The thread begins with a brief post from whoosh, which appears to be an image or a simple mention, and then a detailed summary from ChatGPT outlining the "best PC builds" as of early 2024, based on a recent video. The summary covers three PC build categories—budget, mid-range, and premium—highlighting key components, approximate costs, and targeted performance levels for gaming. Overall, the discussion emphasizes the latest hardware options and encourages viewers to share their opinions and experiences with the recommended builds, catering to both new and experienced PC enthusiasts.
whoosh
Cooler King
:iee:
The BEST PC Builds RIGHT NOW! 😃 (December/January 2023) In the latest video from PC Centric, a deep dive into the best PC builds currently available is presented, focusing on a range of budgets—from economical setups to high-end gaming machines boasting the powerful RTX 4090 graphics card.
Overview​
The video starts with the host, highlighting the significant changes in hardware options recently released by Nvidia, AMD, and Intel, reflecting on the evolving landscape for PC builders. The discussion revolves around three distinct budgets: a budget build, a mid-range option, and a top-tier powerhouse.
Budget Build​
For the budget-friendly option, the host recommends prioritizing a graphics card, suggesting the RTX 2060 as a solid choice given its capabilities for 1080p and some 1440p gaming. Moving on, the Intel i3-12100F is recommended due to its performance per price point, although considering future-proofing, planning for an eventual upgrade might be wise. The overall estimated cost for this build lands around £605, making it quite appealing for entry-level gamers. Key components include:
  • Graphics Card: RTX 2060 - ~£180
  • CPU: Intel i3-12100F - ~£123
  • Motherboard: Micro ATX B660 - ~£140
  • RAM: 16GB DDR4 - ~£56
  • Storage: Crucial P3 SSD - ~£43
  • Power Supply: 600W - ~£43
Mid-Range System​
The mid-range options feature the RTX 3060 Ti paired with the Ryzen 5 5600X. This combination maximizes value while providing excellent performance across contemporary gaming titles. The estimated cost here is approximately £1146. Components recommended include:
  • Graphics Card: RTX 3060 Ti - ~£430
  • CPU: Ryzen 5 5600X - ~£170
  • Motherboard: B550 - ~£150
  • Case: H510 Flow - ~£90
  • RAM: 16GB DDR4 with RGB - ~£75
  • Power Supply: 650W - ~£60
Premium Build​
Lastly, the premium setup showcases the RTX 4090 paired with an Intel i7-13700KF for users seeking top-tier gaming performance. However, this comes at a whopping total of around £4163, with the major components including:
  • Graphics Card: RTX 4090 - ~£2000
  • CPU: Intel i7-13700KF - ~£300
  • Motherboard: High-end options around £400
  • RAM: 32GB DDR4 - ~£120
  • Storage: 2TB SN770 - ~£120
  • Power Supply: 1000W - ~£150
The video wraps up with an encouragement for viewers to share their thoughts on the builds showcased and whether they feel the chosen components are appropriate for each budget. The guide provides valuable insights not only for newcomers but also for seasoned builders looking to upgrade their systems intelligently. Whether you're aiming for budget-friendly gaming or an extravagant build, there are options for every gamer out there. What do you think of these builds? Do you have experiences with any of the recommended parts? Share below!
