A sleek, futuristic device glows blue and red under ambient lighting on a reflective surface.
Hitachi Energy Relion Devices: Urgent Security Patch Required​
A recent advisory has put the spotlight on a critical vulnerability affecting Hitachi Energy’s Relion series—namely, devices within the Relion 670/650/SAM600-IO families. For those working in and around industrial control systems, especially where Windows-based management tools are part of the environment, this vulnerability underscores the need for urgent attention and robust cybersecurity practices.
Overview of the Vulnerability​
Hitachi Energy has disclosed a vulnerability related to the Improper Handling of Insufficient Privileges (CWE-274). In simple terms, the flaw resides within the product’s database schema. Its exploitation could allow an attacker, who has already acquired valid user credentials or intercepted session tickets, to escalate their privileges. Through the proprietary Open Database Connectivity (ODBC) protocol—communicating over TCP port 2102—the attacker can manipulate a database table, thereby bypassing security controls enforced by the product.
Two scoring systems have evaluated this vulnerability:
  • CVSS v4 Base Score: 8.6
    This score reflects the ease of remote exploitation with low attack complexity against the system, emphasizing its severe potential impact.
  • CVSS v3 Base Score: 7.2
    Despite being slightly lower, this rating also categorizes the vulnerability as high-risk.
Note: The dual scoring approach demonstrates the evolving nature of vulnerability assessments and aids organizations in prioritizing remediation steps.
Key Points:​
  • Vulnerability Type: Improper handling of insufficient privileges
  • Attack Vector: Remote exploitation via a network-accessible proprietary ODBC protocol
  • Implications: Unauthorized modification and potential for permanent device disablement
  • Critical Target: Industrial control systems in the energy sector
Affected Devices and Versions​
The advisory meticulously lists all affected product versions. Organizations using Hitachi Energy’s Relion series—whether in energy generation, transmission, or even in control systems interfacing with Windows environments—should perform immediate checks to determine their version status. Here is a summarized breakdown:
  • Relion 670/650 Series:
  • Affected versions include Version 2.2.0 (all revisions) and Version 1.x series with varying limits.
  • Relion 670/650/SAM600-IO Series:
  • For example, Version 2.2.1 is affected up to revision 2.2.1.8.
  • Other Versions:
  • Additional impacted revisions include 2.2.2 (up to 2.2.2.5), 2.2.3 (up to 2.2.3.4), 2.2.4 (up to 2.2.4.3), and 2.2.5 (up to 2.2.5.1), among others.
The precise version details underscore that this is not an isolated issue but a widespread vulnerability across many iterations of the product line. Given the scale, any organization integrating these devices into their control systems—and by extension, their IT networks—needs a rapid inventory and assessment.
Technical Breakdown​
How Does the Vulnerability Work?​
At its core, the vulnerability is a classic case of insufficient privilege handling. Here’s how the attack chain typically unfolds:
  • Credential Compromise:
    An attacker first needs to gain access to legitimate user credentials or intercept a session ticket.
  • Exploitation via ODBC Protocol:
    With these credentials, the attacker uses the proprietary ODBC protocol (listening on TCP port 2102) to interface with the database schema.
  • Privilege Escalation:
    By manipulating specific database tables, the attacker can escalate privileges, rendering existing security controls ineffective.
  • Consequences:
    Post escalation, an attacker may modify configuration settings or disable the device permanently.
Critical Factors:​
  • Attack Complexity:
    The vulnerability allows exploitation through a low complexity attack, making it more accessible to threat actors.
  • Remote Exploitability:
    The remotely exploitable nature increases the risk profile, particularly in environments where remote management is standard.
This vulnerability is a wake-up call that even specialized industrial equipment can have oversights that expose a network to significant threats, especially when integrated with broader IT infrastructures, including Windows-based systems for management and monitoring.
Mitigation Strategies​
Hitachi Energy, along with cybersecurity authorities like CISA, has recommended immediate mitigation strategies to shield systems from this vulnerability. If your organization relies on these systems, consider the following actions:
Immediate Patch Recommendations​
  • Relion 650 & SAM600-IO Series, Version 2.2.1:
    Upgrade to Version 2.2.1.8.
  • Relion 670 Series, Version 2.2.2:
    Upgrade to Version 2.2.2.5.
  • Relion 670 Series, Version 2.2.3:
    Upgrade to Version 2.2.3.5.
  • Relion 670/650 Series, Version 2.2.4:
    Upgrade to Version 2.2.4.3.
  • Relion 670/650/SAM600-IO Series, Version 2.2.5:
    Upgrade to Version 2.2.5.2.
  • Older Versions (e.g., Relion 670 series Versions 2.1.0, 2.0.0; Relion 650 series Versions 1.1, 1.2, etc.:
    Follow the prescribed version-specific upgrade paths or refer to general mitigation advice where an upgrade isn’t directly available.
Network and Operational Defenses​
  • Segregate Network Infrastructure:
    Limit connectivity between process control networks and enterprise or Internet-facing networks.
  • Restrict ODBC Usage:
    Given that the vulnerability is exploited via the ODBC protocol, restrict its use to communications strictly within the substation or local control domain.
  • Implement Firewall Rules:
    Only allow essential ports and protocols, specifically ensuring that TCP port 2102 is not exposed beyond the internal network.
  • Physical and Operational Security:
    Industrial control systems should be physically secured and not accessible by unauthorized personnel. Ensure that portable devices or removable storage media are thoroughly scanned before connecting to control systems.
What Windows Administrators Should Know​
Although this advisory is centered on industrial control systems, many Windows-based systems interface with such equipment for monitoring and management. Windows network administrators should:
  • Assess if any ICS tools or dashboards they manage are connected with these devices.
  • Review firewall configurations to ensure that sensitive protocols like ODBC are not inadvertently exposed.
  • Consider employing network segmentation and role-based access control (RBAC) to minimize attack surfaces.
These steps echo broader cybersecurity best practices that are relevant regardless of the operating system involved, providing a layered defensive strategy that is essential in today’s hybrid environments.
Broader Implications and Industry Analysis​
The Convergence of IT and OT Security​
The discovery of this vulnerability in industrial control products highlights a long-standing challenge: the convergence of traditional IT (often Windows-based) and operational technology (OT). As these networks become increasingly integrated, a vulnerability in an OT device can have far-reaching implications. Organizations are now urged to:
  • Implement Defensive-in-Depth Strategies:
    This strategy involves multiple layers of defense, ensuring that if one security control fails, others are in place to prevent a breach.
  • Perform Regular Vulnerability Assessments:
    Periodic audits of both IT and OT systems can uncover overlooked vulnerabilities before they become exploited.
  • Promote Cross-Department Collaboration:
    IT, OT, and cybersecurity teams must work in tandem to ensure that security measures are coherent across all segments of the network.
Learning From the Past​
Historically, vulnerabilities in specialized devices such as industrial control systems have often received less scrutiny compared to mainstream IT products. However, as witnessed with recent cybersecurity incidents, this oversight can have drastic consequences. The current advisory is a reminder that no system is too niche to be scrutinized under modern cybersecurity standards.
Expert Commentary​
Insider analysis concurs that effective mitigations are not solely reliant on patches. Instead, an organization’s overall security posture—including network design, access controls, and continuous monitoring—plays an equally vital role. Cybersecurity experts emphasize that:
  • Patches must be accompanied by proactive monitoring.
    Administrators should incorporate systems that detect anomalous behavior indicative of privilege misuse.
  • User education is key.
    Training staff to recognize suspicious activity and follow strict security protocols can significantly reduce risk.
These insights illustrate that while the immediate goal is to patch the vulnerability, the long-term solution involves cultivating a resilient security culture.
The vulnerability affecting Hitachi Energy’s Relion devices serves as a critical reminder: in our interconnected world, the security of industrial control systems is as important as that of any Windows workstation or server. With remote exploitability and low attack complexity, the flaw demands immediate attention. Organizations using these devices should apply the recommended updates without delay and review their overall network security measures.
For Windows security administrators, this is a clarion call to examine all points of interface between IT and OT systems. Ensuring that firewalls, access controls, and network segmentations are rigorously enforced can prevent unauthorized access and mitigate potential damage.
Stay vigilant, perform regular audits, and always keep your systems updated—not only to safeguard your Windows infrastructure but also to protect any industrial control assets intertwined with your operations.
In Summary:
  • Vulnerability: Improper handling of insufficient privileges in Hitachi Energy’s Relion series.
  • Exploitation Path: Remote attack via ODBC protocol on TCP port 2102.
  • Severity: High (CVSS v4 score of 8.6), highlighting the urgent need for patching.
  • Mitigation: Immediate firmware updates and network security enhancements are critical.
  • Relevance for Windows Users: Cross-network integrations call for comprehensive security strategies that span IT and OT.
By staying informed and proactive, organizations can ensure that both their Windows systems and industrial control environments remain secure against evolving threats.
