Microsoft’s CVE entry for CVE-2025-62203 calls the Excel flaw a “Remote Code Execution” vulnerability, but the published CVSS vector marks the Attack Vector as Local (AV:L) — a distinction that looks contradictory at first glance but, in practice, reflects two different questions: what an attacker can achieve and how the exploit must be triggered.
An illustration contrasting remote cloud delivery via email with a local trigger from a spreadsheet.Background​
Microsoft’s Security Update Guide and the associated CVE title are intentionally concise: saying Remote Code Execution (RCE) signals the high-impact outcome that an external adversary can cause code to run on a victim’s machine if the exploitation chain succeeds. CVSS, by design, breaks exploitability into discrete metrics — one of them is Attack Vector (AV), which describes the location of the vulnerable component at the moment the vulnerability is triggered. When the final triggering action occurs inside a local application process (for example, when Microsoft Excel parses a workbook on the endpoint), CVSS records AV:L, even if the malicious file was delivered to the machine remotely via email, cloud share, or web download.
This split — headline impact vs. technical trigger — is common for Office document-parsing vulnerabilities. Vendors use the RCE label as an operational shorthand to indicate the attacker’s origin can be external and the impact may be severe, while CVSS captures the technical mechanics required to exploit the bug. Understanding both signals is critical for correct triage and mitigation planning.
What CVE-2025-62203 actually conveys​
The advisory headline: impact and urgency​
The CVE title “Remote Code Execution” is an immediate triage signal: it tells administrators and defenders that a remote actor can cause a target to run arbitrary code, subject to the exploitation chain completing. That phrasing is useful in operations because it prioritizes items that can enable a full compromise and helps security teams decide what to patch first. The shorthand is deliberately blunt: RCE equals high operational risk.
The CVSS Attack Vector: the moment of trigger​
The CVSS Attack Vector (AV) metric asks a different question: "Where must code run when the vulnerable component is invoked?" If the vulnerable logic executes inside an application on the endpoint (Excel parsing a local file), the correct CVSS value is Local (AV:L). CVSS treats network delivery and the local parsing act as separate phases and avoids "double-counting" the network step, which preserves consistent scoring across diverse exploit models. This is why AV:L is technically correct for many document-based RCEs.
Why the apparent mismatch is intentional (not an error)​
Two different audiences, two different goals:
  • Vendor advisories and CVE titles prioritize rapid, operationally useful warnings. Labeling a bug as RCE draws attention because defenders know the worst-case result: arbitrary code execution from an external actor.
  • CVSS is a standardized scoring system used to enable automated triage pipelines and risk calculations. It documents precise exploit mechanics to allow consistent, comparable scoring across thousands of vulnerabilities. When the exploit’s final execution happens locally, CVSS records AV:L.
Put simply: “Remote” in the CVE title refers to the attacker’s location or delivery channel; AV:L describes the execution context required to trigger the vulnerability. Both are correct and complementary.
The technical anatomy: how a remote delivery becomes an RCE despite AV:L​
Typical exploitation chain for Excel parsing bugs​
  • Attacker crafts a malicious Excel workbook (XLSX, XLSB, or embedded object) that leverages a memory-safety defect (use-after-free, heap overflow, out-of-bounds read/write).
  • The attacker delivers the file remotely — via spear-phishing email, a shared cloud link, a file upload, or web download.
  • The victim opens the workbook (or a preview component renders it) in a local Excel client.
  • Excel’s native parser encounters the malformed structure, triggers memory corruption, and the attacker’s payload executes inside the Excel process with the logged-on user’s privileges.
Steps 2 (remote delivery) and 4 (local execution) are distinct; CVSS focuses on step 4 when assigning AV.
Why native parsing bugs bypass common mitigations​
Excel’s parsers are complex and include legacy binary formats, Open XML subdocuments, OLE/ActiveX handling, and rendering engines. These are implemented in native code and can contain subtle memory management defects. Such data-only attacks can lead to arbitrary code execution without macros or scripts, making classic macro-blocking mitigations insufficient.
The important exception: server-side rendering and preview handlers​
There is an operationally critical exception: if a network-accessible server or service (for example, an email gateway that generates attachment previews, Office Online Server, or a collaboration platform) parses the same vulnerable content using the affected parser, the vulnerable code runs in a network-bound process. In that case the correct CVSS Attack Vector becomes Network (AV:N) because an attacker can trigger the vulnerable code remotely without requiring the target endpoint user to open the file. Vendors call this out explicitly when applicable, because it materially increases exposure.
This is why administrators must map where parsing occurs in their environment — not just which desktops run Excel, but which servers and services process or preview Office files on behalf of users. If any server-side component uses the vulnerable parser, treat that host as a high-priority patch candidate.
Practical implications for defenders​
Why AV:L should not be interpreted as “low risk”​
  • Ubiquity of Excel: Excel is installed widely across enterprises and consumers, increasing the attack surface and likelihood that a crafted file will reach a user.
  • Low-friction delivery channels: Email, cloud collaboration, and shared drives let attackers distribute malicious files cheaply and at scale.
  • User interaction is easy to social-engineer: Phishing and business-email compromise techniques make it straightforward to convince users to open a spreadsheet.
Therefore, even vulnerabilities scored AV:L can be highly exploitable in practice and deserve immediate remediation. Treat RCE-class advisories as urgent patch items regardless of CVSS AV alone.
Prioritization checklist for IT teams​
  • Confirm affected Excel/Office builds across your estate and match them to Microsoft’s published updates. Deploy the vendor patches through your management tools (WSUS, Intune, SCCM, Microsoft Update).
  • Harden mail gateways and collaboration platforms to reduce delivery risk: sandbox attachments, block risky file types, and restrict auto-preview features where feasible.
  • Enforce Protected View and strict macro execution policies for files from the Internet. This reduces the risk of accidental execution and provides an additional barrier while patches are deployed.
  • Use application control and Attack Surface Reduction (ASR) rules to prevent Office from launching child processes or executing untrusted payloads. Combine with EDR detection rules for anomalous Office process behavior.
  • Conduct targeted EDR hunts for suspicious Excel process activity and preserve suspected malicious files for analysis. Prioritize endpoints that handle sensitive spreadsheets.
How to communicate the nuance to non-technical stakeholders​
Explaining the difference in plain language matters. Use this simple analogy: the attacker sends a booby-trapped parcel from afar (remote delivery), but the trap only springs when the recipient opens the box (local trigger). The headline tells you someone outside can cause harm; the CVSS vector tells you the harmful action happens only after the parcel is opened on the endpoint. Both points matter for mitigation planning.
For executives, focus on impact and mitigations: RCE means an attacker could run code on a company machine if a user opens a malicious spreadsheet — patching, mail hardening, and user training are immediate, cost-effective mitigations. For security teams, provide the CVSS metrics and explain the implications for exploitability and automation.
Risk analysis: strengths and limitations of the vendor wording​
Strengths​
  • Operational clarity: The RCE label quickly communicates high impact and encourages rapid patching, which is exactly the intended effect for urgent advisories.
  • Triage efficiency: Administrators triage RCEs faster than lower-impact classes; the succinct label helps prioritize scarce patching resources.
Risks and potential for misunderstanding​
  • Oversimplification: Headline wording can be misread as implying the vulnerable component is network-facing, when the exploit actually requires user interaction. This can misdirect remediation focus if teams do not read the advisory body or CVSS vector.
  • Automated triage pitfalls: Security automation that relies solely on CVE titles (for example, prioritizing all “RCE” entries as network-exploitable) may misclassify the exposure model unless CVSS AV is also considered.
  • The server-side blind spot: Environments that run server-side rendering or previewing can turn an AV:L client risk into an AV:N server risk. If organizations overlook server-side parsing, they may under-prioritize truly network-exploitable hosts.
Verification and open questions​
  • Microsoft’s advisory text and CVSS vector reflect the canonical vendor position that the attack outcome is RCE while the CVSS AV is Local for document-parsing triggers. Analysts should always read both the title and the CVSS metadata to understand the full picture.
  • At the time of vendor disclosure, community mirrors and third-party trackers reported a patch and did not universally report confirmed in-the-wild exploitation; absence of public proof-of-concept does not guarantee the issue is not being weaponized privately. Exercise caution and patch promptly. This claim is current as of the advisory publication but may change as researchers publish technical write-ups or PoCs.
Flag: while vendor advisories and community mirrors consistently explain the delivery-vs-trigger model, specific low-level root-cause details (exact parser component, record type, or exploit primitive) are often withheld in early advisories — treat any reconstructive technical claims as provisional until corroborated by vendor KBs or reputable technical analyses.
Concrete mitigation steps (operational checklist)​
  • Inventory
  • Map installed Office and Excel build numbers across endpoints and servers.
  • Identify servers, gateways, and services that render or preview Office files.
  • Patch
  • Obtain and deploy Microsoft’s security updates for the affected Excel/Office builds via your patch management system.
  • Harden email and collaboration channels
  • Enable sandboxing for attachments, quarantine suspicious files, and restrict automatic previews.
  • Endpoint controls
  • Enforce Protected View for files from the Internet.
  • Apply ASR rules to prevent Office applications from launching child processes.
  • Restrict macro execution by Group Policy and require signed macros where feasible.
  • Detection and response
  • Tune EDR to monitor for unusual Office process behavior and privilege escalation attempts originating from Excel processes.
  • Preserve potential malicious files and corresponding telemetry for analysis.
  • User awareness
  • Brief high-risk user groups (finance, HR, legal) about the danger of unsolicited spreadsheet attachments and phishing tactics.
These measures together reduce the window of opportunity for attackers and provide layered defenses while patches roll out.
The broader takeaway for security operations​
CVE-2025-62203 exemplifies a recurring pattern in Office security: remote delivery, local trigger. The advisory headline captures the attacker’s reach and the impact, while CVSS AV captures the technical exploit moment. Neither is wrong; both are necessary for a complete operational picture. Effective risk management requires reading both the headline and the CVSS metadata, mapping where parsing occurs in your environment, and applying layered mitigations that include patching, mail hardening, endpoint controls, and active detection.
Administrators should treat RCE-class Office advisories as high priority even when CVSS lists AV:L, and should escalate patching for any server-side components that parse Office documents because those hosts can convert a local-trigger vulnerability into a network-exploitable one.
The label “Remote Code Execution” in CVE-2025-62203 communicates a critical operational truth: a remote adversary can cause code to run on a target system if the exploitation chain completes. The CVSS Attack Vector: Local (AV:L) is a technical, standardized description indicating the exploit triggers when Excel parses a file on the endpoint. The two descriptions answer different questions and are intentionally complementary: one signals impact and actor reach; the other specifies the exploit mechanics required at trigger time. For defenders, the right response is straightforward — assume high impact, assume remote delivery is feasible, verify whether any server-side parsers amplify exposure, and deploy vendor updates and layered mitigations immediately.
