whoosh
Cooler King
:razz:
Fire-arrows! In the captivating YouTube video titled "Fire-arrows!" by Lindybeige, the host delves into the intriguing question of whether archers ever truly utilized fire-arrows in ancient and medieval battles. While these fiery projectiles are a staple in action films, reality tells a different story. The video provides an engaging exploration of the concept, blending humor with historical analysis.
The Myth of Fire-Arrows​
Contrary to what movies suggest, fire-arrows were not a practical choice for use in battle. Lindybeige articulates several reasons why these incendiary projectiles would have been ineffective. One of the key demonstrations involves the simple physics of shooting a flaming arrow. When launched from a bow, the arrow's speed and the air's turbulence would extinguish the flame almost immediately.
The Challenges of Creating Effective Fire-Arrows​
The video outlines three primary solutions that people might have considered to make fire-arrows viable:
  1. Big Fire: Assume one could create an enormous flame at the tip of the arrow, perhaps using burning pitch. While theoretically possible, this method would create logistical issues, such as burning the archer's hands or bowstring.
  2. Heating the Arrow: Using a glowing-hot arrow is another proposed method. However, the arrow’s effectiveness would be compromised as it would lose heat rapidly in flight, likely reducing its burning potential upon impact.
  3. Chemical Innovations: The potential use of chemical mixtures to create a self-sustaining fire-arrow is mentioned. While this could result in a more effective fire, the practicality in battle conditions—with a low success rate of igniting targets—makes it less than ideal.
    Practical Applications​
    The discussion transitions into the more effective use of fire-arrows during sieges or naval battles. In these scenarios, shooting a multitude of arrows could potentially create confusion and force defenders to focus on extinguishing fires instead of preparing for an attack. However, even in tales of old, the reality remained stark: the success rate of fire setting was only about 2%.
    In summary, while the romantic idea of fire-arrows paints a compelling picture in cinema, Lindybeige effectively dismantles this myth by combining scientific reasoning with historical context. Fire-arrows might have looked visually mesmerizing, but their functionality in actual warfare was largely limited and often impractical.​
    What are your thoughts on the practicality of historical weapons portrayed in films? Do you think modern filmmakers should consider these insights for greater authenticity in their portrayals? Let’s spark a discussion!
