whoosh
Cooler King
:iee:
Is Buying More RAM a Waste for Gamers? Insights from Linus Tech Tips In a recent video by Linus Tech Tips titled "Is Buying More RAM a WASTE for Gamers? (2022)," the discussion revolves around the necessity and effectiveness of upgrading RAM for gaming performance. The video addresses a common concern among gamers: "Will adding more RAM actually improve my gaming experience?"
Key Takeaways​
  • Current Gaming Standards: Gaming on 8GB of RAM is becoming less viable as games grow in complexity and require more resources. The video suggests that while some games may run adequately on 8GB, many modern titles are optimized for 16GB or more.
  • Performance Bottlenecks: Linus emphasizes that RAM is just one of several components affecting gaming performance. Even with ample RAM, other factors like CPU and GPU performance can create bottlenecks. Therefore, simply adding RAM may not yield significant improvements if other components are underpowered.
  • Game Demands: Different games have different RAM requirements. Titles that are more resource-intensive, particularly those with vast open worlds or heavy multitasking, benefit from higher RAM configurations.
  • Future-proofing: Upgrading to a more considerable amount of RAM can be seen as a future-proofing strategy. As games continue to evolve, having up-to-date hardware ensures long-term usability without needing immediate replacements.
For Windows users particularly, understanding the balance between RAM and other system components is crucial. Windows 10 and 11 systems can benefit from larger RAM configurations—especially for multitasking or professional uses like video editing and graphic design, in addition to gaming.
Recommendations​
  • Evaluate Your Needs: Before upgrading, assess your current system's performance. Tools like Windows Task Manager can help you determine if RAM usage is consistently high during gaming sessions.
  • Build Compatibility: If upgrading, ensure that new RAM is compatible with your current motherboard and meets the specifications needed for optimal performance.
  • Consider Overall Upgrades: Rather than focusing solely on RAM, users should consider the performance of their entire system. Incremental upgrades over time may provide the best experience in gaming and productivity. The video by Linus Tech Tips sheds light on why simply increasing RAM might not be the best move for all gamers, especially when other components can limit performance. It serves as a valuable resource for anyone looking to understand their system's limitations better and make informed upgrade choices. For more detailed insights, check out the video https://www.youtube.com/watch?v=H19_JKw4QN4.
