abiyubi
Link Removed i have reset problem. I can not solve the problem. My computer sometimes get a blue screen error and reset itself.I update the bios.In my opinion it does not get error as much as it used to after bios update. I need help!!
Hello and welcome to the forum.
Update this driver
ALCXWDM.SYS 11/17/2004 from here Link Removed
and this driver
fetnd6.sys 6/19/2008 from here Link Removed - Invalid URL (after determining which network adapter you are using)
and this driver
atikmdag.sys 4/24/2009 from here Link Removed
If Blue Screens persists, then;
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure...
Update this driver
and this driver
and this driver
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here Link Removed
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area Link Removed .
Good luck
Randy
