EzioAuditore
- Joined
- Sep 15, 2012
- Messages
- 2
- Thread Author
- #1
I have been experiencing BSOD From tommorow after a power failure please help the dump is attached
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1...
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
I do not recommend using wireless USB devices. Especially in Win7 systems.
These wireless USB devices have many issues with Win7 - and using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
[FONT=lucida console]**************************Sat Sep 15 21:33:27.705 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091612-14320-01.dmp]
Windows 7 Kernel Version [B]7600 [/B]MP (2 procs) Free x86 compatible
Built by: [B]7600[/B].16385.x86fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:47:03.587[/B]
BugCheck Code: [B]BugCheck 50, {9e11e000, 0, 8321dcbb, 0}[/B]
Probably caused by :[B]memory_corruption ( nt!MiCompressRelocations+3d )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]0x50_nt!MiCompressRelocations+3d[/B]
CPUID: "Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz"
MaxSpeed: 2400
CurrentSpeed: [B]2392[/B]
BIOS Version 2.1.0
BIOS Release Date 12/04/2006
Manufacturer Dell Inc.
Product Name OptiPlex 745
[/FONT]
[COLOR=RED][B]mcdbus.sys Tue Feb 24 05:42:13 2009 (49A3CF05)[/B][/COLOR]
[COLOR=RED][B]b57nd60x.sys Sun Apr 26 07:15:34 2009 (49F44256)[/B][/COLOR]
amdxata.sys Tue May 19 13:57:35 2009 (4A12F30F)
intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
[COLOR=RED][B]intelide.sys Mon Jul 13 19:11:19 2009 (4A5BBF17)[/B][/COLOR]
mcaudrv.sys Sun Jan 29 01:54:00 2012 (4F24ED08)
idmwfp.sys Tue Feb 7 10:13:15 2012 (4F313F8B)
nvhda32v.sys Wed Apr 18 13:07:34 2012 (4F8EF4D6)
HWiNFO32.SYS Thu May 10 09:05:14 2012 (4FABBD0A)
nvlddmkm.sys Tue May 15 03:34:51 2012 (4FB2071B)
[/FONT]
