whoosh
Cooler King
:zoned:
How to Remove Tannus Flat Proof Tires In this informative YouTube video, titled "How to Remove Tannus Flat Proof Tires," viewers are guided through various methods for safely removing Tannus Airless Tires, which are renowned for their unique, flat-proof technology. As more cyclists are turning to innovations like Tannus Tires for their durability, understanding how to handle these products effectively becomes essential.
Overview of the Video​
The presenter begins by acknowledging that some riders may want to switch their Tannus Tires to a new set of rims after significant use—up to 5,000 miles! The video outlines two primary methods for removing these tires:
  1. Using an S Tool or Wrench:
    • The first method involves utilizing an S tool or a wrench alongside a pair of snips. The bike tire is wedged between the tool and the rim, allowing the user to leverage both sides. With hands placed strategically, riders can roll the tool towards themselves to release the pins anchoring the tire to the rim.
    • This method allows for the potential reuse of both the tire and the pins, making it a more sustainable option.
  2. Cutting the Tire:
    • Alternatively, if a rider is less concerned about preserving the tire, cutting it off may be the quickest option. Using a knife or clippers, one can slice through the tire, making it easy to remove. After cutting, any remaining pins inside the rim should be extracted using pliers.
      Key Points & Tips​
      • Replacement Pins: If you plan on reusing the Tannus Tires, it's essential to obtain new pins prior to reinstallation.
      • Potential Rim Damage: Users are advised to be cautious while employing the prying method to avoid damaging their rims.
      Community Engagement​
      For those who utilize Tannus Tires, what has your experience been during installation or removal? Have you found any additional tips or tricks that worked for you? Feel free to share your thoughts or check out related topics on tire maintenance and cycling innovations! Let's discuss what gear has worked best for you in the cycling community!​
      If you want to learn more about cycling accessories or bike maintenance, be sure to check out our other threads in the Water Cooler!
