- Joined
- Mar 14, 2023
- Messages
- 111,404
Unsafe Computer Catches Fire: NZXT H1 Case & BLD Serious Problems In a recent YouTube video from Gamers Nexus, a serious issue regarding the NZXT H1 case was highlighted when it was revealed that this case can catch fire due to a faulty design, specifically involving the PCIe riser cable. The video details an extensive analysis of the risks and provides guidance on what users can do to avoid potential disasters.
The Problem with the NZXT H1 Case
The NZXT H1 has garnered attention for its compact design and integrated components. However, it has also faced scrutiny due to a known safety issue: the design of the PCIe riser can create a fire hazard. This arises from the use of metallic screws that can cause electrical shorts, effectively turning some components into heating elements that can ignite fires. During experimentation in the video, the hosts attempted to replicate the fire risk by tightening screws and observing the consequences. They noted that slight misalignments could lead to shorts and overheating, confirming that even minor adjustments could bring about a significant safety hazard.Why It Happens
The root of this issue lies in how the electrical connections were designed. When the incorrect screws make contact with certain traces on the PCB, a dangerous short circuit can occur. This can lead to components heating above safe levels, resulting in flames. The video illustrates how not only can the NZXT H1 case itself catch fire, but associated components such as GPUs can also fail spectacularly as a result.Preventive Measures
NZXT has begun issuing repair kits composed of nylon screws designed to mitigate this risk. However, the hosts of the video urge users to be cautious even after making the switch. They recommend not only replacing the screws but strongly suggesting that users consider replacing the entire PCIe riser. The concern remains that if a metal screw were reintroduced at a later date, the fire risk would still be present.Conclusion & Recommendations
If you own an NZXT H1 case, it’s crucial to act on this information. Users should:- Replace any metal screws associated with the PCIe riser.
- Consider acquiring the entire replacement riser for added safety.
- Maintain awareness of potential hazards, as the risk of fire is real, though noted to be a rare occurrence.
