VIDEO 2020 Content Creation PC Build - Threadripper 3960X - Zenith II Extreme - RTX 2080 Ti
whoosh
Cooler King
:cool:
2020 Content Creation PC Build - Threadripper 3960X - Zenith II Extreme - RTX 2080 Ti In this YouTube video, the creator showcases a high-end PC build specifically designed for content creation, featuring a powerful AMD Ryzen Threadripper 3960X processor. The focus is on assembling a system that can efficiently handle video editing and other intensive workloads, marking a significant upgrade from their previous setup.
Key Highlights of the Build:​
  • Processor: At the heart of this build is the AMD Ryzen Threadripper 3960X, providing a robust 24 cores and 48 threads, which is ideal for multitasking and processing heavy editing tasks.
  • Motherboard: The build utilizes the ASUS ROG Zenith II Extreme, known for its extensive connectivity options including USB 3.2 and robust networking features, which are particularly beneficial for content creators.
  • Cooling Solutions: The system is equipped with a Corsair IQ closed-loop cooler, designed to handle the large surface area of the AMD CPU, ensuring it remains cool under load.
  • Memory: 32GB of Corsair Vengeance RGB Pro RAM is included, enhancing performance and aesthetics with RGB lighting, while allowing ample memory for rendering tasks.
  • Storage: The build features PCIe storage solutions from Lexar and Seagate, providing fast data access. The addition of an expansion card allows for even more storage options, perfect for large video files.
  • Power Supply and GPU: The creator reuses an 850W power supply and the RTX 2080 Ti graphics card from their previous build, demonstrating a thoughtful approach to cost-efficiency while maintaining powerful performance.
  • Case: The choice of the Phanteks Eclipse 680X case is notable for its design, which houses all components neatly while allowing for robust airflow.
    Performance Insights:​
    Throughout the video, viewers are treated to insights into the benchmarking of the build, showcasing how this new configuration outperforms the previous Intel Skylake setup. The integration of features like USB 3.2 and high-speed internet connectivity are discussed, emphasizing their importance for video production workflows. The video also touches on the aesthetics of the build, including cable management and RGB configurations, providing a holistic view of not just performance but visual presentation as well.
    Community Engagement:​
    This build reflects a significant leap in performance for those interested in serious content creation. Users are encouraged to share their thoughts on the build, and those considering similar upgrades can gain useful insights from the creator’s experiences. If you're thinking about upgrading your own content creation setup or just love to tinker with PC builds, what components do you think are essential in your ideal system? Join the conversation below!
