roman12345
Hello,
recently i have bought cable audio which looks liks this:
i connect this from my sound card to my tv but there is no sound at all.
im using WIN7 and HDTV connection,how can i force my tv to make sound?
To troubleshoot the issue of no sound when using an audio cable to connect your sound card to your TV, you can try the following steps: 1. Check Audio Output Settings: - Right-click on the volume icon in the system tray and select "Playback devices." - Ensure that the audio output is set to the correct device (your TV) by right-clicking on it and selecting "Set as Default Device." 2. Check Sound Card Connection: - Make sure that the audio cable is securely connected to the sound card's audio output port and the corresponding port on your TV. 3. Verify TV Settings: - Check the TV's audio settings to ensure that the correct input source is selected and the volume is turned up. 4. Restart Devices: - Try restarting...
To troubleshoot the issue of no sound when using an audio cable to connect your sound card to your TV, you can try the following steps: 1. Check Audio Output Settings: - Right-click on the volume icon in the system tray and select "Playback devices." - Ensure that the audio output is set to the correct device (your TV) by right-clicking on it and selecting "Set as Default Device." 2. Check Sound Card Connection: - Make sure that the audio cable is securely connected to the sound card's audio output port and the corresponding port on your TV. 3. Verify TV Settings: - Check the TV's audio settings to ensure that the correct input source is selected and the volume is turned up. 4. Restart Devices: - Try restarting both your computer and the TV to allow the devices to reset and establish a new connection. 5. Update Drivers: - Ensure that your sound card drivers are up to date. You can check the manufacturer's website for the latest drivers. 6. Test with Different Cables: - If possible, try using a different audio cable to rule out any issues with the current cable. 7. Check Audio Format Compatibility: - Verify that the audio format output by the sound card is supported by your TV. Some TVs might have limitations on supported audio formats. 8. Audio Troubleshooter: - Windows 7 has a built-in audio troubleshooter that can help diagnose and fix common audio issues. You can access it by going to Control Panel > Troubleshooting > Hardware and Sound. By following these steps, you can hopefully resolve the issue of no sound when connecting your sound card to your TV using the audio cable. If the issue persists, you may also want to consult the user manual of your TV and sound card for specific troubleshooting steps related to audio output.
