whoosh
Cooler King
:eek::shocked:
Tree Job from HELL In a gripping YouTube video titled "Tree Job from HELL," the challenges of a hazardous tree removal are vividly showcased by arborist Blair Glenn. This video follows up on the Chimney Oak situation, marking it as one of the top five hardest tree jobs Glenn has ever undertaken. The challenges faced during this job highlight the risks and complexities that professionals encounter in arboriculture.
Job Overview​
The job involves a large Live Oak tree that has uprooted and is precariously leaning against a chimney. The weight of the tree is estimated between 30 to 50 tons, with significant concerns about the stability of both the tree and the crane used to stabilize it. The workers worry that the tree might roll or fall, potentially causing severe damage. From the outset, there are discussions about the best methods to stabilize the tree, considering various factors that could complicate the task.
Key Challenges​
The video presents an array of difficulties ranging from equipment failures to precarious positioning. Initially, a crane is deployed to alleviate some of the burdens, but the crane company fails to return the following day, forcing Glenn and his team to devise alternative plans, which included building an A-frame structure for added stability. The crew must handle tonnage and heights carefully while making cuts to remove the tree without further risking the nearby structures.
Innovative Solutions​
As they progress, Glenn and his team demonstrate resourcefulness in their approach. They utilize bucket trucks and create an A-frame to support the tree's weight, learning as they go. A memorable moment occurs when they observe water seeping from the tree, illustrating how cutting into it changes the internal pressure and water distribution. The tension escalates with concerns over the tree's movement and the structural integrity of the chimney it's leaning against. The workers must constantly adjust their tactics based on the tree's shifting weight and ensure that safety remains their top priority.
Conclusion & Reflection​
The video not only showcases the physical demands of the job but also delves into the psychological pressures faced by the crew as they assess risks and make quick decisions. By the end, viewers witness the successful stabilization and removal of the tree, underscoring the community's resilience and teamwork in the face of unforeseen challenges. This intricate ballet of engineering, skill, and bravery is a testament to the hard work that goes into tree removal and the unpredictable nature of working in arboriculture. For those interested in the behind-the-scenes decisions of such high-stakes jobs, this video is an enlightening watch. Have you ever witnessed a risky tree job like this? What challenges did the professionals face? Share your thoughts and related experiences below!
