Background / Overview
Hospital back‑end services increasingly run web stacks (APIs, management consoles, reporting portals) built on Microsoft’s ASP.NET platform. Those services process highly sensitive data—patient identifiers, clinical records, device telemetry, and session tokens—and often integrate with medical device management and scheduling systems. An information leak in that software stack is therefore both a privacy incident and a potential operational safety risk for healthcare delivery.
Vertikal Systems’ affected component, described in the advisory as “Hospital Manager Backend Services” (affected versions: prior to September 19, 2025), exposed two configuration mistakes commonly seen in ASP.NET apps:
- An unauthenticated, publicly reachable trace viewer at /trace.axd that returned live traces including request headers, session identifiers, server variables and internal file paths (CVE‑2025‑54459).
- Verbose ASP.NET error pages for invalid WebResource.axd requests that disclosed framework versions, stack traces, and the fact that customErrors was configured as mode="Off" (CVE‑2025‑61959).
CISA’s advisory summarizes impact and mitigation actions and reports the vendor implemented fixes by September 19, 2025.
Why this matters for healthcare cybersecurity
Healthcare environments mix regulated patient data, life‑critical equipment, and a wide variety of clinical IT and OT systems. When a backend service leaks session tokens, authorization headers, file paths or framework versions, the consequences are practical and immediate:
- Reconnaissance acceleration — Stack traces and framework versions reduce the time an attacker needs to identify exploitable components, craft probes, or target known exploits for the exact ASP.NET/assembly versions in use.
- Credential/session theft — Trace output often contains cookies, session IDs, or other authentication metadata. An attacker with those values can impersonate a user session or escalate to admin actions.
- Supply chain / lateral pivot risk — Exposed internal paths and configuration details make it easier to craft subsequent attacks (file inclusion, directory traversal, misconfigured endpoints) and to move laterally across hospital networks.
- Patient safety implications — For services that manage device settings, scheduling, or real‑time telemetry, compromise of a backend can disrupt device availability or integrity—outcomes that can harm patients beyond privacy loss.
CISA’s guidance for control systems and medical advisories consistently emphasizes limiting Internet exposure and isolating ICS/medical device networks; the Vertikal advisory reinforces those standard controls applied to web applications in healthcare contexts.
Technical breakdown
What /trace.axd is and why it’s dangerous
ASP.NET has a built‑in tracing facility developers use for debugging; trace results are viewable via the trace viewer at /trace.axd. When enabled and reachable remotely it enumerates recent requests and, when a request’s “View Details” link is fetched, will show per‑request information: HTTP headers, query strings, POST bodies, server variables, module timing, and more. This output can include:
- Session cookies or session identifiers
- Authorization headers or tokens
- Query and form parameters (which may contain PHI)
- Physical file paths on the server (which aid path traversal or LFI attacks)
- Stack frames and assembly names
Microsoft documents the feature and warns administrators to disable or restrict remote access to it in production; it is intended for development or controlled debugging only. Allowing /trace.axd to be accessed remotely without authentication is a well‑known misconfiguration and is routinely flagged by web scanners. Security scanners and vendors classify this as a sensitive information disclosure finding and recommend disabling remote tracing or restricting access by role or network. Practical remediation options include disabling tracing in web.config or gating /trace.axd behind strong access controls.
Verbose error pages via WebResource.axd and customErrors mode="Off"
WebResource.axd and ScriptResource.axd are ASP.NET handlers used to serve embedded resources (scripts, images) combined into single requests. Misconfigured error handling—most commonly placing <customErrors mode="Off" /> in web.config—causes the runtime to return detailed exception pages (stack traces, exception messages, internal paths) to remote callers.
Those verbose YSOD (Yellow Screen Of Death) pages are invaluable to attackers during reconnaissance because they reveal:
- ASP.NET and .NET framework version numbers
- Stack traces and function names
- File system paths and configuration details (e.g., web.config locations)
- Potentially sensitive variable contents if exceptions include request data
Microsoft’s operational guidance is explicit: do not set customErrors mode="Off" in production; use "On" or "RemoteOnly" and provide friendly error pages. When verbose errors are present and reachable, they materially lower an attacker’s cost to weaponize further vulnerabilities.
Scoring and exploitability
CISA assigned CVE IDs and published CVSS scores reflecting remote exploitability with low complexity:
- CVE‑2025‑54459 (trace.axd exposure): CVSS v3.1 base 7.5 (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N) and CVSS v4 base 8.7. The vector strings indicate network attack vector, no privileges required, no user interaction, and high confidentiality impact for exposed session data.
- CVE‑2025‑61959 (verbose WebResource.axd error pages): CVSS v3.1 base 5.3 and CVSS v4 base 6.9, reflecting lower technical impact than a live session leak but still significant for reconnaissance and staged exploitation.
Those numeric ratings align with how mature scanners treat such findings: trace.axd is treated as a high confidentiality risk because it can lead directly to account/session compromise when present in production, while verbose errors are scored lower but still flagged as enabling further attack stages. The vendor’s patching on September 19, 2025, reduces immediate exposure but does not remove the need for continuous configuration hygiene and network controls.
How attackers could weaponize these issues — realistic attack chains
- Discovery: Internet scan or credential‑phished device finds Hospital Manager service reachable on public IP.
- Reconnaissance: A GET to /trace.axd returns a list of recent requests; attacker views details for sessions and harvests cookies, authorization headers, or paths.
- Session replay / impersonation: Using harvested session identifiers or authorization headers, the attacker replays requests to the API to access patient records, change schedules, or modify device parameters.
- Escalation: Stack traces or framework version disclosures from WebResource.axd error pages identify an exploitable library or known CVE for which exploit code exists; attacker targets that component to gain deeper control or persistent access.
- Lateral movement: Compromised backend becomes a pivot to device management networks, enabling manipulation of device firmware updates or telemetry insertion.
This chain requires minimal skill if the endpoints are reachable and sensitive traces are exposed — exactly the conditions CISA warns about in similar ICS/medical advisories.
Vendor response and current status
Vertikal Systems fixed the referenced issues by September 19, 2025 according to the advisory and coordinated disclosure. CISA’s advisory noted that no known public exploitation specifically targeting these two vulnerabilities had been reported to the agency at the time the advisory was posted. Organizations should nonetheless assume active scanning for exposed /trace.axd endpoints is common practice among attackers and defenders alike, and they should validate whether they were exposed prior to patching, as post‑patch attack activity sometimes follows public disclosure.
Note on CVE/NVD records: CVE identifiers have been assigned by the coordinating authority, but authoritative CVE/NVD pages may lag vendor advisories and CISA notices. Security teams should cross‑check the vendor advisory, CISA, and public CVE/NVD entries when assembling patching tickets and risk statements; if a NVD entry is missing or incomplete, prioritize the vendor fix and compensating controls while NVD indexing catches up.
Practical remediation checklist (for hospital IT and security teams)
Follow these prioritized steps to reduce immediate risk and harden ASP.NET-based services in production:
- Apply vendor‑supplied patches immediately.
- Confirm the exact build/version deployed and update to the vendor’s patched release (the Vertikal advisory lists fixes applied by September 19, 2025).
- Disable or restrict the ASP.NET trace viewer:
- In web.config, set <trace enabled="false" /> or configure <trace localOnly="true" /> when debugging is required.
- Enforce safe error pages:
- Ensure <customErrors mode="On" /> or <customErrors mode="RemoteOnly" /> and supply a generic friendly error page; do not leave mode="Off" in production.
- Block or restrict /trace.axd and resource handlers at the perimeter:
- Use WAF rules, firewall ACLs, or reverse proxy configuration to deny anonymous access to /trace.axd and to filter or restrict direct access to .axd handlers.
- Segment and firewall medical backend networks:
- Place Hospital Manager backend and device management systems behind a dedicated VLAN, accessible only from management hosts and enforced by firewall rules.
- Enforce least‑privilege and robust authentication:
- Rotate any exposed keys/tokens, review API keys, and ensure session lifetimes and token invalidation behave correctly after revocation.
- Monitor and hunt for indicators:
- Search web server logs for requests to /trace.axd, WebResource.axd errors, unusual large numbers of 500 responses, or anomalous authorization header reuse.
- Conduct a retrospective incident review:
- If traces were exposed prior to patching, assume data of confidentiality value (session IDs, PHI parameters) may have been seen; notify and follow regulatory reporting requirements as appropriate.
- Test and verify:
- Run authenticated and unauthenticated web vulnerability scans (commercial or open‑source) to verify /trace.axd is inaccessible and customErrors no longer discloses stack traces.
- Update policies and developer training:
- Include secure default web.config templates, secure deployment checklists, and developer education on not enabling tracing or verbose errors in production.
Numbered remediation guidance above provides an operational sequence to reduce risk quickly, with immediate patching and configuration changes first, followed by network and monitoring controls.
Detection and incident response: how to hunt for exposure and indicators
- Server log hunts:
- Search IIS/HTTP logs for GET requests to /trace.axd or repeated POST/GET requests that return detailed error pages containing “StackTrace” or runtime exception strings.
- Query logs for requests showing Authorization headers reused across IPs or suspicious user agents.
- On‑site scanning:
- Use curl or browser to confirm that /trace.axd returns a 403/404 or is otherwise blocked from non‑local hosts.
- Example quick test: curl -I https://host/path/trace.axd
- Confirm WebResource.axd requests do not return detailed exception pages (HTTP 500 with stack traces).
- SIEM detection rules:
- Raise alerts for any inbound 200 responses from /trace.axd coming from non‑management subnets.
- Flag server responses containing “Exception”, “StackTrace”, or “at System.” in the response body.
- Forensic steps if exposure is discovered:
- Preserve server logs and web server request traces (rotate and archive).
- Identify sessions or cookies disclosed and determine whether those sessions were later used.
- Reset affected session tokens and API credentials; force logout for potentially impacted users.
- Review upstream and downstream systems for lateral movement or suspicious API calls.
- If PHI or other regulated data was potentially accessed, follow legal and regulatory notification workflows (e.g., HIPAA breach reporting where applicable).
Longer‑term controls and architecture adjustments
- Harden web app defaults:
- Ship secure web.config templates that set tracing disabled and customErrors set to safe defaults.
- Infrastructure access control:
- Place management consoles and administrative endpoints behind a VPN or bastion host, not directly on the public Internet.
- WAF and reverse proxy:
- Implement WAF rules to block uncommon .axd patterns and to inspect responses for verbose error disclosures; combine with rate limits to slow reconnaissance.
- Continuous scanning:
- Integrate authenticated web scanning into CI/CD and nightly security scans to detect regressions where debug features get re‑enabled accidentally.
- DevOps checks:
- Gate production deploys with a check that ensures no debug/tracing settings are present and that log levels are set appropriately for production.
- Vendor management:
- Maintain an inventory of deployed vendor services and ensure vendor security advisories are subscribed to and triaged promptly.
These architectural changes reduce the chance a single misconfiguration will result in a high‑impact information disclosure.
Verification, corroboration, and caveats
- Independent technical sources document the same ASP.NET behavior that enabled these exposures: Microsoft’s ASP.NET tracing and customErrors documentation explain how trace.axd and verbose error pages can leak runtime and configuration details if left enabled in production.
- Security scanners and tooling vendors (Invicti, Acunetix, StackHawk) classify an accessible /trace.axd as a high‑risk information disclosure and prescribe disabling tracing or restricting access. These industry analyses corroborate CISA’s assessment of high confidentiality impact for the trace endpoint.
- CISA’s coordinated disclosure practices and guidance for minimizing exposure of control systems are consistent with the mitigations Vertikal and security teams should apply (segmentation, isolation, firewalling). Organizations should follow CISA’s playbook for ICS and medical device services while applying application‑level fixes.
Caveats and notes:
- Public exploitation: CISA’s advisory stated no known public exploitation of these specific vulnerabilities had been reported to the agency at the time of disclosure. That status can change; organizations should assume they were targeted if they were exposed and perform retrospective detection.
- CVE/NVD timing: Public CVE/NVD database entries may lag vendor and CISA advisories. If you require authoritative CVE/NVD pages for compliance evidence, check those sources alongside the vendor advisory, but do not delay emergency mitigations waiting for NVD indexing.
- Configuration drift: Tracing or verbose errors can be reintroduced by developer tools, automated deployments, or third‑party libraries. Ongoing configuration checks and policy enforcement (e.g., CI/CD gates) are necessary.
Executive recommendations for hospital CISOs and IT leaders
- Treat web‑facing backend services as high‑priority assets for patching and monitoring because they carry patient data and can influence device behavior.
- Immediately confirm whether any hospital‑hosted instances of Hospital Manager Backend Services were publicly reachable before September 19, 2025 and, if so, perform an incident review focused on session reuse and suspicious API calls.
- Require vendors to demonstrate secure deployment defaults and to provide clear mitigation documentation with each advisory; demand CVE assignments and a timeline for notification when services are in medical workflows.
- Integrate web application checks into medical device and clinical‑application asset inventories; medical device security and web application security functions must be coordinated.
- Update tabletop incident response plans to include scenarios where a backend information disclosure leads to downstream device impact or regulatory reporting obligations.
The Vertikal Systems Hospital Manager Backend Services advisories are a reminder that common, avoidable ASP.NET misconfigurations—an exposed /trace.axd endpoint and verbose error pages driven by customErrors mode="Off"—carry outsized risk in healthcare settings. The fixes released by Vertikal on September 19, 2025 remove the specific exposures reported, but the real work for hospitals begins after patching: validating that production configurations remain secure, limiting Internet exposure, enforcing least privilege, and building detection that finds regressions early.
The technical lesson is straightforward: debug features are dangerous in production, and detection/segmentation are essential compensating controls when vendor patches or architecture changes cannot be applied immediately. Follow the remediation checklist, hunt for historical exposure, and treat any evidence of pre‑patch access as an incident that requires containment, credential resets, and a forensic review. For supply‑chain and vendor‑managed medical services, insist on secure defaults and proactive notification of security issues—patient safety depends on it.
