The forum thread begins with an unclear post from whoosh on October 17, 2022. Shortly after, a detailed review from ChatGPT on September 12, 2024, discusses the Asus RTX 4090 TUF Gaming OC graphics card, highlighting its robust build quality, effective thermal performance, and overclocking potential, despite some concerns about memory cooling efficiency. The review overall presents the card as a high-end option with strong design and performance, encouraging user discussion about their experiences and opinions on its design and thermals.
whoosh
Cooler King
:iee:
Asus RTX 4090 TUF Gaming OC Review, Thermals, Power & Overclocking In this video, Steve from Hardware Unboxed offers a detailed review of the Asus RTX 4090 TUF Gaming OC graphics card, focusing on its build quality, thermal performance, power delivery, and overclocking potential. The review emphasizes the card's impressive design and construction, particularly highlighting its minimal use of plastic components. The aluminum fan shroud not only looks stylish but is claimed to enhance the card's structural integrity and heat dissipation.
Key Features and Design​
The RTX 4090 TUF Gaming OC measures 348mm in length, 150mm in height, and 73mm in width, translating to a hefty weight of 2313 grams. This design incorporates a robust support pillar to mitigate GPU sag, though Steve notes that the support mechanism could be improved for a more permanent solution. The card features three 105mm fans that optimize airflow by spinning in alternating directions to reduce turbulence. A standout aspect of this model is its RGB lighting, which is customizable via Asus' Armory Crate software, adding an aesthetic appeal for gamers.
Thermal Performance​
During testing with Hitman 3 at 4K resolution, the hotspot temperature peaked at 77°C, with the average GPU temperature hitting 67°C. Even under maximum overclocking conditions, where the power consumption rose to 495 watts, the temperatures remained manageable, demonstrating the card's efficiency in heat management. However, the review raises concerns over the memory cooling, noting a significant increase in memory temperature compared to competing models, primarily due to the use of thicker thermal pads. While these pads ensure a decent performance, they are not as effective as thinner alternatives in dissipating heat from memory chips.
Overclocking Capabilities​
With a maximum adjustable power limit of 520 watts, the RTX 4090 TUF showed promising overclocking results but is limited by Nvidia’s restrictive guidelines on voltage adjustments. This results in only a modest increase in performance across similar high-end models.
Final Thoughts​
Overall, Steve concludes that the Asus RTX 4090 TUF Gaming OC is a top contender among RTX 4090 models, noted for its outstanding aesthetics and build quality, despite some weaknesses in memory cooling. For anyone considering this card, it stands as a highly recommended choice, blending performance with high-end design expectations .​
What do you think of the design and thermals of the RTX 4090 TUF? Have you had any experience with other models? Share your thoughts!
