Person at a computer sees a secret project path with a warning icon on screen.
Siemens’ TIA Portal path‑traversal flaw embedded inside Festo Didactic packages is a real, actionable risk for engineering workstations and training systems — and it demands immediate, prioritized remediation across mixed IT/OT environments.
Background / Overview​
Festo Didactic devices — including TP260 training panels and MES‑PC packages delivered with Siemens Totally Integrated Automation (TIA) Portal installers — shipped with versions of TIA Portal that are affected by a path traversal / improper input validation vulnerability tracked as CVE‑2023‑26293. The weakness can let a crafted PC system configuration file cause the engineering environment to create or overwrite arbitrary files; when exploited in certain contexts that leads to arbitrary code execution on the engineering host. The vendor advisories and public CVE records make clear that the primary remediation is to update TIA Portal to the fixed update levels published by Siemens. This article summarizes the technical facts, verifies the most critical claims against independent sources, highlights discrepancies and unanswered questions, and delivers concrete, Windows‑focused mitigation and detection guidance for administrators responsible for engineering workstations and Festo Didactic training systems.
What the advisories say (concise summary)​
  • Affected component: Siemens TIA Portal (versions across V15–V18 as packaged with Festo Didactic systems).
  • Vulnerability: Path traversal / Improper Input Validation (CWE‑20 / CWE‑22) that could enable creation/overwrite of arbitrary files when a user opens a malicious PC system configuration file; in some contexts this can lead to arbitrary code execution.
  • Tracked CVE: CVE‑2023‑26293.
  • Vendor remediation: Update TIA Portal to the versions or update levels Siemens lists (see Siemens SSA‑116924 for exact update guidance).
  • Festo coordination: Festo published a CSAF advisory for affected Didactic devices that bundle TIA Portal; their advisory references the Siemens fix and recommends updating the installed TIA Portal instances shipped with their hardware.
Technical deep dive​
How the vulnerability works​
The vulnerability resides in how PC system configuration files (the files engineers open when loading projects, device configurations, or system backups) are parsed. A specially crafted configuration file can include path segments that are not correctly canonicalized or validated. When the TIA Portal processing code accepts those path fragments, it can result in file writes outside intended directories — enabling an attacker to overwrite installers, configuration files, or components that the engineering environment later executes. This class of flaw is a classic path traversal / external control of file path problem; if the overwritten file is something executed by a privileged service, remote code execution (RCE) is possible.
Exploit preconditions and complexity​
  • User interaction required: The attacker must get a victim to open a malicious PC system configuration file — this is social‑engineering dependent (phishing, drive‑by download, malicious USB, or shared project file). The CVSS and vendor notes emphasize the requirement for user interaction (UI:R).
  • Attack complexity: Low — crafting a malicious configuration file is straightforward for an attacker who understands the file format. The limiting factor is delivering that file to an operator of the engineering workstation.
  • Network remote‑exploitability: Not fully remote in the classic sense — the attacker needs to persuade a user to open the file, but the file can be delivered remotely (email attachment, file share, web download), so remote reach is possible via social engineering.
Affected versions (vendor statements)​
Siemens and downstream Festo advisories list overlapping but not identical affected version ranges. The Siemens SSA‑116924 advisory and the public CVE description enumerate TIA Portal V15–V18 with update cutoffs for V16/V17/V18; Festo’s advisory specifically calls out the TIA Portal bundles shipped on Festo MES‑PC and TP260 hardware with particular update‑level constraints. Administrators must check the installed TIA Portal update level on each Festo device against the Siemens fix list to determine exposure.
Verification and cross‑referencing (what we checked)​
To validate the key claims we cross‑checked:
  • Siemens ProductCERT advisory SSA‑116924 (Siemens’ own security advisory) — describes the path traversal, includes mitigation instructions and tied CVE details. This is the canonical vendor advisory and is the primary source for fixed versions.
  • National Vulnerability Database / NVD entry CVE‑2023‑26293 — restates the vulnerability summary and affected versions; NVD records were used to confirm the CVE assignment and standard details.
  • Festo / CERT@VDE CSAF and advisory summaries — confirm that several Festo Didactic products shipped TIA Portal installers with the vulnerable TIA Portal versions, and that Festo coordinated disclosure through CERT@VDE. The Festo advisory maps the generic Siemens TIA Portal problem into the Festo product inventory (TP260 and MES‑PC bundles).
These three sources independently corroborate the central technical claim (path traversal in TIA Portal via PC system configuration files) and the correct remediation (update TIA Portal).
Notable discrepancy: CVSS scores and vectors​
  • Siemens SSA‑116924 documents a CVSS v3.1 base score of 7.3 for CVE‑2023‑26293.
  • Some downstream summaries (and the CSAF you supplied) have a CVSS v3.1 score of 7.8 or other variants. This difference appears in public trackers that re‑score or display enriched vectors. The NVD entry and Siemens advisory are authoritative for vendor‑published vectors; when downstream sources disagree, treat the vendor/NVD vector as the reference until reconciled.
This discrepancy is important for risk scoring and must be reconciled within each organization’s risk process.
Practical risk evaluation for Windows and engineering teams​
  • Engineering workstations are high‑value targets. Devices running TIA Portal are used to design, configure, and deploy PLC/SCADA logic. A compromised engineering host can be used for lateral movement into OT networks or to deploy malicious logic to controllers.
  • Attack path is plausible in modern operations. Project files and configuration bundles are commonly transferred between vendors, contractors, training labs, and field technicians — typical vectors for malicious files. Festo training devices are often used in corporate labs and classrooms where file exchange is frequent.
  • Business impact: Overwriting key engineering binaries, configuration files, or placing a payload in a workspace that subsequent compilation/deployment runs could execute or push to devices — all plausible consequences. The potential to perform file overwrite + privileged execution makes the vulnerability high‑impact even if exploitation requires user interaction.
Immediate, prioritized actions (operational checklist)​
The following steps are ordered by priority for defenders managing Windows engineering workstations, Festo Didactic devices, and OT/IT boundaries.
  • Patch/update: Update TIA Portal instances on all affected devices to the Siemens fixed versions indicated in SSA‑116924. Where Festo packages include embedded TIA Portal installers, update the TIA Portal installation on those devices (not just the Festo software). If you manage many devices, prioritize production engineering hosts and any MES‑PC or lab machines with remote network access.
  • Quarantine and inventory: Immediately inventory Festo Didactic systems (TP260 and MES‑PC, and any classroom/lab machines) to determine which TIA Portal versions are present. Isolate any systems that cannot be patched quickly.
  • Block/inspect file vectors: Harden email gateways and file shares to block or flag suspicious PC system configuration files and related file types used by TIA Portal. Where possible, enforce content scanning and sandboxing for attachments destined for engineering hosts.
  • Reduce exposure: Enforce strict network segmentation. Ensure engineering workstations are on isolated VLANs or subnets with firewall rules limiting inbound/outbound connectivity to only required update and build servers. Use jump hosts for remote access to engineering networks.
  • User training and policies: Stop opening untrusted project/config files on engineering hosts. Use ephemeral VM images for opening third‑party projects and restore known‑clean snapshots afterwards.
  • Detection and logging: Add monitoring for:
  • Unexpected file writes to engineering workspace directories (project, temp, tool installation path).
  • New or changed executable files adjacent to project directories.
  • Unusual process creation events originating from TIA Portal processes or their child processes on Windows hosts.
  • Incident readiness: Prepare rollback snapshots/backup images of engineering workstations so you can revert a suspected compromise quickly. Collect and preserve logs for any suspected malicious file opens (Windows Event Logs, TIA Portal logs, AV/EDR telemetry).
Detection guidance for Windows defenders​
  • Watch for these Windows events:
  • PowerShell or cmd.exe invoked by the user session hosting TIA Portal without expected justification.
  • New service installs or DLL writes under program files used by TIA Portal or engineering toolchains.
  • Creation of files in atypical locations (root of drives, %ProgramData% anomalies) immediately after opening a project file.
  • Implement EDR rules to flag:
  • Unexpected writes by TIA Portal processes to system directories.
  • Execution of unsigned binaries created within user temp directories or project folders.
  • File checks:
  • Maintain hash lists of known good TIA Portal binaries and compare after any suspicious activity.
  • Quarantine and analyze any incoming PC system configuration file from outside vendors in an isolated sandbox before delivery to production engineering hosts.
Long‑term remediation and supply‑chain considerations​
  • Enforce a software bill of materials (SBOM) and track bundled third‑party applications shipped with vendor hardware (Festo devices often bundle third‑party engineering tools — track their versions).
  • Require vendors to clarify which third‑party products are installed on delivered hardware and the update mechanism for those tools. If vendors ship installers, ask for instructions to remove or update bundled toolchains.
  • For training labs and classrooms, adopt golden image practices and immutable provisioning: after a lab session, revert to a signed baseline image rather than allowing persistent, uncontrolled file exchange on the host.
Critical analysis: strengths and gaps in the public advisories​
Strengths​
  • Vendor coordination exists. Siemens published SSA‑116924 with technical details and mitigation steps; Festo coordinated and published advisories for Didactic products that package TIA Portal. That coordination is good for downstream users to map vendor fixes to delivered hardware.
  • CVE and public tracking are in place. The vulnerability has a CVE and NVD entries, which helps organizations maintain risk records and patch tickets.
Weaknesses / risks​
  • Version mapping ambiguity for bundled packages. When vendors bundle a third‑party product (like TIA Portal) in hardware, it’s easy for organizations to miss the need to update the third‑party product. Festo’s advisory calls this out but operational teams often assume vendor‑shipped images are current. The risk is a false sense of security.
  • CVSS / scoring discrepancies. As noted, different trackers show slightly different scores (7.3 vs 7.8). That divergence affects prioritization and should be reconciled by risk owners using the vendor/NVD vector as the baseline.
  • Detection maturity gaps. Many organizations lack monitoring of engineering workstations at the same level as servers. EDR placement, log retention, and network segmentation are often weaker for lab / training systems — making exploitation easier and detection slower.
Unverifiable or ambiguous claims​
  • Any assertion that this specific CVE has been used in the wild against Festo Didactic customers was not substantiated in public advisories. Public trackers and Siemens do not report confirmed exploitation of this CVE in targeted attacks as of the latest vendor/NVD updates. Treat claims of active exploitation cautiously unless supported by forensic evidence.
Actionable playbook for Windows/IT teams (step‑by‑step)​
  • Inventory: Identify all hosts that have TIA Portal installed, including Festo MES‑PC units and TP260 training panels. Record TIA Portal major/minor version and update level.
  • Patch: Apply Siemens’ fixes from SSA‑116924 to every affected host. Prioritize production engineering hosts first.
  • Isolate: For hosts that cannot be patched immediately, place them in a restricted VLAN with firewall rules preventing inbound file transfer services and limiting outgoing connections.
  • Harden mail/file transfer: Block or detonate attachments of TIA Portal file types in sandboxed environments. Require file delivery via secured ticketing or managed file transfer, not casual email.
  • Monitor: Deploy EDR rules described above; set high‑priority alerts for suspicious file writes and unsigned binaries in engineering directories.
  • Verify: After patching, run integrity checks of TIA Portal binaries and engineering project files; compare to pre‑patch backup images.
  • Train: Educate engineers and trainers to treat unsolicited project/configuration files with suspicion; require verification of provenance before opening on an engineering host.
CVE‑2023‑26293 is a significant path‑traversal vulnerability in Siemens TIA Portal that became operationally relevant to Festo Didactic customers because Festo devices shipped with vulnerable TIA Portal installers. The technical risk is clear: a malicious configuration file, when opened by an engineer, can create/overwrite files and potentially lead to code execution. The fix is straightforward in concept — update TIA Portal to the Siemens‑published patched updates — but operational execution requires careful inventory, vendor‑aware patching of bundled products, and strengthened controls around how configuration and project files are exchanged in engineering and training environments. For organizations responsible for Windows engineering workstations and Festo Didactic deployments, the immediate priorities are: inventory affected devices, apply Siemens’ fixes, isolate or restrict unpatched hosts, harden file delivery paths, and implement detection rules focused on anomalous file writes by engineering toolchains. These measures close the most likely exploitation paths and buy time to remediate at scale while maintaining training and production continuity.
(Verification notes: Key technical claims in this article were cross‑checked against Siemens’ SSA‑116924 advisory and the NVD/CVE entries for CVE‑2023‑26293; Festo’s product advisory and CSAF mapping were used to translate the vendor fix into the specific affected Festo Didactic devices and packaging details. Where downstream trackers differ on scoring, rely on the vendor/NVD vector until reconciled.
