bochane
- Joined
- Oct 18, 2012
- Location
- Leiderdorp, The Netherlands
A multi-boot consisting of an SSD with a new and clean installed W10-AU and an HD with W7.
The W10 SSD is booted from the BIOS, the W7 HD is added with EASYBCD
Once I installed the multi-boot, I see weird behavior:
I get a blank screen with a busy marker for about 2 minutes, before the boot selection menu pops up. Strangely, it is not on the first time you boot this configuration, but after some time. It slows down the starting up unacceptable
And the boot selection menu contains an extra line from where the boot options, which you normally see on a W10 repair disk, can be selected.
This is different from the pre-AU behavior, in the old W10 was every thing as expected.
It looks to me that W10 AU boot parameters/behavior have/has been changed?
Does someone know how to set up this configuration without EASYBCD?
O yes, and the current version of EASYBCD is 2.3
Henk
Henk
