whoosh
Cooler King
:iee:
SERIOUSLY?? MORE bad news for NVIDIA's 40 Series... In recent discussions surrounding NVIDIA's 40 Series graphics cards, particularly their compatibility with power supplies, concerns have been raised about potential risks associated with using older power supplies. In a YouTube video that dives into this topic, the host highlights significant issues that could arise when users attempt to run NVIDIA’s latest offerings with non-ATX 3.0 compliant power supplies.
Key Points from the Video​
  1. Potential Fire Risks: The video explains that using older power supplies without proper adapters can lead to serious safety concerns, including the risk of fire due to overcurrent conditions. The new ATX 3.0 specification includes data communication between the power supply and the graphics card, which helps regulate power draw based on the power supply's capabilities.
  2. Adapter Issues: It turns out that the new 12VHPWR connectors used by NVIDIA's 40 Series cards are designed to work ideally with ATX 3.0 power supplies. Using adapters that don’t support communication can lead to situations where the graphics card attempts to draw more power than what the supply can handle, creating the potential for overheating and damage.
  3. Design Flaws: The host mentions that the new power connectors are fragile and rated for only 30 cycles of plugging and unplugging. With heavy use, especially during cable management, the likelihood of damaging these connectors increases significantly, raising further concerns about long-term reliability.
  4. Recommendations: For users planning to purchase high-end models like the 4090, the recommendation is clear: invest in a robust 1000 to 1200 watt ATX 3.0 power supply to ensure safety and compatibility. This not only mitigates risks but also enhances the stable operation of the graphics card under load.
    Community Implications​
    With the increase in power demands from next-generation graphics cards, it is now more important than ever for users to be aware of their power supply capabilities. The discussion about adapting older systems to support newer technology is not just relevant to tech enthusiasts but should be heeded by anyone considering an upgrade. Engaging with this topic is critical, especially as more users transition to these powerful GPUs. What have your experiences been with power supplies and graphics cards? Have you encountered any issues, or do you have different insights? Let’s share thoughts and solutions below! Related Threads:
    • Have you upgraded your power supply for your new GPU?
    • What are your thoughts on NVIDIA's 40 Series cards?
    Stay informed and make sure your setup is ready for the future!
