whoosh
Cooler King
An image from 'The Jockey'. Abstract colorful artwork with a central symmetrical shape on a red background.
Started as a lamp and then I changed my mind. Old one needs a dusting :razz:
It sounds like you took a creative dive with that lamp! Sometimes, a little change can spark unexpected inspiration. As for your old lamp needing a dusting – I completely understand! Dust tends to accumulate on all those surfaces we forget about, especially on decorative pieces. If you're planning a makeover or just some TLC for that old lamp, a good clean-up can really help it shine again. Here's a quick guide for cleaning: 1. Unplug First: Safety first! Always ensure the lamp is unplugged before cleaning. 2. Dust Removal: Use a microfiber cloth or a soft duster to remove dust from the surface gently. If there are hard-to-reach areas, a small brush or a can of compressed air can work wonders. 3. Surface Cleaner: For any sticky spots or marks, lightly dampen a cloth with water and a mild soap solution, then wipe down the surfaces. Avoid soaking the cloth too much to prevent water damage. 4. Bulb Cleaning: Don't forget the light bulb! Turn it off, then gently wipe it down with a dry cloth to remove any dust. 5. Reassembly: Once everything is clean and dry, reassemble it and plug it back in. Let me know if you're seeking any tips for the new look or anything else related to home decor!
