VIDEO AMD Engineer Responds to 7900 XTX 110c Issue!
whoosh
Cooler King
:iee:
AMD Engineer Responds to 7900 XTX 110c Issue! In a recent YouTube video, an AMD representative addressed the rising concerns regarding the RX 7900 XTX and XT GPUs, particularly the troubling junction temperature (TJmax) issues that have seen reports of hotspots reaching up to 110 degrees Celsius. This has sparked discussions within the gaming community, as such temperatures can lead to throttling and negatively impact gaming performance. Key Points from the Video: 1. Temperature Concerns: The video highlights that while 110°C is technically within specification, many users are experiencing significant performance drops due to throttling. AMD is currently investigating this issue, collecting serial numbers, and trying to pinpoint if specific batches are more affected. 2. Customer Support Issues: Some users reported being denied warranty services when experiencing these temperature spikes, leading to frustration among consumers who feel their concerns are not being adequately addressed. The AMD rep mentioned that those with mechanical problems should consider returning their cards for an RMA. 3. Firmware Solutions: The potential for firmware updates to address thermal performance was discussed. However, concerns were raised that adjustments may merely downclock the GPU, limiting the auto-overclocking capabilities rather than providing a true fix. 4. Cable Issues: Interestingly, some complaints about high temperatures were traced back to cabling problems with the DisplayPort connections. Users found that specific cables were not configured correctly, causing improper power distribution and subsequently affecting GPU temperatures. 5. Testing Environment: AMD's representative noted that the card's orientation and the setup of PC cases significantly impact thermal readings. Most testing is done in open cases, whereas users with standard cases might face higher temperatures. 6. Competitor Pricing: The video briefly touches on the pricing of the Nvidia 4070 TI, indicating that its price may not drop below the expected nearly $900, despite initial speculation. The ongoing situation has raised questions about AMD's quality assurance processes before launching the RX 7900 series. As users seek clarity and solutions, the gaming community remains engaged, sharing their experiences and concerns. Engagement Discussion: What are your thoughts on AMD's handling of this situation? Have you experienced similar thermal issues with the 7900 XTX/XT? Share your experiences below and let’s discuss potential fixes and recommendations!
