The thread begins with a brief, unclear post by whoosh, followed by a detailed review of the NVIDIA GeForce RTX 3070 Founders Edition from Gamers Nexus, discussing its performance, thermals, noise levels, power consumption, and gaming benchmarks. The review portrays the RTX 3070 as a well-rounded, high-performance GPU suitable for gamers, with notable improvements over previous models and efficient thermal and noise management. The community is encouraged to share their experiences or ask questions about upgrading, indicating a generally positive sentiment and interest in the GPU's capabilities.
whoosh
Cooler King
:zoned:
NVIDIA GeForce RTX 3070 Founders Edition Review: Gaming, Thermals, Noise, & Power Benchmarks In the latest review from Gamers Nexus, the NVIDIA GeForce RTX 3070 Founders Edition GPU is put under the microscope to evaluate its performance, thermals, noise levels, and power consumption. Released at an MSRP of $500, the RTX 3070 presents itself as a competitive option against both previous generations and AMD’s forthcoming RDNA 2 products.
Key Highlights:​
  1. Performance Analysis: The RTX 3070 boasts a robust architecture with 5888 CUDA cores, positioning it as a significant upgrade over the GTX 1070. Benchmark comparisons indicate that the 3070 holds a 37% performance lead against the 1080 Ti at 1440p, and it consistently delivers playable frame rates even at 4K resolution. Its performance demonstrates substantial gains from both the 20 series and 10 series NVIDIA cards.
  2. Thermals and Noise: The review highlights improvements in thermal management, noting that while the card operates efficiently (recording about 65 degrees Celsius in a quiet environment during stress tests), the design sacrifices some thermal efficiency for lower noise levels. At 40 dBA, the RTX 3070 is one of the quietest cards tested, which is a crucial consideration for gamers looking to minimize noise during intense gaming sessions.
  3. Power Consumption: The RTX 3070's power draw is recorded at around 227 watts under heavy load, which places it favorably against previous generation GPUs. This efficient power consumption showcases NVIDIA’s advancements in power management technology integrated within the Ampere architecture.
  4. Gaming Benchmarks: The card performs exceptionally in several titles. For instance, in Red Dead Redemption 2, it averages 123 FPS at 1080p and maintains a commendable performance at higher resolutions, solidifying its position as an excellent choice for gamers seeking to run current titles at high settings without breaking the bank.
  5. Mechanical Assembly and Design: The teardown aspect of the review presents the RTX 3070 as being well-constructed, with attention to cooling pressure distribution across its die. The varied cooling solution is notably enhanced over previous models, reflecting NVIDIA's commitment to dealing with thermal challenges effectively.
    Conclusion:​
    The NVIDIA GeForce RTX 3070 Founders Edition stands out as a well-rounded GPU suitable for both mainstream and high-performance gaming. The combination of strong gaming performance, manageable thermals, and quiet operation makes it a solid choice for gamers at the $500 price point. As the market awaits AMD's response with RDNA 2, the 3070 is poised to be a frontrunner in its category.
    Community Thoughts​
    What are your thoughts on the RTX 3070? Have any of you made the switch from older models like the GTX 1070 or even the 1080 Ti? Feel free to share your experiences or ask questions about the benchmarks if you're considering an upgrade! For more discussions and insights related to GPUs, check out the related threads in the Water Cooler section.
