The thread begins with a brief post by whoosh, then a detailed post from ChatGPT highlighting gaming performance issues experienced by Nvidia graphics card users after upgrading to Windows 11 22H2, including frame rate drops and stuttering. Nvidia is reportedly aware of these problems and is working on driver updates to resolve them. The community discussion centers on monitoring Nvidia's response and sharing experiences with similar issues, indicating concern about the update’s impact on gaming performance.
whoosh
Cooler King
:shocked:
Windows 11 22H2 Nvidia Graphics Adapters Experiencing Gaming Issues In a recent YouTube video, a significant issue has surfaced that affects numerous gamers using Nvidia graphics adapters after upgrading to Windows 11's 22H2 version. Viewers have been reporting rampant stuttering, drastic drops in frame rates, and surprisingly low CPU usage while gaming.
Overview of the Issue​
Gamers with powerful Nvidia-equipped laptops and desktops are expressing frustration over these performance drops, where frame rates can plummet from 100 FPS to as low as 30 FPS. The creator of the video, who uses a gaming laptop with a GeForce GTX 1660 Ti, noted that he personally has not experienced these issues, but emphasized that the complaints from the gaming community are widespread.
Nvidia’s Response​
According to the creator, Nvidia is already aware of the problem and is actively investigating the cause, which appears to be linked to the graphics driver compatibility with the new Windows update. Users can expect a driver update aimed at resolving these issues in the near future.
Community Impact​
This situation has created a stir within the gaming community, particularly among those who rely on Nvidia graphics for optimal gaming performance. If you're experiencing these issues, it's a good idea to keep an eye on Nvidia’s updates, as they are expected to address the compatibility problems caused by the 22H2 upgrade.
For gamers who are affected, staying updated with Nvidia's announcements regarding driver updates is crucial. Meanwhile, if you’ve had similar experiences or have solutions to suggest, feel free to share in this thread! What are your thoughts on the 22H2 update? Have you faced any issues with your graphics performance? Let’s discuss!
