A Blank Gadget Window problem with other Gadget issues, need help
Hi every1, I got a serious problem about Windows7 Gadgets.
I lose all gadgets including the original clock and cpu meters.
If I try to launch sidebar.exe, it will appear as shown in picture.
If I close this window, sidebar.exe will be terminated as well.
I've tried deleting the gadget cache but it seems not working.
Please help and I'll appriciate.
BUMP...no1 reply yet
Elmer
Hi poporange630 and Welcome to the Forum.
First thing I would do is goto C:\Program Files\Windows Sidebar\Gadgets and (if you have 64bit??) C:\Program Files (x86)\Windows Sidebar\Gadgets and see if you physically have any gadgets in there**.
I'd then go Control Panel >> Programs and Features >> Turn Windows features on or off, and check if Windows Gadget Platform is "ticked". If it is ticked, untick it. Re-boot. Do the same again, this time re-tick it. Reboot. Now see if your gadgets are showing.
HTH.
** If they are there, something has become corrupted. The second paragraphs instructions should reset them. If there is corruption I'd suggest running sfc /scannow in an elevated command prompt to check your system files integrity.
