The thread begins with an unclear or cryptic post by whoosh, followed by a detailed review of the Acer Arc A770 BiFrost GPU, discussing its design, thermal performance, benchmarks, and teardown insights. The review highlights that while the GPU offers good thermal management and a unique design, its gaming performance improvements over competing cards are minimal, and noise levels at idle could be improved. Overall, the discussion underscores the GPU’s strengths in cooling and aesthetics but suggests modest performance gains, prompting user interest in the evolving Intel GPU lineup.
- Joined
- Mar 14, 2023
- Messages
- 119,002
Intel Making Moves: Acer Arc A770 BiFrost GPU Review, Thermals, & Tear-Down In a recent and detailed YouTube review from Gamers Nexus, the Acer Arc A770 BiFrost GPU is put under the microscope, offering insights into its performance, thermal management, and overall design. With the rise of Intel in the GPU market, this review focuses on how the Acer variant of the A770 stands against both its Intel Limited Edition counterpart and competing GPUs.
Overview of the Acer Arc A770 BiFrost
The video starts with a brief introduction to the unique design of the Acer Arc A770 BiFrost GPU, which features a dual cooling solution: a blower fan at the middle and an axial fan on the outer edges. The review dives into the significance of these fans, noting the innovative use of a vapor chamber for thermal management—a technology highlighted by Acer but often misrepresented in marketing claims. Key Features Highlighted:- Blower and Axial Fans: Combining these fan types aims to enhance airflow and cooling efficiency.
- Vapor Chamber Technology: Used to dissipate heat effectively, contrary to some claims that it impacts airflow.
- Thermal Testing: The reviewer emphasizes the importance of proper thermal interfaces and real-world testing over theoretical designs.
Performance Analysis
When comparing the Acer A770 BiFrost to Intel's Limited Edition card, the review shows nuanced performance metrics:- Thermals: The BiFrost recorded competitive temperatures during stress tests, with internal memory and VRM thermals faring better than on the Intel card.
- Noise Levels: The A770 BiFrost, however, struggles with noise at idle, running louder than the Limited Edition counterpart. This could be improved with a firmware update to adjust the fan curve.
Gaming Benchmarks
In actual gameplay scenarios, the performance difference between the BiFrost and the Intel LE card was marginal, showing only slight average FPS improvements across various titles:- Shadow of the Tomb Raider: Around a 4 FPS increase favoring the BiFrost.
- Final Fantasy 14: A meager gain of 2 FPS over the Intel LE.
Teardown Insights
The review concluded with a teardown of the GPU, revealing thoughtful engineering choices:- Effective Use of Thermal Interfaces: Including thermal putty on critical components, which is often overlooked by competitors.
- Ease of Maintenance: The design makes it easier to disassemble and re-assemble, which is crucial for DIY enthusiasts.
