This thread discusses the power supply requirements for the NVIDIA RTX 4090, highlighting varying recommendations from manufacturers—ranging from 850W to 1200W—and emphasizing the importance of PSU quality and compatibility, especially regarding PCIe Gen 5 connectors. The conversation notes that while higher wattages are suggested for overclocking and demanding setups, many users with balanced systems may operate effectively on an 850W PSU. Overall, there's an ongoing debate about necessary power supplies, with users sharing their experiences and considerations for upgrading.
whoosh
Cooler King
:iee:
RTX 4090 Power Supply Requirements The recent YouTube video titled "RTX 4090 Power Supply Requirements" delves into crucial considerations for those looking to upgrade to NVIDIA's latest flagship graphics card. One key takeaway from the video is the debate around the necessity of a 1200W power supply for the RTX 4090. The host reflects on personal concerns regarding their current 850W PSU, weighing whether it will suffice for optimal performance or if an upgrade will be essential.
Power Supply Recommendations​
The video emphasizes varying recommendations from different manufacturers. NVIDIA itself suggests an 850W PSU for their Founders Edition, while some partners like Palit advocate for a hefty 1200W. The host points out that power supply quality is just as important as wattage—transient peak performance can vary dramatically based on the PSU's construction.
PCIe Connection Considerations​
For users keen on ensuring compatibility, the video highlights the importance of PCIe connectors. The RTX 4090 utilizes a newer PCIe Gen 5 connector, which might require multiple 8-pin connections from older PSUs. Viewers are advised to check their current power supply’s configuration to ensure compatibility with the RTX 4090, especially if overclocking is a consideration.
Why Higher Wattages?​
The recommended wattages often cater to users who plan to overclock their systems, especially pairing a 4090 with power-hungry CPUs like the Intel 12900K. The host notes that while power recommendations seem inflated, they might be aimed at covering warranty liabilities rather than reflecting typical usage scenarios. Readers are encouraged to consider their unique system specifications when evaluating power needs.
Case Compatibility​
Physical compatibility is also addressed—ensuring that the RTX 4090 fits in your case is paramount. The increased size and cooling requirements can pose challenges, especially with various models differing in design.
In summary, while the recommendations leans towards higher wattage PSUs for stability and performance, many users running a balanced system (like a Ryzen 5600X) can operate smoothly on an 850W supply, assuming quality components are used. As technology evolves, PSU requirements will also shift, so this discussion is timely—especially with the upcoming PCIe Gen 5 specifications on the horizon. What are your thoughts on the PSU requirements for the RTX 4090? Have you considered upgrading your power supply, or do you think you're safe with your current setup? Share your experiences below!
