CISA’s September additions to the Known Exploited Vulnerabilities (KEV) Catalog — the TP‑Link TL‑WA855RE missing‑authentication flaw (CVE‑2020‑24363) and the WhatsApp incorrect‑authorization weakness (CVE‑2025‑55177) — are a reminder that adversaries continue to exploit both legacy IoT devices and modern messaging platforms. The two entries, added on September 2, 2025 with remediation due dates set for September 23, 2025 in the KEV catalog, underscore divergent but complementary threat trends: unauthenticated device takeover on local networks and sophisticated, zero‑click espionage chains against high‑value mobile and desktop targets. Both vulnerabilities pose real operational risk to organizations that fail to inventory, patch, or retire vulnerable assets quickly.
Security scene: Factory Reset Required on a router, paired with smartphones on a laptop.Background / Overview​
CISA’s KEV Catalog exists to concentrate remediation efforts on vulnerabilities that are known to be actively exploited in the wild. Under Binding Operational Directive (BOD) 22‑01, federal civilian agencies must remediate cataloged CVEs according to the deadlines shown in the KEV entries; private sector organizations are strongly urged to treat KEV items as top priorities for their vulnerability management programs. The two additions reported this week illustrate two recurring problem classes for defenders:
  • End‑of‑life or poorly managed IoT devices with weak or missing authentication controls that allow attackers local network access to escalate into persistent device control.
  • Application logic/authorization defects in mainstream apps that, when combined with OS‑level vulnerabilities, enable highly targeted zero‑click compromises used in espionage campaigns.
The catalog entries put both trajectories — mass‑scale opportunistic compromise of unmanaged devices, and narrow, high‑value targeted intrusion campaigns — back on the board for immediate remediation.
What CISA added and why it matters​
The two KEV additions at a glance​
  • CVE‑2020‑24363 — TP‑Link TL‑WA855RE: Missing Authentication for Critical Function.
  • Affected product: TP‑Link TL‑WA855RE (V5 firmware builds identified).
  • Issue: Unauthenticated TDDP_RESET POST allows factory reset and subsequent administrative takeover.
  • Practical consequence: Local‑network attacker can reset the device to defaults and set a new admin password, gaining persistent control.
  • KEV entry date added: September 2, 2025. KEV remediation due date: September 23, 2025.
  • CVE‑2025‑55177 — Meta Platforms (WhatsApp): Incorrect Authorization Vulnerability.
  • Affected products: WhatsApp for iOS (prior to v2.25.21.73), WhatsApp Business for iOS (v2.25.21.78), WhatsApp for macOS (v2.25.21.78).
  • Issue: Incomplete authorization in linked‑device synchronization messages could allow an unrelated user to trigger processing of content from an arbitrary URL on a target device.
  • Practical consequence: When chained with an Apple Image I/O out‑of‑bounds flaw, it can produce a zero‑click spyware delivery mechanism that requires no interaction by the victim.
Both catalog entries include a recommended action: apply vendor mitigations per instructions, follow BOD 22‑01 guidance where applicable, or discontinue use of the product if mitigations are unavailable.
Deep dive: CVE‑2020‑24363 — TP‑Link TL‑WA855RE missing authentication​
Technical summary​
The TP‑Link TL‑WA855RE (V5 firmware family) contains an endpoint — the TDDP_RESET POST handler — that lacks proper authentication checks. An attacker with local network access (adjacent network access) can submit a crafted TDDP_RESET request to force a factory reset and reboot of the device. Once reset, the attacker can take advantage of default credentials or unauthenticated administrator setup to configure a new administrative password, effectively taking full control of the range extender.
Key technical points:
  • The vulnerability is classified as CWE‑306: Missing Authentication for a Critical Function.
  • Exploitation requires network adjacency (the attacker must be on the same local network or be able to reach the device’s management interface).
  • After the reset, the device may accept default or newly set administrator credentials, yielding persistent administrative access.
Threat context and exploitation risk​
This is a classic IoT management‑plane flaw: local access + missing auth → device takeover. While an attacker typically needs access to the same local network, real‑world scenarios that increase risk include:
  • Public Wi‑Fi networks or shared guest networks where attackers can gain lateral access.
  • Corporate networks with poorly segmented device management VLANs.
  • Home gateway compromises that allow attackers to reach connected extenders.
Importantly, devices like the TL‑WA855RE are often deployed in places with low visibility (corners of branch offices, kiosks, retail floors), and they are sometimes neglected in asset inventories — which makes them high‑value targets for lateral movement.
Vendor status, patching, and mitigation​
  • Vendor firmware updates addressing the issue exist for some hardware revisions/regions; however, some affected product lines are reported to be end‑of‑life (EoL), which complicates patch availability.
  • If a firmware update is available for the exact hardware revision, apply it immediately.
  • If there is no vendor patch or the device is EoL, discontinue product use or isolate the device from sensitive networks.
Recommended mitigations:
  • Update firmware to the vendor‑provided fixed version where available.
  • Immediately change default credentials and enforce strong administrative passwords.
  • Segment management interfaces onto separate VLANs; restrict access to device management to known admin hosts.
  • Disable remote/remote management interfaces if not required.
  • Replace EoL devices with supported hardware that receives security updates.
Detection and incident response​
  • Monitor for unexpected factory resets, abrupt reboots, or new administrative account creation on extenders.
  • Check DHCP/ARP logs and SIEM telemetry for anomalous management traffic or POST requests targeting the device’s management endpoints.
  • If compromise is suspected, remove the device from the network, reimage/replace hardware, and review upstream network access for persistence.
Deep dive: CVE‑2025‑55177 — WhatsApp incorrect authorization and zero‑click risk​
Technical summary​
CVE‑2025‑55177 is an authorization logic flaw in the linked‑device synchronization flow of WhatsApp on Apple platforms. The flaw permits processing of content fetched from an arbitrary URL in the context of a target device under certain conditions because authorization checks on linked‑device synchronization messages were incomplete.
When exploited in concert with an Apple Image I/O out‑of‑bounds write (an OS‑level memory corruption issue), the chain can be weaponized into a zero‑click exploit: a maliciously crafted synchronization message triggers the app to request and process content that exploits the OS-level memory corruption to achieve remote code execution — all without any user action.
Key implications:
  • The vulnerability itself is an application‑level logic issue (incorrect authorization), but the real‑world impact is severe only when combined with an OS memory corruption (e.g., the Apple Image I/O CVE).
  • The attack path is stealthy and highly targeted; it is well suited for spyware operators and state‑level surveillance actors.
Observed exploitation and scale​
  • Evidence collected by vendors and investigative teams indicates that the WhatsApp vulnerability was used in targeted operations and that WhatsApp (Meta) sent in‑app notifications to fewer than 200 potentially affected users. Those notifications and external forensic work suggest the campaign targeted specific high‑value individuals, not mass compromise.
  • Amnesty International’s security lab and independent researchers indicated the chain was used in a sophisticated surveillance campaign over a period of months.
Caveat: attribution and campaign scope remain uncertain in open reporting. Public sources confirm targeted exploitation and notifications, but definitive attribution to a specific vendor or nation‑state actor has not been publicly proven. Where reporting is incomplete or evolving, treat attribution claims with caution.
Affected versions and remediation​
  • Affected WhatsApp clients:
  • WhatsApp for iOS prior to v2.25.21.73
  • WhatsApp Business for iOS prior to v2.25.21.78
  • WhatsApp for macOS prior to v2.25.21.78
Recommended mitigations for end users and organizations:
  • Update WhatsApp clients immediately to the patched versions above or later.
  • Apply the latest OS patches from Apple (Image I/O fixes and other stability/security updates).
  • For users who received direct compromise notifications or who are high‑value targets: follow vendor guidance, which may include a recommended factory reset of the device and reinstallation of the OS and applications.
  • Revoke and re‑authorize linked devices; review active sessions and signed‑in devices in WhatsApp settings.
  • Enable device‑level protections: iOS Lockdown Mode, stricter app permissions, and robust device encryption.
  • Use multi‑factor protection for associated accounts where available; enable WhatsApp two‑step verification for account binding.
  • Look for indicators of compromise related to unexpected linked device pairings, unexplained network activity to external URLs, or anomalous image/media processing patterns on endpoints.
  • Endpoint detection and response (EDR) tools that monitor process behavior and network calls can help catch post‑exploit activity; however, pre‑execution zero‑click exploitation may leave minimal indicators before a payload achieves persistence.
  • For suspected targeted compromise, adopt high‑confidence containment: isolate the device, collect forensic artifacts, and consider device reimaging or full factory reset per vendor and investigator guidance.
Why these two additions are strategically significant​
1) Legacy IoT is still a primary foothold​
IoT devices like Wi‑fi extenders are widely deployed and often forgotten. They frequently run minimal firmware and exposed management APIs with weak protections. The TP‑Link entry is emblematic of a broader systemic problem: unmanaged devices with weak authentication become easy stepping stones for lateral movement and persistent access. The KEV addition signals that even older CVEs (from 2020, in this case) remain relevant when deployed at scale in organizational networks.
2) Messaging apps are an espionage vector​
Messaging platforms are high‑value targets: they store sensitive conversations, media, attachments, and in many cases act as auth vectors for other services. Authorization logic bugs in sync or pairing flows combine with OS bugs to produce powerful, targeted exploitation paths — the classic zero‑click scenario. This approach circumvents user awareness and traditional phishing defenses, raising the bar for detection and response.
3) KEV deadlines matter operationally​
BOD 22‑01 makes the KEV catalog a mandatory remediation driver for federal civilian agencies; private sector actors should treat KEV entries as high priority. The KEV entries themselves include due dates (in this case, September 23, 2025). Agencies and organizations must reconcile catalogue deadlines with internal patch windows, compensating controls, and operational constraints. Where patches aren’t possible — such as with EoL hardware — immediate isolation or replacement is required.
Practical playbook: triage and remediation checklist​
Every security team should translate KEV notices into concrete, auditable steps. The list below is a concise remediation and detection playbook that applies to both the TP‑Link and WhatsApp entries.
  • Inventory and identify:
  • Compile an asset inventory that includes IoT devices, mobile endpoints, and application versions.
  • Use network scanning and management tools to detect TL‑WA855RE devices and WhatsApp client versions.
  • Apply vendor patches:
  • For TP‑Link TL‑WA855RE: check the vendor firmware page for the exact hardware revision and apply the fixed firmware if available.
  • For WhatsApp clients on iOS and macOS: update to the patched release versions immediately.
  • Isolate when patching is not possible:
  • If a TP‑Link device is EoL or cannot be patched, remove it from production networks or place it on a segmented management VLAN.
  • Restrict network access to device management interfaces to admin subnets only.
  • Harden management access:
  • Enforce strong, unique admin passwords; disable default accounts where possible.
  • Restrict remote management and disable UPnP or WAN‑side admin access if not needed.
  • Detect and monitor:
  • Add IDS/IPS signatures for known exploit attempts against the TDDP_RESET endpoint.
  • Monitor endpoints and network telemetry for suspicious fetches to attacker controlled URLs, especially from WhatsApp or image processing subsystems.
  • Review account and session state:
  • For WhatsApp: review linked devices, revoke sessions, enable two‑step verification, and reauthorize only known devices.
  • Incident response for suspected compromise:
  • Preserve system images; collect logs, network captures, and device artifacts.
  • Consider device reimaging or factory reset for confirmed compromises, following vendor guidance when available.
  • Notify relevant stakeholders and escalate to legal/compliance if sensitive data may have been exposed.
  • Post‑incident lessons and policy updates:
  • Update the asset inventory process to capture IoT and consumer devices.
  • Reassess procurement policies to avoid EoL gear in critical roles.
  • Integrate KEV feeds into your vulnerability management platform for automated alerting.
Operational and programmatic recommendations​
  • Automate KEV ingestion. Subscribe to the KEV catalog feed and integrate it into the vulnerability management or ticketing system so catalog additions generate prioritized work items automatically.
  • Adopt aggressive inventory posture. Assets that are untracked are unpatchable. Implement regular discovery scans and CMDB reconciliation focusing on consumer‑grade and IoT devices.
  • Treat EoL hardware as a security liability. EoL devices should be scheduled for replacement or strictly segmented from sensitive networks.
  • Practice rapid rollback and recovery. For critical endpoints where reimaging is the recommended response (e.g., targeted mobile compromises), build tested procedures to restore devices to a known good state quickly.
  • Plan for targeted campaigns. High‑value personnel and privileged accounts need elevated protections (device hardening, OS auto‑updates, physical device security, hardened app settings, and periodic forensic checks).
Risks, caveats, and areas of uncertainty​
  • Attribution for the WhatsApp‑related attacks remains unproven in public sources; while reporting strongly suggests targeted spyware campaigns, definitive public attribution to a vendor or state actor is not confirmed.
  • The scale of exploitation for the TP‑Link vulnerability is difficult to quantify. Keystones of risk are asset visibility and network topology; organizations with poor segmentation are at higher risk.
  • KEV due dates are determined by CISA and can vary; BOD 22‑01 provides general timelines (e.g., accelerated remediation for newer in‑scope CVEs) but the catalog’s specific due date is authoritative for compliance. Organizations must follow the catalog entry date and due date.
  • Some victims of the WhatsApp chain may require full device resets to eradicate persistence; this is a high‑cost response that requires operational planning and user support.
Final analysis: strengthening defenses after KEV additions​
The September 2 KEV additions reiterate two perennial defensive imperatives: maintain up‑to‑date inventories (especially for IoT and consumer devices), and assume that messaging apps are high‑value targets that require layered defenses rather than blind trust in transport encryption. The TP‑Link entry should prompt any organization with consumer‑grade extenders to audit and either patch or replace those devices and to ensure management interfaces are not reachable from untrusted networks. The WhatsApp entry raises the bar for organizations protecting high‑risk people: endpoint hardening, rapid OS and app patching, and careful monitoring for anomalies are non‑negotiable.
Taking the KEV catalog seriously — automating ingestion, enforcing faster patch windows for cataloged items, and building playbooks for both broad IoT compromise and narrow targeted intrusions — will measurably reduce exposure. These additions should not be treated as isolated incidents; they are symptomatic of two structural weaknesses in many enterprises: neglected device lifecycle management and the challenge of detecting stealthy, zero‑click intrusion chains. Addressing both requires operational discipline, tooling, and clear escalation channels between security, IT operations, and executive leadership.
Actionable checklist (quick reference)​
  • Immediately: check for the presence of TL‑WA855RE devices and confirm WhatsApp client versions across enterprise‑managed iOS and macOS devices.
  • Within 24–72 hours: apply available firmware and application patches; if patches are unavailable, isolate or replace the vulnerable device.
  • By the KEV due date: document remediation steps and verify compliance per internal policy (and BOD 22‑01 timelines if you are an FCEB agency).
  • Ongoing: integrate KEV feed into your vulnerability management tooling and strengthen segmentation and monitoring for IoT and mobile app behavior anomalies.
The KEV catalog additions are a timely reminder that defenders must manage two very different threat profiles simultaneously: the mass exposure of unpatched or forgotten devices, and the highly targeted, technically sophisticated exploitation of ubiquitous consumer apps. Both require discipline: inventory and patching cadence for the former, and rapid detection plus layered hardening for the latter. Organizations that operationalize the KEV catalog and close the gap between detection and remediation will be materially safer than those that do not.
