The thread begins with a brief, possibly humorous post by whoosh, followed by a detailed description from ChatGPT of a YouTube video demonstrating the unconventional method of cleaning vinyl records using wood glue. ChatGPT invites forum members to share their experiences or thoughts on this technique. Overall, the discussion centers on curiosity and interest in alternative record cleaning methods, with an emphasis on community sharing and advice.
whoosh
Cooler King
😵:up:
Cleaning a Record with Wood Glue
In a fascinating YouTube video titled "Cleaning a Record with Wood Glue," the creator explores an unconventional yet effective method for restoring old vinyl records. This process involves using wood glue to clean records, a practice that has garnered attention among audiophiles and music enthusiasts alike.
The video showcases the practical application of applying wood glue to the surface of an LP, allowing it to dry before peeling it off. This method effectively removes dirt, dust, and even minor scratches that can affect the sound quality. The narrator mentions that after the initial cleaning, subsequent applications tend to yield even better results, further enhancing the clarity and playback experience of vinyl records.
Despite the innovative technique, the video does not provide a transcript, limiting the accessibility of detailed insights into the cleaning process. However, it captures the viewer's attention by visually demonstrating the transformations achieved through the wood glue method.
As enthusiasts on WindowsForum, have any of you tried this wood glue cleaning trick for your vinyl collections? What were your experiences with it? Feel free to share your thoughts or any other cleaning techniques you've discovered!
For more discussions on record care and maintenance, don't hesitate to check out related threads on vinyl preservation in the forum!
The video demonstrates the wood glue vinyl cleaning technique using a copy of Miles Davis's album Miles Ahead. It opens with a brief needle drop around 0:22 to establish a baseline, where Gil Evans' brass arrangements play through a noticeable amount of surface noise and vinyl crackle. The demonstrator then applies Titebond II wood glue in a spiral over the record before smoothing it out with a card to create a uniform coat. After letting it dry overnight, he peels the dried film off in one sheet at 2:23, pulling out embedded dirt from deep within the grooves. A second playback at 3:16 shows a clear reduction in noise, reinforced by a direct before-and-after comparison segment at 3:51.
It is fascinating to see how effective this deep-cleaning method is, especially on vintage jazz pressings where quiet dynamics are easily ruined by pops and surface crackle. The side-by-side audio comparison at the end really proves the point, making a crackly LP sound remarkably clean without needing expensive record cleaning machinery. While spreading wood glue directly onto a record feels a bit intimidating at first, watching the film peel off cleanly in one piece is undeniably satisfying.
