whoosh
Cooler King
Velka 7 - The Brutally Small RTX 3070 Build! In a recent YouTube video titled "Velka 7 - The Brutally Small RTX 3070 Build!", the presenter delves into the innovations and capabilities of the Velka series of PC cases, highlighting how they push the limits of small form factor (SFF) computing. These cases, particularly the Velka 7, are engineered to house powerful components in remarkably compact spaces, all while maintaining a focus on functionality and cooling.
The Velka 7 Case Overview​
The Velka 7 is noted for its impressive specifications despite its small size, boasting a total volume of just six liters. This model allows for graphics cards up to 289 mm in length and a CPU cooler clearance of 47 mm, making it suitable for high-performance components. The build quality has been improved with thicker panels compared to earlier versions, competing with more established high-quality aluminum cases in terms of sturdiness and design. The video captures the building process, emphasizing the unique layout required for the PCIe riser cable, which, while unconventional, does not compromise signal performance. The transition of I/O ports from the top to the rear of the case represents a significant design update, optimizing airflow and accessibility. However, users are advised about the limitations regarding HDMI ports, particularly with new 4K TVs, while display performance remains robust with DisplayPort connections.
Build Specifications​
In the build highlighted in the video, an RTX 3070 Founders Edition graphical card and an AMD Ryzen 5800X processor were used. The presenter notes that while the RTX 3070 is compact, the thermal design can be a limitation within the small confines of the Velka 7. The airflow is well thought out, but users might contend with higher fan speeds and noise levels. By applying undervolting techniques using MSI Afterburner, performance and noise can be significantly improved, a tip noted for those unfamiliar with under-volting strategies.
Performance Insights​
One of the standout features of this build is its ability to perform at an impressive level, managing 1440p gaming despite the compact nature of the setup. The temperatures recorded remain within acceptable limits for both the GPU and CPU, although the Ryzen 5800X's heat generation can be taxing in such a confined space. The video serves as an excellent guide for anyone looking to build a similarly compact system, especially those needing portability for travel or simple desk setups. The Velka 7 demonstrates that powerful gaming setups can fit in a surprisingly small footprint, making it ideal for gamers and professionals on the go.
Community Discussion​
For those interested in compact builds or sharing their experiences with similar setups, what are your thoughts on the Velka 7? Have you explored other SFF cases, or do you have tips on optimizing airflow in tight spaces? Join the discussion below! This video serves as a great resource, and for those considering such a build, the insights gleaned here can help ensure a smoother construction process and optimized performance. Be sure to check back for more content on SFF builds and stay tuned for future updates on similar cases!
