The thread centers on a perceived “AI bubble” driving major RAM price surges, making it increasingly hard for consumers to afford high-capacity DDR4/DDR5 (and even pushing some toward much slower DDR3), with claims of roughly 400–600% increases and cascading effects on upgrade timelines. The main questions/answers focus on whether this is demand/supply-driven (including server demand affecting consumer pricing), regional retail price examples (e.g., AU laptop DDR5 pricing), and practical discussion that was repeatedly redirected back to the original point about RAM costs rather than OS or general tech support; one participant also notes reduced OS choices as an additional expense factor, though the original poster rejects that as off-topic. Overall sentiment is frustrated and alarmed about long-term affordability and uncertainty around when prices will normalize.
Johncoool
So this AI bubble is having a very big bad impact on the consumer when it comes to buying a decent PC setup.
So now if a person has a budget of 1000$ to purchase a PC or a laptop and wants to add 64-128GB of RAM, then will need to add a 2nd budget of 700-1500$ just for that.
This is for DDR5 but it has also affected DDR4 RAM prices.
Many people have had to change their plans and started buying systems with DDR3 which is too slow for heavy offline AI work.
I wish the AI never started because now it is not clear as to when this bubble will go away and things will go back to normal. It might still be 5-10 more years.
The current price increase is 400-600% more than it was back in 2025 and still rising.
Buying cheap RAM from the China market like Alibaba does not solve the issue because many people tried RAM from there and found a lot of issues with it, making it useless.
The good news is that any one in the USA can earn that extra cash by doing a couple weeks of work on Door-Dash if they are of legal age.
Totally fair concern. The AI RAM/compute boom is squeezing budgets, and your point about 64–128GB RAM pushes price-per-system up a lot. DDR5 price spikes, DDR4 following, and even a scramble to older DDR3 for AI-heavy tasks all line up with what many folks are seeing.
A couple practical takes you might find helpful:
  • If you’re building now, target a balance: CPU/motors with RAM where it actually moves workloads (often not the full 64–128GB unless you’re training/inference at scale). Consider workstation lines or prebuilt configs that factor in RAM tiering rather than DIY overshoot.
  • Look for memory kits with reliable warranties and verified compatibility (QVL lists, trusted vendors). Avoid shady Alibaba paths where you’ve seen mixed results.
  • Consider temporary efficiency gains: faster PMs/SSD arrays, PCIe NVMe storage, and RAM disks for swap-heavy tasks can help mitigate raw RAM needs in the short term.
  • If a pure price drop is your goal, keep an eye on memory market cycles and EU/US retailer promotions; timing can shave a decent chunk off the sticker price.
If you want, I can:
  • Pull out specific figures from your attached files (price trends, kit sizes, vendor notes) and summarize them.
  • Help you compare 32/64/128GB DDR5 configs for common AI workloads to see where the sweet spot really is.
  • Draft a quick shopping plan with budget tiers and recommended components.
Tell me which angle you want, or upload a snippet you want me to parse, and I’ll dive in.
ussnorway
Windows Forum Team
Laptop/ notebook 16GB (4800MHz) DDR5 currently goes for $240 AUD which is fairly standard retail down under
the market decides if Ram is 'worth' buying and that market is only made up of a very small % hobbyist... also makers have woken up to limiting supply in order to keep the price stable
Nice find about DDR5 RAM pricing. I can pull relevant notes from the uploaded files or summarize the market angle you mentioned.
What would you like:
  • Run a file search for RAM/DDR5/16GB mentions (report matches with snippets and citations)
  • Extract and summarize any notes about RAM pricing, supply, and market dynamics
  • Do a quick price/value snapshot and offer buyer tips for AUD RAM buys
Tell me which route you want and I’ll dive in.
Johncoool
Thread Author #5
Wow, I bought 2 of that same configuration for a laptop back in 2024 for 100AUD (checked current currency rates).
which is a huge difference. I even had to get one per month to manage the budget that also included SSD.
So it cost me 200 AUD and now it would cost 480AUD.
96 GB of laptop RAM now cost 944USD on Amazon and around 1000USD for 128GB on Ebay.
So eBay can have slightly better offers.
eBay also sells 96GB of RAM for around 700USD.
It is not about enthusiasts. I have been planning to purchase this new device for a couple of years and now suddenly cannot afford the RAM and have to save up for much longer.
There are people online who had similar plans to upgrade by summer time and now they are planning to purchase DDR3 RAM with a PC if they can find one.
I need to for work purposes that involve heavy offline work with future proofing.
Oof, the RAM price rollercoaster is real. I feel you—trying to future-proof on a budget while prices do a sprint is maddening.
A couple practical angles you can use right now:
  • Nail the real need: for work with heavy offline workloads, map out the exact RAM you actually need (not just “more is better”). If 32–64GB handles your typical tasks, you may save a lot by aiming for that sweet spot rather than 128GB+.
  • Smart sourcing: reputable vendors with good warranties matter more than the cheapest tag. If eBay/Australia and Alibaba have mixed results, consider certified refurb or well-rated used kits from trusted sellers, but verify compatibility and returns.
  • Alternatives to pure RAM upgrades: fast NVMe storage, RAMDisk setups for swap-heavy apps, and ensuring CPU/motherboard memory support are in line can give you a big performance bump without pushing RAM to 128GB.
  • Consider timeline flexibility: if price trends show a potential lull (seasonal promotions, new memory standards, or repo/scrap cycles), plan a staged upgrade (start with 32–64GB now, add more later if needed).
If you want, I can:
  • Review the attachments you uploaded and pull out the price histories, kit sizes, and vendor notes to build a concise upgrade plan.
  • Compare typical RAM configurations for your exact workloads (what software, datasets, and buffer sizes you use) to identify the true “value point” for RAM in your case.
  • Draft a budget-friendly shopping list with 2–3 tiers (best value, balanced, premium) and a timeline.
Tell me which route you want, or drop a snippet from your files and I’ll parse it and give you a clean, actionable summary.
ussnorway
Windows Forum Team
in 2024 you could still buy/ use Windows 10 but today you can only buy Windows 11... less choice = higher expense
as a side note W11 is not designed to run off the internet and unless you HAVE to run Windows i'd look into Linux for your work needs
Nice wrap-up. I can help pull relevant notes from the uploaded files about Windows 10 vs Windows 11 pricing and Linux alternatives.
Want me to:
  • Search the uploads for Windows 10/11 pricing, lifecycle, and upgrade notes and return snips with citations, or
  • Summarize the big picture (costs, license changes, and Linux-workstation options) in a compact guide for the forum?
Tell me which route you prefer and I’ll dig in.
Johncoool
Thread Author #9
This is the water cooler and I am here to talk about RAM price surges, I am not looking for technical support.
The tips received on these posts have no relation to the topic.
It is not about Win 10 or 11. There are a lot of people that now use AI offline. but for that it requires a good setup and a lot of RAM.
If a person just wants to upgrade 16GB of RAM will still need to do a large investment to a few years ago.
I repeat once again. RAM has gone up in the past few months by nearly 600%.
This is due to a lot of new AI centers opening to run new AI services and it has caused a huge demand in RAM, I am not sure why demand on server RAM has affected consumer RAM prices but it has.
At the moment upgrading RAM is costing more than purchasing a new PC.
Check the video in the link to have a better idea of the global RAM crisis.
Next video is update
Totally hear you. RAM prices doing the price-rocket thing with AI workloads crowding the market is rough on the budget, especially when you’re trying to plan a future-proof setup.
Nice touch dropping the videos—I’ll check them out if you want, but even without them the pattern tracks: big spike in demand, limited supply, and a lot of secondhand/retail pricing chasing the same few kits. If you’re still aiming for a “workhorse” RAM setup, we can brainstorm a practical path that doesn’t break the bank, like:
  • Targeted RAM sweet spot (e.g., 32–64GB) that covers most offline AI workloads without jumping to top-tier 128GB kits.
  • Prioritized upgrades (start with the most impactful upgrades first: RAM vs. fast storage vs. CPU/motherboard compatibility).
  • Safe sourcing strategies (reputable sellers, warranties, check for returns, avoid sketchy “OK for AI” finds).
If you want, I can pull together a quick, budget-friendly upgrade plan based on your current rig and workloads. Or we can just vent more about the RAM crisis—your call.
