input sizes to overrun logical buffer boundaries and trigger kernel-level crashes or warnings.
  • Upstream commit notes and the kernel CVE announcement provide the exact commits that resolve the condition and recommend upgrading to the latest stable kernel releases where the fixes were merged.
Distribution coverage and remediation status​
Major distributions and kernel maintainers incorporated the fix into their stable releases. Debian’s tracker shows fixed and vulnerable package states across releases, and Ubuntu’s security advisory lists the publication and status for its kernels. Cloud vendor trackers (Amazon Linux, Ubuntu images, etc. also classify severity and map fixed kernel builds. These independent vendor mappings corroborate that the issue is an upstream kernel defect remediated by normal kernel updates.
Interpreting Microsoft’s statement: “Azure Linux includes this open-source library and is therefore potentially affected”​
What Microsoft actually attested​
Microsoft’s advisory language for several upstream Linux CVEs in 2025 has followed the same pattern: Azure Linux (Microsoft’s curated Linux distribution for Azure VM images) is an early product family for which Microsoft has published machine-readable CSAF/VEX attestations starting in October 2025. Where Microsoft finds an implicated upstream component inside Azure Linux builds, it notes that “Azure Linux includes the open-source library and is therefore potentially affected” and commits to update the CVE/VEX record when other Microsoft product families are identified.
Why that wording does not equal “exclusivity”​
  • That sentence is an affirmative inventory result for Azure Linux — it tells you Microsoft has validated presence of the code in that product family and thus has a responsibility to issue remediations and VEX entries for it.
  • It is not a statement that Microsoft’s inventory work scanned every Microsoft product and verified absence elsewhere. Microsoft explicitly promises to update the CVE entry if more Microsoft products are found to ship the same component.
  • Practically, large vendors roll out CSAF/VEX attestations in phases; starting with one product family (Azure Linux) gives customers a deterministic automation signal for that surface while inventory work continues across the remainder of the product catalog.
Is Azure Linux the only Microsoft product that includes the vulnerable library?​
Short answer: No — Azure Linux is the only Microsoft product Microsoft has publicly attested as including the implicated upstream Bluetooth code for CVE-2025-38303 at the time of that advisory, but that does not prove no other Microsoft product contains the same code. Absence of a VEX/CSAF attestation for other Microsoft SKUs equals “not yet attested,” not “not present.”
Why other Microsoft products could still include the code​
  • Any Microsoft product that ships or embeds a Linux kernel build could include the same upstream Bluetooth code if:
  • The kernel version included a commit range prior to the fix.
  • The kernel build configuration enabled the EIR/Bluetooth code paths.
  • The product pipeline used the same upstream or backported kernel code in that artifact.
  • Examples of Microsoft-delivered artifacts that may (in principle) include Linux kernel code:
  • WSL2 kernel (the Windows Subsystem for Linux uses a Microsoft-maintained Linux kernel binary).
  • Marketplace or partner images published in Azure that are curated or repackaged by Microsoft.
  • Specialized Azure node images or management agent artifacts that bundle a kernel image or modules.
  • Any internal or appliance-like images Microsoft builds for specific services.
Practical verification is per-artifact​
Whether an artifact contains the vulnerable code is a per-artifact property (kernel source/commit range and configuration). Therefore, the correct operational approach is to treat Microsoft’s Azure Linux attestation as authoritative for Azure Linux images and to verify other Microsoft-provided artifacts you run by inspecting the artifact, SBOM, kernel version, or vendor VEX/CSAF mapping rather than assuming they are safe purely because they aren’t named in the VEX for Azure Linux.
Technical steps to verify exposure in your environment​
  • Identify the kernel in use:
  • For VMs and bare-metal Linux, run uname -r and inspect your distribution’s packaged kernel.
  • For WSL2, check the shipped WSL kernel version (wsl --status and check the kernel binary).
  • Inspect whether the kernel build includes net/bluetooth/eir.c:
  • If you have kernel source or the distro package, search for net/bluetooth/eir.c and the EIR-related config flags.
  • Map your kernel commit or package version against the upstream fix:
  • Compare your kernel’s version/commit range against the upstream commits that fixed the issue (upstream commit references and stable-tree merges are listed in the kernel CVE announcement).
  • For images (containers, Marketplace appliances, Azure VM images):
  • Obtain an SBOM or run a container/image scan for kernel or kernel-module artifacts.
  • For Marketplace images, confirm whether the image is Microsoft-curated Azure Linux or a third-party image that should be triaged with the vendor.
  • If in doubt, treat the image as “unknown” and prioritize remediation or compensating controls until verification or vendor attestation is available.
Remediation and mitigation guidance​
  • Patch: Upgrade to the vendor-provided fixed kernel packages. Upstream kernel fixes have been merged; distributions provide patched kernel packages — apply those updates as soon as feasible. Debian and Ubuntu advisories list the fixed package versions and recommended updates.
  • Rebuild static artifacts: If your environment contains statically built kernel modules or appliances that bundle an older kernel, rebuild those artifacts with a patched kernel tree and redeploy.
  • Temporary hardening:
  • If Bluetooth functionality is not needed on a host, disable Bluetooth services or blacklist the Bluetooth module until you can apply the kernel update.
  • For multi-tenant or sensitive hosts, reduce the attack surface by restricting untrusted local workloads from interacting with Bluetooth devices.
  • Cloud operators:
  • For Azure VM fleets using Microsoft-maintained Azure Linux images, follow Microsoft’s update guidance and automate remediation using Microsoft’s provided VEX/CSAF signals for those images.
  • For customer-supplied images in Azure Marketplace or custom images, verify vendor advisories for those distributions rather than assuming Microsoft’s Azure Linux attestation applies.
  • Monitor: Look for kernel oopses, Bluetooth service crashes, or sudden restarts of networking/Bluetooth subsystems as indicators of attempted or accidental triggering of the bug.
Risk profile and exploitability​
  • The defect manifests as a robustness/availability issue (kernel crash/oops) when advertising data assembly overflows expected bounds.
  • This is a local or low-privilege kernel robustness issue rather than a remotely wormable RCE: exploitation requires conditions that allow eir_create_adv_data to run on crafted inputs that trigger the improper buffer accounting. Distribution and cloud advisories classify the impact as medium for availability and recommend patching; EPSS/real-world exploit reports for this CVE are low at publication.
  • In cloud environments, the principal operational concern is availability and potential disruption to networking/Bluetooth-enabled services for a host or VM that uses the vulnerable kernel. In multi-tenant or containerized environments, local vectors (container escapes, unprivileged processes able to interface with Bluetooth subsystems) increase blast radius; defensively, isolate Bluetooth access to trusted workloads.
How to treat Microsoft’s product attestation in practice​
  • For customers running Azure Linux images: treat Microsoft’s VEX/CSAF attestation as the authoritative signal for those images and apply Microsoft’s updates promptly. Microsoft’s published VEX for Azure Linux is intentionally machine-readable to support automation and triage.
  • For customers running other Microsoft artifacts (WSL2 kernels, Marketplace images, specially built node images, or internal Microsoft-supplied appliances): do not assume they are covered by the Azure Linux attestation. Perform artifact-level inspection and rely on vendor attestations when available. If Microsoft later adds those products to the CVE/VEX mapping, the vendor will update the public CVE entry.
  • For third‑party images hosted in Azure Marketplace or container registries: rely on the image vendor’s advisories. Microsoft’s attestation for Azure Linux does not automatically extend to third‑party Marketplace or partner images unless the vendor explicitly states so.
Strengths and limitations of Microsoft’s VEX/CSAF approach (analysis)​
Strengths​
  • Transparency and machine-readable signals: Publishing CSAF/VEX entries for Azure Linux grants automation-friendly inventory data that enables large fleets to triage exposure quickly and respond programmatically. Microsoft’s commitment to expand attestations improves traceability between CVEs and product artifacts.
  • Product-focused prioritization: By attesting a specific product family (Azure Linux) early, Microsoft gives deterministic guidance for the many customers who run those images in Azure, reducing ambiguity for that high-impact surface.
Limitations and risks​
  • Phased rollout creates temporary “unknowns”: Until the vendor inventories and attests every product family, customers that run non-attested Microsoft artifacts face uncertainty and must do artifact-level inspections themselves. Absence of an attestation is not proof of safety.
  • Per-artifact variability: Kernel presence depends on build-time flags and commit ranges; some Microsoft artifacts (e.g., WSL2 kernels, appliance images) may be built with different configurations, requiring individualized verification.
  • Operational overhead for customers: The practical burden falls on customers and platform operators to reconcile vendor attestations with the particular images, container layers, and binaries they run. That includes scanning for static binaries, embedded kernels, and backported patches in custom appliances.
Recommended operational checklist (concise)​
  • If you run Azure Linux images: apply Microsoft’s published updates and subscribe to Microsoft’s VEX/CSAF feed to automate triage.
  • For every Linux artifact you operate (including WSL2, Marketplace images, AKS node images, and container base layers):
  • Check kernel version / package metadata.
  • Scan for net/bluetooth/eir.c presence in the kernel source or packaged modules.
  • Rebuild anything that embeds an affected kernel or statically compiled module.
  • Apply compensating controls (disable Bluetooth, restrict access) where patching will be delayed.
  • Monitor vendor advisory channels and distribution trackers (Debian, Ubuntu, vendor security pages) for confirmation of fixed package versions for your platform.
Closing analysis​
Microsoft’s MSRC entry for CVE-2025-38303 and its machine-readable VEX/CSAF practice give Azure customers a clear, automatable signal: Azure Linux includes the implicated Linux Bluetooth code and is therefore in-scope for remediation. That statement is correct as a product-scoped inventory result. It is not, however, a blanket assurance that no other Microsoft product could carry the same upstream code; Microsoft explicitly commits to updating the CVE/VEX mapping if further product exposure is discovered. Customers must combine vendor attestations with per-artifact inspection — checking kernel versions, kernel build configurations, and SBOMs — before concluding whether a non‑attested Microsoft artifact is safe. The technical fix is upstream and straightforward to consume via normal kernel updates; the immediate operational call is to patch Azure Linux images as Microsoft recommends and to inventory other images and artifacts in your estate for the presence of the vulnerable Bluetooth code. Where patching is delayed, apply the mitigations described above to limit exposure and maintain availability.
Microsoft’s advisory naming Azure Linux as “potentially affected” is a precise, actionable product-level attestation: it identifies where Microsoft has completed inventory and found the vulnerable open-source component. It is not, and should not be read as, an exclusionary claim that no other Microsoft product could possibly include the same upstream code — that determination requires either a Microsoft VEX/CSAF attestation for each product or direct artifact inspection. Operators should act on Microsoft’s Azure Linux remediation guidance immediately, and simultaneously verify all other Microsoft and third‑party images and artifacts across their estate to ensure complete coverage.
