CISA has published an advisory for CVE-2026-5846, a flaw in Watchfire Controller Software that could let an authenticated attacker deliver malicious firmware and ultimately take full control of an affected digital-sign controller.
The issue affects Watchfire BC550, BC750, BC760, and BC760DC controllers running specified firmware releases. CISA says the products contain self-signed, hard-coded RSA private keys and matching X.509 certificates used by the built-in HTTPS/TLS management interface. Those keys were embedded in plaintext in firmware patch binaries available through Watchfire’s Remote Support filestore.
While CISA assigns the vulnerability a CVSS v3.1 score of 5.7, or Medium severity, its newer CVSS v4.0 score is 7.6, rated High. The practical concern is integrity: compromised certificate material could undermine firmware-authentication safeguards and enable a malicious update to be accepted by a controller.
According to CISA, Watchfire has applied the required security patch to controllers it manages and has issued updates that disable use of the existing certificate. Organizations operating their own systems should verify both the controller model and installed software version.
The affected versions and required patch targets are:
Even so, controllers should not have their management interfaces directly exposed to the internet. CISA recommends placing control-system devices behind firewalls, separating operational networks from business networks, and using current VPN software where remote access is necessary.
For Windows administrators supporting facilities teams, this is primarily an asset-inventory and change-control task: identify Watchfire controller models, confirm their firmware version against the affected list, coordinate maintenance windows, and ensure the management path is segmented before applying the approved update.
Patch levels replace the exposed certificate material
According to CISA, Watchfire has applied the required security patch to controllers it manages and has issued updates that disable use of the existing certificate. Organizations operating their own systems should verify both the controller model and installed software version.The affected versions and required patch targets are:
- BC550 version 12.30 should be updated to 12.31 SP1.
- BC750 version 11.33 should be updated to 11.34.
- BC750 version 12.35 should be updated to 12.36 SP1.
- BC760 version 12.38 should be updated to 12.41 SP1.
- BC760 version 13.00 should be updated to 14.00 SP1.
- BC760DC version 12.39 should be updated to 12.41 SP1.
Remote management exposure is the immediate risk factor
The advisory describes the attack as network-accessible, but notes high attack complexity and required user interaction under CVSS v3.1. CISA reported no known public exploitation specifically targeting CVE-2026-5846 as of the advisory’s July 30, 2026 publication.Even so, controllers should not have their management interfaces directly exposed to the internet. CISA recommends placing control-system devices behind firewalls, separating operational networks from business networks, and using current VPN software where remote access is necessary.
- Primary source: CISA
Published: 2026-07-30T12:00:00+00:00
Loading…
www.cisa.gov
