BSOD daily, random timing
I surrender. Thought I could take care of it on my own, no luck. The BSOD are random - doesn't matter what program is running, it'll even crash just being logged in. I keep a minimum running @ startup. My best case was no anti-virus & no Adobe products, I think that lasted 2 days. I switched from AVG to MSE. I checked the drivers listed in the log that had a 2006 date, but the actual driver properties say 2009.
Haven't done any hardware mods to this laptop, so I suspect it's a software issue. I did run CPU burn-in and memtest86 to see if it was hardware, but neither showed any issues.
RAMMon v1.0 Build: 1002 built with SysInfo v1.0 Build: 1006
PassMark (R) Software - www.passmark.com
Memory Summary For T4300
Number of Memory Devices: 2 Total Physical Memory: 3999 MB (4096 MB) Total Available Physical Memory: 2354 MB Memory Load: 41%
ItemModule #1Module #2Ram Type DDR2 DDR2 Standard Name DDR2-800 DDR2-800 Module Name PC2-6400 PC2-6400 Memory Capacity (MB) 2048 2048 Bus Clockspeed (Mhz) 400.00 400.00 Jedec Manufacture Name Samsung Samsung Search Amazon.com Search! Search! SPD Revision 1.2 1.2 Registered No No ECC No No DIMM Slot # 1 3 Manufactured Week 45 of Year 2008 Week 45 of Year 2008 Module Part # M4 70T5663RZ3-CF7 M4 70T5663RZ3-CF7 Module Revision 0x3352 0x3352 Module Serial # 0x7668F1E4 0x7668F531 Module Manufacturing Location 2 2 # of Row Addressing Bits 14 14 # of Column Addressing Bits 10 10 # of Banks 8 8 # of Ranks 2 2 Device Width in Bits 8 8 Bus Width in Bits 64 64 Module Voltage SSTL 1.8V SSTL 1.8V CAS Latencies Supported 4 5 6 4 5 6 Timings @ Max Frequency 6-6-6-18 6-6-6-18 Minimum Clock Cycle Time, tCK (ns) 2.500 2.500 Minimum CAS Latency Time, tAA (ns) 15.000 15.000 Minimum RAS to CAS Delay, tRCD (ns) 15.000 15.000 Minimum Row Precharge Time, tRP (ns) 15.000 15.000 Minimum Active to Precharge Time, tRAS (ns) 45.000 45.000 Minimum Row Active to Row Active Delay, tRRD (ns) 7.500 7.500 Minimum Auto-Refresh to Active/Auto-Refresh Time, tRC (ns) 60.000 60.000 Minimum Auto-Refresh to Active/Auto-Refresh Command Period, tRFC (ns) 127.500 127.500 DDR2 Specific SPD Attributes Data Access Time from Clock, tAC (ns) 0.400 0.400 Clock Cycle Time at Medium CAS Latency (ns) 3.000 3.000 Data Access Time at Medium CAS Latency (ns) 0.450 0.450 Clock Cycle Time at Short CAS Latency (ns) 3.750 3.750 Data Access Time at Short CAS Latency (ns) 0.500 0.500 Maximum Clock Cycle Time (ns) 8.000 8.000 Write Recover Time, tWR (ns) 15.000 15.000 Internal Write to Read Command Delay, tWTR (ns) 7.500 7.500 Internal Read to Precharge Command Delay, tRTP (ns) 7.500 7.500 Address/Command Setup Time Before Clock, tIS (ns) 0.170 0.170 Address/Command Hold Time After Clock, tIH (ns) 0.250 0.250 Data Input Setup Time Before Strobe, tDS (ns) 0.050 0.050 Data Input Hold Time After Strobe, tDH (ns) 0.120 0.120 Maximum Skew Between DQS and DQ Signals (ns) 0.200 0.200 Maximum Read Data hold Skew Factor (ns) 0.240 0.240 PLL Relock Time (ns) 0.000 0.000 DRAM Package Type Planar Planar Burst Lengths Supported 4 8 4 8 Refresh Rate Reduced (7.8us) Reduced (7.8us) # of PLLS on DIMM 0 0 FET Switch External Enable No No Analysis Probe Installed No No Weak Driver Supported Yes Yes 50 Ohm ODT Supported Yes Yes Partial Array Self Refresh Supported Yes Yes Module Type SO-DIMM SO-DIMM Module Height (mm) 30.0 30.0
RAM is set right, 800Mhz 6-6-6-18.
The problem is too many old drivers. Go to HP support to update them:
HP Support & Drivers
Update drivers:
Intel Raid
iirsp.sys Tue Dec 13 16:47:54 2005
Intel Matrix Storage
iaStorV.sys Wed Apr 08 12:57:17 2009
Intel® Driver Update Utility
Smart Array SAS/SATA Controller Media
HpSAMD.sys Mon May 18 19:43:49 2009
HP Smart Array RAID controllers
LightPulse HBAs
elxstor.sys Tue Feb 03 17:52:11 2009
Emulex | Downloads - Emulex - CNAs and HBAs - Windows - Drivers for Windows - Ent
Adaptec RAID
arc.sys Thu May 24 17:27:55 2007
http://www.adaptec.com/en-US/downloads/
AMD AHCI
amdsbs.sys Fri Mar 20 14:36:03 2009
AMD.com | Support & Downloads
VIA RAID
vsmraid.sys Fri Jan 30 20:18:57 2009
VIA Drivers Download - VIA Technologies, Inc.
Touchpad
SynTP.sys Thu Jun 18 22:33:58 2009
SiS AHCI
sisraid4.sys Wed Oct 01 17:56:04 2008
Silicon Image - Support
Realtek USB Card Reader
RtsUStor.sys Thu Jun 04 04:46:49 2009
Realtek
Realtek LAN
Rt64win7.sys Fri Nov 27 04:45:07 2009
Realtek
QLogic QLA2300 Adapter
ql2300.sys Thu Jan 22 18:05:06 2009
QLogic Driver Download
IBM ServeRAID Controller
nfrd960.sys Tue Jun 06 17:11:48 2006
IBM Support Portal
Conexant Modem
mdmxsdk.sys Mon Jun 19 17:27:26 2006
Conexant: Support
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021711-25942-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02c15000 PsLoadedModuleList = 0xfffff800`02e52e50
Debug session time: Thu Feb 17 19:29:06.199 2011 (UTC - 5:00)
System Uptime: 3 days 1:56:31.228
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 50, {fffff9004d72981c, 1, fffff96000241986, 5}
Unable to load image \SystemRoot\System32\win32k.sys, Win32 error 0n2
Probably caused by : win32k.sys ( win32k+221986 )
Followup: MachineOwner
1: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff9004d72981c, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff96000241986, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000005, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ebd0e0
 fffff9004d72981c
FAULTING_IP:
win32k+221986
fffff960`00241986 4883ec20        sub     rsp,20h
MM_INTERNAL_CODE:  5
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  chrome.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88006fb35b0 -- (.trap 0xfffff88006fb35b0)
rax=00000000000008ac rbx=0000000000000000 rcx=fffff900c22a7730
rdx=fffffa80045f0b60 rsi=0000000000000000 rdi=0000000000000000
rip=fffff96000241986 rsp=fffff88006fb3740 rbp=fffff88006fb3d90
 r8=0000000000000000  r9=0000000000000000 r10=00000000008ed800
r11=fffff88006fb3750 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po nc
win32k+0x221986:
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002d048c1 to fffff80002c85740
STACK_TEXT:
fffff880`06fb3448 fffff800`02d048c1 : 00000000`00000050 fffff900`4d72981c 00000000`00000001 fffff880`06fb35b0 : nt!KeBugCheckEx
fffff880`06fb3450 fffff800`02c8382e : 00000000`00000001 fffff900`c22a7730 fffff880`06fb3600 fffff960`0009504c : nt! ?? ::FNODOBFM::`string'+0x40e8b
fffff880`06fb35b0 fffff960`00241986 : fffff900`c22a7730 fffff960`000a63ab 00000000`0000001c fffff900`c0081070 : nt!KiPageFault+0x16e
fffff880`06fb3740 fffff900`c22a7730 : fffff960`000a63ab 00000000`0000001c fffff900`c0081070 00000000`00000094 : win32k+0x221986
fffff880`06fb3748 fffff960`000a63ab : 00000000`0000001c fffff900`c0081070 00000000`00000094 fffff900`c0867290 : 0xfffff900`c22a7730
fffff880`06fb3750 00000000`0000001c : fffff900`c0081070 00000000`00000094 fffff900`c0867290 00000000`00000000 : win32k+0x863ab
fffff880`06fb3758 fffff900`c0081070 : 00000000`00000094 fffff900`c0867290 00000000`00000000 fffff960`00054fad : 0x1c
fffff880`06fb3760 00000000`00000094 : fffff900`c0867290 00000000`00000000 fffff960`00054fad 00000000`00000000 : 0xfffff900`c0081070
fffff880`06fb3768 fffff900`c0867290 : 00000000`00000000 fffff960`00054fad 00000000`00000000 fffff900`c22a7750 : 0x94
fffff880`06fb3770 00000000`00000000 : fffff960`00054fad 00000000`00000000 fffff900`c22a7750 fffff900`00000006 : 0xfffff900`c0867290
STACK_COMMAND:  kb
FOLLOWUP_IP:
win32k+221986
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  win32k+221986
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x50_win32k+221986
Loading Dump File [F:\a\Minidump\D M P\DMP\021711-39359-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c4b000 PsLoadedModuleList = 0xfffff800`02e88e50
Debug session time: Thu Feb 17 22:17:14.884 2011 (UTC - 5:00)
System Uptime: 0 days 2:47:39.897
BugCheck 1E, {0, 0, 0, 0}
Probably caused by : ndis.sys ( ndis!ndisInterruptDpc+6a )
1: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) - The operation completed successfully.
FAULTING_IP:
+3536303635636134
00000000`00000000 ??              ???
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
ERROR_CODE: (NTSTATUS) 0 - STATUS_WAIT_0
BUGCHECK_STR:  0x1E_0
PROCESS_NAME:  System
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff8800371b9c8 -- (.exr 0xfffff8800371b9c8)
ExceptionAddress: fffff88001eb8cba (ndis!ndisInterruptDpc+0x000000000000006a)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff8800371ba70 -- (.trap 0xfffff8800371ba70)
rax=fffff8800371bc88 rbx=0000000000000000 rcx=fffff8800371bc38
rdx=fffffa80057868e0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88001eb8cba rsp=fffff8800371bc00 rbp=0000000000000000
 r8=0000000000000000  r9=0000000000000000 r10=0000000000da7a64
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
ndis!ndisInterruptDpc+0x6a:
fffff880`01eb8cba ff1588350500    call    qword ptr [ndis!_imp_KeQueryDpcWatchdogInformation (fffff880`01f0c248)] ds:7123:fffff880`01f0c248=00000000000dc6b2
LAST_CONTROL_TRANSFER:  from fffff80002cb346e to fffff80002cbb710
STACK_TEXT:
fffff880`0371aab8 fffff800`02cb346e : fffff880`0371abe8 00000000`00000000 fffff880`0371b230 fffff800`02ce8668 : nt!KeBugCheck
fffff880`0371aac0 fffff800`02ce140d : fffff800`02ec9b7c fffff800`02e03ea4 fffff800`02c4b000 fffff880`0371b9c8 : nt!KiKernelCalloutExceptionHandler+0xe
fffff880`0371aaf0 fffff800`02ce8a90 : fffff800`02e0ab34 fffff880`0371ab68 fffff880`0371b9c8 fffff800`02c4b000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`0371ab20 fffff800`02cf59ef : fffff880`0371b9c8 fffff880`0371b230 fffff880`00000000 00000000`00000000 : nt!RtlDispatchException+0x410
fffff880`0371b200 fffff800`02cbad82 : fffff880`0371b9c8 fffffa80`057868e0 fffff880`0371ba70 fffffa80`052fe1a0 : nt!KiDispatchException+0x16f
fffff880`0371b890 fffff800`02cb968a : fffffa80`00000001 fffffa80`05592030 00000000`00000000 fffffa80`047901b0 : nt!KiExceptionDispatch+0xc2
fffff880`0371ba70 fffff880`01eb8cba : 00000000`00000000 00000000`00da7a64 00000000`00000000 fffffa80`047633f0 : nt!KiGeneralProtectionFault+0x10a
fffff880`0371bc00 fffff800`02cc6bfc : fffffa80`05786908 00000004`00000000 00000000`00000000 fffff880`009e8180 : ndis!ndisInterruptDpc+0x6a
fffff880`0371bc90 fffff800`02cc3eea : fffff880`009e8180 fffff880`009f2f40 00000000`00000000 fffff880`01eb8c50 : nt!KiRetireDpcList+0x1bc
fffff880`0371bd40 00000000`00000000 : fffff880`0371c000 fffff880`03716000 fffff880`0371bd00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  ndis!ndisInterruptDpc+6a
MODULE_NAME: ndis
IMAGE_NAME:  ndis.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc184
FAILURE_BUCKET_ID:  X64_0x1E_0_ndis!ndisInterruptDpc+6a
Drivers:
fffff880`00eb6000 fffff880`00f0d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`01026000 fffff880`010a1000   adp94xx  adp94xx.sys  Fri Dec 05 18:54:42 2008 (4939BF42)
fffff880`0143d000 fffff880`01493000   adpahci  adpahci.sys  Tue May 01 13:30:09 2007 (46377921)
fffff880`01493000 fffff880`014c2000   adpu320  adpu320.sys  Tue Feb 27 19:04:15 2007 (45E4C6FF)
fffff880`034a5000 fffff880`0352f000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04435000 fffff880`0444b000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01151000 fffff880`01158000   aliide   aliide.sys   Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01158000 fffff880`0115f000   amdide   amdide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`014c2000 fffff880`014e0000   amdsata  amdsata.sys  Tue May 19 13:53:21 2009 (4A12F211)
fffff880`014e0000 fffff880`01527000   amdsbs   amdsbs.sys   Fri Mar 20 14:36:03 2009 (49C3E213)
fffff880`01527000 fffff880`01532000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`01532000 fffff880`0154b000   arc      arc.sys      Thu May 24 17:27:55 2007 (4656035B)
fffff880`0154b000 fffff880`01566000   arcsas   arcsas.sys   Wed Jan 14 14:27:37 2009 (496E3CA9)
fffff880`013e8000 fffff880`013f1000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01200000 fffff880`0122a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04450000 fffff880`045bf000   athrx    athrx.sys    Mon Sep 21 22:47:11 2009 (4AB83AAF)
fffff960`00860000 fffff960`008c1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00fb1000 fffff880`00fbd000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`01eb0000 fffff880`01eb7000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`035ed000 fffff880`035fe000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02f4e000 fffff880`02f6c000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`068a3000 fffff880`0696e000   CAX_CNXT CAX_CNXT.sys Fri Feb 13 16:19:32 2009 (4995E3E4)
fffff880`06668000 fffff880`067dc000   CAX_DPV  CAX_DPV.sys  Fri Feb 13 16:24:50 2009 (4995E522)
fffff880`04800000 fffff880`04852000   CAXHWAZL CAXHWAZL.sys Fri Feb 13 16:20:54 2009 (4995E436)
fffff960`00700000 fffff960`00727000   cdd      cdd.dll      unavailable (00000000)
fffff880`017b9000 fffff880`017e3000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`048c3000 fffff880`04971000   CHDRT64  CHDRT64.sys  Fri Feb 26 20:55:00 2010 (4B887B74)
fffff880`00cff000 fffff880`00dbf000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`011d0000 fffff880`01200000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00ca1000 fffff880`00cff000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04420000 fffff880`04424500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`0115f000 fffff880`01167000   cmdide   cmdide.sys   Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01d62000 fffff880`01dd5000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00fa8000 fffff880`00fb1000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`04425000 fffff880`04435000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02ec8000 fffff880`02ed0000   cpuz132_x64 cpuz132_x64.sys Thu Mar 26 19:17:23 2009 (49CC0D03)
fffff880`06899000 fffff880`068a2000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`069b0000 fffff880`069be000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`035cf000 fffff880`035ed000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0358e000 fffff880`0359d000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01bb6000 fffff880`01bcc000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`049ae000 fffff880`049d0000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`069cc000 fffff880`069d8000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`069e3000 fffff880`069f6000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`069d8000 fffff880`069e3000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`069a4000 fffff880`069b0000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05aff000 fffff880`05bf3000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`05000000 fffff880`05046000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`01566000 fffff880`015ed000   elxstor  elxstor.sys  Tue Feb 03 17:52:11 2009 (4988CA9B)
fffff880`05d8e000 fffff880`05dc4000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01800000 fffff880`01814000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0176d000 fffff880`017b9000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01de6000 fffff880`01df0000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01ca1000 fffff880`01cdb000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01fa9000 fffff880`01ff3000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02c02000 fffff800`02c4b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`050ba000 fffff880`050de000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06844000 fffff880`0684c080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`045ea000 fffff880`045f6000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 09:48:30 2009 (49F85AAE)
fffff880`0100f000 fffff880`01026000   HpSAMD   HpSAMD.sys   Mon May 18 19:43:49 2009 (4A11F2B5)
fffff880`02e00000 fffff880`02ec8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01c98000 fffff880`01ca1000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`045cc000 fffff880`045ea000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`012ca000 fffff880`013e8000   iaStorV  iaStorV.sys  Wed Apr 08 12:57:17 2009 (49DCD76D)
fffff880`050e0000 fffff880`05afeb60   igdkmd64 igdkmd64.sys Wed Aug 25 15:35:58 2010 (4C75709E)
fffff880`015ed000 fffff880`015fe000   iirsp    iirsp.sys    Tue Dec 13 16:47:54 2005 (439F418A)
fffff880`0697d000 fffff880`069a4000   IntcHdmi IntcHdmi.sys Tue May 26 07:13:09 2009 (4A1BCEC5)
fffff880`01139000 fffff880`01141000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04280000 fffff880`04296000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00f60000 fffff880`00f69000   isapnp   isapnp.sys   Mon Jul 13 19:31:08 2009 (4A5BC3BC)
fffff880`04400000 fffff880`0440f000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00b9e000 fffff800`00ba8000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04200000 fffff880`04243000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01d48000 fffff880`01d62000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01e60000 fffff880`01e8b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`049d0000 fffff880`049d5200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06644000 fffff880`06659000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01400000 fffff880`0141f000   lsi_fc   lsi_fc.sys   Tue Dec 09 17:46:09 2008 (493EF531)
fffff880`0122a000 fffff880`01247000   lsi_sas  lsi_sas.sys  Mon May 18 20:20:23 2009 (4A11FB47)
fffff880`0141f000 fffff880`01432000   lsi_sas2 lsi_sas2.sys Mon May 18 20:31:48 2009 (4A11FDF4)
fffff880`010a1000 fffff880`010c0000   lsi_scsi lsi_scsi.sys Thu Apr 16 18:13:50 2009 (49E7AD9E)
fffff880`06600000 fffff880`06623000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c49000 fffff880`00c8d000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`069f6000 fffff880`069fa280   mdmxsdk  mdmxsdk.sys  Mon Jun 19 17:27:26 2006 (449716BE)
fffff880`012b4000 fffff880`012c0000   megasas  megasas.sys  Mon May 18 21:09:46 2009 (4A1206DA)
fffff880`01605000 fffff880`016a9000   MegaSR   MegaSR.sys   Mon May 18 21:25:54 2009 (4A120AA2)
fffff880`0696e000 fffff880`0697d000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`069be000 fffff880`069cc000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04411000 fffff880`04420000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01167000 fffff880`01181000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00dbf000 fffff880`00df0000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`00f69000 fffff880`00f93000   mpio     mpio.sys     Mon Jul 13 20:01:27 2009 (4A5BCAD7)
fffff880`05cbe000 fffff880`05cce000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`02f6c000 fffff880`02f84000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02f84000 fffff880`02fb1000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`02fb1000 fffff880`02fff000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`049d6000 fffff880`049f9000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`012a9000 fffff880`012b4000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01181000 fffff880`011a7000   msdsm    msdsm.sys    Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`017f5000 fffff880`01800000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f16000 fffff880`00f20000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01cea000 fffff880`01d48000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03583000 fffff880`0358e000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01c86000 fffff880`01c98000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01eb7000 fffff880`01fa9000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`05bf3000 fffff880`05bff000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`02f23000 fffff880`02f36000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04358000 fffff880`04387000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`048ae000 fffff880`048c3000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03574000 fffff880`03583000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03460000 fffff880`034a5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01e00000 fffff880`01e60000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`016a9000 fffff880`016b9000   nfrd960  nfrd960.sys  Tue Jun 06 17:11:48 2006 (4485EF94)
fffff880`05cce000 fffff880`05ce3000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`010c0000 fffff880`010d1000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03451000 fffff880`0345d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c4b000 fffff800`03228000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01a13000 fffff880`01bb6000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01bea000 fffff880`01bf3000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`011a7000 fffff880`011d0000   nvraid   nvraid.sys   Wed May 20 02:39:40 2009 (4A13A5AC)
fffff880`016b9000 fffff880`016e4000   nvstor   nvstor.sys   Wed May 20 02:45:37 2009 (4A13A711)
fffff880`02ed0000 fffff880`02f23000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03538000 fffff880`0355e000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f93000 fffff880`00fa8000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f20000 fffff880`00f53000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01000000 fffff880`01007000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`01141000 fffff880`01151000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01dd5000 fffff880`01de6000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`04038000 fffff880`040de000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04971000 fffff880`049ae000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c8d000 fffff880`00ca1000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0181c000 fffff880`019c0000   ql2300   ql2300.sys   Thu Jan 22 18:05:06 2009 (4978FBA2)
fffff880`016e4000 fffff880`01743000   ql40xx   ql40xx.sys   Mon May 18 21:18:11 2009 (4A1208D3)
fffff880`04334000 fffff880`04358000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04387000 fffff880`043a2000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`043a2000 fffff880`043c3000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`043c3000 fffff880`043dd000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03400000 fffff880`03451000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01bf3000 fffff880`01bfc000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`017e3000 fffff880`017ec000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`017ec000 fffff880`017f5000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01c4c000 fffff880`01c86000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02f36000 fffff880`02f4e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0429f000 fffff880`042eb000   Rt64win7 Rt64win7.sys Fri Nov 27 04:45:07 2009 (4B0F9FA3)
fffff880`05dc4000 fffff880`05dfe000   RtsUStor RtsUStor.sys Thu Jun 04 04:46:49 2009 (4A2789F9)
fffff880`01e93000 fffff880`01eb0000   sbp2port sbp2port.sys Mon Jul 13 19:19:53 2009 (4A5BC119)
fffff880`040de000 fffff880`040e9000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`019c0000 fffff880`019ce000   SiSRaid2 SiSRaid2.sys Wed Sep 24 14:28:20 2008 (48DA86C4)
fffff880`019ce000 fffff880`019e6000   sisraid4 sisraid4.sys Wed Oct 01 17:56:04 2008 (48E3F1F4)
fffff880`01e8b000 fffff880`01e93000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`05c28000 fffff880`05cbe000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`04130000 fffff880`04197000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`040e9000 fffff880`04116000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`019e6000 fffff880`019f0000   stexstor stexstor.sys Tue Feb 17 18:03:36 2009 (499B4248)
fffff880`01247000 fffff880`012a9000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`0444b000 fffff880`0444c480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`042eb000 fffff880`04334000   SynTP    SynTP.sys    Thu Jun 18 22:33:58 2009 (4A3AF916)
fffff880`02002000 fffff880`021ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`04116000 fffff880`04128000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`013f1000 fffff880`013fe000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`00c00000 fffff880`00c1e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`035bb000 fffff880`035cf000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005e0000 fffff960`005ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`00c1e000 fffff880`00c44000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04243000 fffff880`04255000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06800000 fffff880`0681d000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0440f000 fffff880`04410f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`050a9000 fffff880`050ba000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04854000 fffff880`048ae000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`05053000 fffff880`050a9000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`067dc000 fffff880`067e8000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`06888000 fffff880`06899000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`05046000 fffff880`05053000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`0684d000 fffff880`0687a200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`00f53000 fffff880`00f60000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01a00000 fffff880`01a0e000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01007000 fffff880`0100f000   viaide   viaide.sys   Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`00fd2000 fffff880`00ff7000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fbd000 fffff880`00fd2000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010dd000 fffff880`01139000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01c00000 fffff880`01c4c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01743000 fffff880`0176d000   vsmraid  vsmraid.sys  Fri Jan 30 20:18:57 2009 (4983A701)
fffff880`045bf000 fffff880`045cc000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`0355e000 fffff880`03574000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`035a0000 fffff880`035bb000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019f0000 fffff880`01a00000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`01ff3000 fffff880`01ffb000   wd       wd.sys       Mon Jul 13 19:19:55 2009 (4A5BC11B)
fffff880`00e03000 fffff880`00ea7000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea7000 fffff880`00eb6000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0352f000 fffff880`03538000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003b0000   win32k   win32k.sys   unavailable (00000000)
fffff880`04296000 fffff880`0429f000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f0d000 fffff880`00f16000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06623000 fffff880`06644000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`05ce3000 fffff880`05d14000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
fffff880`04128000 fffff880`04130000   XAudio64 XAudio64.sys Wed Apr 29 14:21:07 2009 (49F89A93)
Unloaded modules:
fffff880`05d2a000 fffff880`05d5b000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`05cf0000 fffff880`05d2a000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003A000
fffff880`05c0e000 fffff880`05c27000   HIDCLASS.SYS
    Checksum:  00000000
    ImageSize:  00019000
fffff880`05c00000 fffff880`05c0e000   hidusb.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05ce3000 fffff880`05cf0000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`05dc4000 fffff880`05df5000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`05d54000 fffff880`05d8e000   RtsUStor.sys
    Checksum:  00000000
    ImageSize:  0003A000
fffff880`0682b000 fffff880`06844000   HIDCLASS.SYS
    Checksum:  00000000
    ImageSize:  00019000
fffff880`0681d000 fffff880`0682b000   hidusb.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0687b000 fffff880`06888000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`05ce3000 fffff880`05d54000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01cdb000 fffff880`01ce9000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01df0000 fffff880`01dfc000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01bcc000 fffff880`01bd7000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01bd7000 fffff880`01bea000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`03583000 fffff880`035a0000   serial.sys
    Checksum:  00000000
    ImageSize:  0001D000
Thanks for the feedback. I had gone thru & did Update Driver Software on all of my devices, but apparently the "checking online" part is useless. If you don't d/l it manually, it doesn't seem to be able to find it. Anyway, will let you know how it turns out, but I'm betting this solves it. Thanks again!
Ok, let's hope. Know it from my own experience, it is not easy to update notebook's drivers when it is years old. Good you're using MSE, with so many old drivers in the system it won't fall into bsods as often as other securities.
Well, glad I don't make it to Vegas much. Still getting crashes at about the same rate (1-3 times a day). The SF tool driver list output doesn't match what I find when I check drivers individually. I don't have time at the moment to go thru them all, but a spot check (especially the ones that show up as 2006 drivers) aren't correct - at least that one says it was modified 6/10/2009.
Anything else to check, or still likely a driver?
I'll go back thru & see if I can figure out a way to get the driver dates more accurate.
#7
Attach your latest crash dumps.
#8
Here are the two. The first is almost immediately after I updated drivers, the second after 2 restarts. Thanks again!
#9
Caused by Atheros Wireless driver:
021911-27284-01.dmp
BugCheck D1, {100000000, a, 1, fffff8800455a6c6}
Probably caused by : athrx.sys ( athrx+f56c6 )
022011-25225-01.dmp
BugCheck 1E, {ffffffffc0000005, fffff80002c29ea5, 0, 5d}
Probably caused by : ntkrnlmp.exe ( nt!KeRevertToUserGroupAffinityThread+15 )
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\021911-27284-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c0f000 PsLoadedModuleList = 0xfffff800`02e4ce50
Debug session time: Sat Feb 19 17:15:20.636 2011 (UTC - 5:00)
System Uptime: 0 days 3:44:15.665
Unable to load image \SystemRoot\system32\DRIVERS\athrx.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athrx.sys
*** ERROR: Module load completed but symbols could not be loaded for athrx.sys
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000100000000, memory referenced
Arg2: 000000000000000a, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff8800455a6c6, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eb70e0
 0000000100000000
CURRENT_IRQL:  a
FAULTING_IP:
athrx+f56c6
fffff880`0455a6c6 ba24000000      mov     edx,24h
BUGCHECK_STR:  0xD1
TRAP_FRAME:  fffff80000b9c850 -- (.trap 0xfffff80000b9c850)
rax=0000000080000000 rbx=0000000000000000 rcx=fffffa80057b2030
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800455a6c6 rsp=fffff80000b9c9e0 rbp=fffff80000b9cc30
athrx+0xf56c6:
LAST_CONTROL_TRANSFER:  from fffff80002c7eca9 to fffff80002c7f740
STACK_TEXT:
fffff800`00b9c708 fffff800`02c7eca9 : 00000000`0000000a 00000001`00000000 00000000`0000000a 00000000`00000001 : nt!KeBugCheckEx
fffff800`00b9c710 fffff800`02c7d920 : 00000000`00000000 fffffa80`059c07d0 fffff800`00b9cb68 fffff880`0508c18b : nt!KiBugCheckDispatch+0x69
fffff800`00b9c850 fffff880`0455a6c6 : 00000002`00000000 fffff880`00000000 fffffa80`057b27fc 00000009`00000000 : nt!KiPageFault+0x260
fffff800`00b9c9e0 00000002`00000000 : fffff880`00000000 fffffa80`057b27fc 00000009`00000000 fffffa80`f4041071 : athrx+0xf56c6
fffff800`00b9c9e8 fffff880`00000000 : fffffa80`057b27fc 00000009`00000000 fffffa80`f4041071 00905deb`00cd512f : 0x2`00000000
fffff800`00b9c9f0 fffffa80`057b27fc : 00000009`00000000 fffffa80`f4041071 00905deb`00cd512f fffffa80`057b27fc : 0xfffff880`00000000
fffff800`00b9c9f8 00000009`00000000 : fffffa80`f4041071 00905deb`00cd512f fffffa80`057b27fc fffffa80`057b2030 : 0xfffffa80`057b27fc
fffff800`00b9ca00 fffffa80`f4041071 : 00905deb`00cd512f fffffa80`057b27fc fffffa80`057b2030 00000000`00000000 : 0x9`00000000
fffff800`00b9ca08 00905deb`00cd512f : fffffa80`057b27fc fffffa80`057b2030 00000000`00000000 fffff880`04509d5b : 0xfffffa80`f4041071
fffff800`00b9ca10 fffffa80`057b27fc : fffffa80`057b2030 00000000`00000000 fffff880`04509d5b fffffa80`057b2030 : 0x905deb`00cd512f
fffff800`00b9ca18 fffffa80`057b2030 : 00000000`00000000 fffff880`04509d5b fffffa80`057b2030 fffff800`00000000 : 0xfffffa80`057b27fc
fffff800`00b9ca20 00000000`00000000 : fffff880`04509d5b fffffa80`057b2030 fffff800`00000000 00000000`00000001 : 0xfffffa80`057b2030
STACK_COMMAND:  kb
FOLLOWUP_IP:
athrx+f56c6
SYMBOL_NAME:  athrx+f56c6
MODULE_NAME: athrx
IMAGE_NAME:  athrx.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4aca1ff5
FAILURE_BUCKET_ID:  X64_0xD1_athrx+f56c6
Loading Dump File [F:\a\Minidump\D M P\DMP\022011-25225-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c02000 PsLoadedModuleList = 0xfffff800`02e3fe50
Debug session time: Sun Feb 20 23:24:05.566 2011 (UTC - 5:00)
System Uptime: 0 days 12:46:09.188
1: kd> !analyze -v
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002c29ea5, The address that the exception occurred at
Arg4: 000000000000005d, Parameter 1 of the exception
Debugging Details:
FAULTING_IP:
fffff800`02c29ea5 4155            push    r13
EXCEPTION_PARAMETER2:  000000000000005d
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eaa0e0
 000000000000005d
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR:  0x1E_c0000005
CURRENT_IRQL:  0
EXCEPTION_RECORD:  fffff880037f59c8 -- (.exr 0xfffff880037f59c8)
ExceptionAddress: fffff80002c29ea5 (nt!KeRevertToUserGroupAffinityThread+0x0000000000000015)
NumberParameters: 2
   Parameter[1]: 000000000000005d
Attempt to read from address 000000000000005d
TRAP_FRAME:  fffff880037f5a70 -- (.trap 0xfffff880037f5a70)
rax=fffff880037f5c08 rbx=0000000000000000 rcx=fffff880037f5c30
rdx=1000001000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002c29ea5 rsp=fffff880037f5c00 rbp=0000000000000002
 r8=0000000000000006  r9=0000000000000006 r10=00000000c0000225
r11=fffff880037f5be0 r12=0000000000000000 r13=0000000000000000
nt!KeRevertToUserGroupAffinityThread+0x15:
LAST_CONTROL_TRANSFER:  from fffff80002caca39 to fffff80002c72740
STACK_TEXT:
fffff880`037f51f8 fffff800`02caca39 : 00000000`0000001e ffffffff`c0000005 fffff800`02c29ea5 00000000`00000000 : nt!KeBugCheckEx
fffff880`037f5200 fffff800`02c71d82 : fffff880`037f59c8 00000000`00000002 fffff880`037f5a70 fffff800`032076b0 : nt!KiDispatchException+0x1b9
fffff880`037f5890 fffff800`02c708fa : 00000000`00000000 00000000`00000002 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff880`037f5a70 fffff800`02c29ea5 : fffff800`03207738 fffff800`032076b0 00000000`00000000 00000000`00000002 : nt!KiPageFault+0x23a
fffff880`037f5c00 fffff800`032076b0 : 00000000`00000000 00000000`00000002 00000000`00000002 00000000`00000000 : nt!KeRevertToUserGroupAffinityThread+0x15
fffff880`037f5c10 00000000`00000000 : 00000000`00000002 00000000`00000002 00000000`00000000 00020000`00000000 : hal!HalpCmcContext
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  nt!KeRevertToUserGroupAffinityThread+15
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc791bd
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KeRevertToUserGroupAffinityThread+15
Drivers:
fffff880`00f87000 fffff880`00fde000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`01200000 fffff880`0127b000   adp94xx  adp94xx.sys  Fri Dec 05 18:54:42 2008 (4939BF42)
fffff880`01386000 fffff880`013dc000   adpahci  adpahci.sys  Tue May 01 13:30:09 2007 (46377921)
fffff880`0127b000 fffff880`012aa000   adpu320  adpu320.sys  Tue Feb 27 19:04:15 2007 (45E4C6FF)
fffff880`04255000 fffff880`042df000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03449000 fffff880`0345f000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c74000 fffff880`00c7b000   aliide   aliide.sys   Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c7b000 fffff880`00c82000   amdide   amdide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`013dc000 fffff880`013fa000   amdsata  amdsata.sys  Tue May 19 13:53:21 2009 (4A12F211)
fffff880`01414000 fffff880`0145b000   amdsbs   amdsbs.sys   Fri Mar 20 14:36:03 2009 (49C3E213)
fffff880`0145b000 fffff880`01466000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`01466000 fffff880`0147f000   arc      arc.sys      Thu May 24 17:27:55 2007 (4656035B)
fffff880`0147f000 fffff880`0149a000   arcsas   arcsas.sys   Wed Jan 14 14:27:37 2009 (496E3CA9)
fffff880`011e5000 fffff880`011ee000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`012bb000 fffff880`012e5000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04465000 fffff880`045e2000   athrx    athrx.sys    Mon Oct 05 12:33:57 2009 (4ACA1FF5)
fffff960`00990000 fffff960`009f1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00dcb000 fffff880`00dd7000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`034c0000 fffff880`034c7000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0421e000 fffff880`0422f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03175000 fffff880`03193000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`06c7d000 fffff880`06d48000   CAX_CNXT CAX_CNXT.sys Fri Feb 13 16:19:32 2009 (4995E3E4)
fffff880`06821000 fffff880`06995000   CAX_DPV  CAX_DPV.sys  Fri Feb 13 16:24:50 2009 (4995E522)
fffff880`067a1000 fffff880`067f3000   CAXHWAZL CAXHWAZL.sys Fri Feb 13 16:20:54 2009 (4995E436)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
fffff880`01c40000 fffff880`01c6a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0668e000 fffff880`0673c000   CHDRT64  CHDRT64.sys  Fri Feb 26 20:55:00 2010 (4B887B74)
fffff880`00ec7000 fffff880`00f87000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01088000 fffff880`010b8000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cfb000 fffff880`00d59000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0444a000 fffff880`0444e500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`00c82000 fffff880`00c8a000   cmdide   cmdide.sys   Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01c90000 fffff880`01d03000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00ebc000 fffff880`00ec5000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0444f000 fffff880`0445f000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03071000 fffff880`03079000   cpuz132_x64 cpuz132_x64.sys Thu Mar 26 19:17:23 2009 (49CC0D03)
fffff880`03079000 fffff880`03082000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`06d8a000 fffff880`06d98000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04200000 fffff880`0421e000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`043e7000 fffff880`043f6000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01c00000 fffff880`01c16000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06779000 fffff880`0679b000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06d98000 fffff880`06da4000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06daf000 fffff880`06dc2000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06da4000 fffff880`06daf000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`06d7e000 fffff880`06d8a000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05a46000 fffff880`05b3a000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`05b3a000 fffff880`05b80000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`0149a000 fffff880`01521000   elxstor  elxstor.sys  Tue Feb 03 17:52:11 2009 (4988CA9B)
fffff880`03d26000 fffff880`03d5c000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01822000 fffff880`01836000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0178e000 fffff880`017da000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01d14000 fffff880`01d1e000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01dc1000 fffff880`01dfb000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01e8b000 fffff880`01ed5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`031ec000 fffff800`03235000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`05000000 fffff880`05024000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0441e000 fffff880`0442a000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 09:48:30 2009 (49F85AAE)
fffff880`0136f000 fffff880`01386000   HpSAMD   HpSAMD.sys   Mon May 18 19:43:49 2009 (4A11F2B5)
fffff880`030ad000 fffff880`03175000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01ff7000 fffff880`02000000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04400000 fffff880`0441e000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010c7000 fffff880`011e5000   iaStorV  iaStorV.sys  Wed Apr 08 12:57:17 2009 (49DCD76D)
fffff880`05027000 fffff880`05a45b60   igdkmd64 igdkmd64.sys Wed Aug 25 15:35:58 2010 (4C75709E)
fffff880`01521000 fffff880`01532000   iirsp    iirsp.sys    Tue Dec 13 16:47:54 2005 (439F418A)
fffff880`06d57000 fffff880`06d7e000   IntcHdmi IntcHdmi.sys Tue May 26 07:13:09 2009 (4A1BCEC5)
fffff880`00c5c000 fffff880`00c64000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04333000 fffff880`04349000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00eb3000 fffff880`00ebc000   isapnp   isapnp.sys   Mon Jul 13 19:31:08 2009 (4A5BC3BC)
fffff880`0442a000 fffff880`04439000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bce000 fffff800`00bd8000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04695000 fffff880`046d8000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01bc4000 fffff880`01bde000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0679b000 fffff880`067a0200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06c5f000 fffff880`06c74000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01532000 fffff880`01551000   lsi_fc   lsi_fc.sys   Tue Dec 09 17:46:09 2008 (493EF531)
fffff880`012e5000 fffff880`01302000   lsi_sas  lsi_sas.sys  Mon May 18 20:20:23 2009 (4A11FB47)
fffff880`01551000 fffff880`01564000   lsi_sas2 lsi_sas2.sys Mon May 18 20:31:48 2009 (4A11FDF4)
fffff880`01564000 fffff880`01583000   lsi_scsi lsi_scsi.sys Thu Apr 16 18:13:50 2009 (49E7AD9E)
fffff880`06c3c000 fffff880`06c5f000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ca3000 fffff880`00ce7000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`03082000 fffff880`03086280   mdmxsdk  mdmxsdk.sys  Mon Jun 19 17:27:26 2006 (449716BE)
fffff880`01583000 fffff880`0158f000   megasas  megasas.sys  Mon May 18 21:09:46 2009 (4A1206DA)
fffff880`01626000 fffff880`016ca000   MegaSR   MegaSR.sys   Mon May 18 21:25:54 2009 (4A120AA2)
fffff880`06d48000 fffff880`06d57000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`06c2e000 fffff880`06c3c000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0443b000 fffff880`0444a000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0101f000 fffff880`01039000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03486000 fffff880`034b7000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`00d8c000 fffff880`00db6000   mpio     mpio.sys     Mon Jul 13 20:01:27 2009 (4A5BCAD7)
fffff880`03d01000 fffff880`03d11000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`03193000 fffff880`031ab000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`031ab000 fffff880`031d8000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03000000 fffff880`0304e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0304e000 fffff880`03071000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01364000 fffff880`0136f000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01039000 fffff880`0105f000   msdsm    msdsm.sys    Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`03525000 fffff880`03530000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fe7000 fffff880`00ff1000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0158f000 fffff880`015ed000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`043dc000 fffff880`043e7000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01fe5000 fffff880`01ff7000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01ef3000 fffff880`01fe5000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045ef000 fffff880`045fb000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`069e8000 fffff880`069fb000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0460e000 fffff880`0463d000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04744000 fffff880`04759000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`04324000 fffff880`04333000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`0356c000 fffff880`035b1000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`016ca000 fffff880`016da000   nfrd960  nfrd960.sys  Tue Jun 06 17:11:48 2006 (4485EF94)
fffff880`03d11000 fffff880`03d26000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`03530000 fffff880`03541000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`043d0000 fffff880`043dc000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c0f000 fffff800`031ec000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01a21000 fffff880`01bc4000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`034b7000 fffff880`034c0000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0105f000 fffff880`01088000   nvraid   nvraid.sys   Wed May 20 02:39:40 2009 (4A13A5AC)
fffff880`016da000 fffff880`01705000   nvstor   nvstor.sys   Wed May 20 02:45:37 2009 (4A13A711)
fffff880`06995000 fffff880`069e8000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`042e8000 fffff880`0430e000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00db6000 fffff880`00dcb000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d59000 fffff880`00d8c000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`010b8000 fffff880`010bf000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00c64000 fffff880`00c74000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01d03000 fffff880`01d14000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`04759000 fffff880`047ff000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0673c000 fffff880`06779000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ce7000 fffff880`00cfb000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0183f000 fffff880`019e3000   ql2300   ql2300.sys   Thu Jan 22 18:05:06 2009 (4978FBA2)
fffff880`01705000 fffff880`01764000   ql40xx   ql40xx.sys   Mon May 18 21:18:11 2009 (4A1208D3)
fffff880`0345f000 fffff880`03483000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0463d000 fffff880`04658000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04658000 fffff880`04679000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04679000 fffff880`04693000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0437f000 fffff880`043d0000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0350a000 fffff880`03513000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03513000 fffff880`0351c000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0351c000 fffff880`03525000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01d87000 fffff880`01dc1000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`06800000 fffff880`06818000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`035b1000 fffff880`035ea000   Rt64win7 Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
fffff880`01d6a000 fffff880`01d87000   sbp2port sbp2port.sys Mon Jul 13 19:19:53 2009 (4A5BC119)
fffff880`03087000 fffff880`03092000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`019e3000 fffff880`019f1000   SiSRaid2 SiSRaid2.sys Wed Sep 24 14:28:20 2008 (48DA86C4)
fffff880`01800000 fffff880`01818000   sisraid4 sisraid4.sys Wed Oct 01 17:56:04 2008 (48E3F1F4)
fffff880`01edd000 fffff880`01ee5000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`03c6b000 fffff880`03d01000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`03c04000 fffff880`03c6b000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06600000 fffff880`0662d000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`01818000 fffff880`01822000   stexstor stexstor.sys Tue Feb 17 18:03:36 2009 (499B4248)
fffff880`01302000 fffff880`01364000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`04693000 fffff880`04694480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`03400000 fffff880`03449000   SynTP    SynTP.sys    Thu Jun 18 22:33:58 2009 (4A3AF916)
fffff880`03092000 fffff880`030a4000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0355f000 fffff880`0356c000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`03541000 fffff880`0355f000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`0436b000 fffff880`0437f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0422f000 fffff880`04255000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`046d8000 fffff880`046ea000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06dc2000 fffff880`06ddf000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04439000 fffff880`0443af00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`05be3000 fffff880`05bf4000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`046ea000 fffff880`04744000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`05b8d000 fffff880`05be3000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05b80000 fffff880`05b8d000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`06c00000 fffff880`06c2d200   usbvideo usbvideo.sys Wed Mar 03 23:40:57 2010 (4B8F39D9)
fffff880`00ff1000 fffff880`00ffe000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`034c7000 fffff880`034d5000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`010bf000 fffff880`010c7000   viaide   viaide.sys   Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`034d5000 fffff880`034fa000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00dd7000 fffff880`00dec000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01d1e000 fffff880`01d6a000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01764000 fffff880`0178e000   vsmraid  vsmraid.sys  Fri Jan 30 20:18:57 2009 (4983A701)
fffff880`045e2000 fffff880`045ef000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`0430e000 fffff880`04324000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`04350000 fffff880`0436b000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`034fa000 fffff880`0350a000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`01ed5000 fffff880`01edd000   wd       wd.sys       Mon Jul 13 19:19:55 2009 (4A5BC11B)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`042df000 fffff880`042e8000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`00320000   win32k   win32k.sys   unavailable (00000000)
fffff880`043f6000 fffff880`043ff000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fde000 fffff880`00fe7000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06ddf000 fffff880`06e00000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`030a4000 fffff880`030ac000   XAudio64 XAudio64.sys Wed Apr 29 14:21:07 2009 (49F89A93)
Unloaded modules:
fffff880`03d7e000 fffff880`03daf000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`03d63000 fffff880`03d7e000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`03d5c000 fffff880`03d63000   RimUsb_AMD64
    Checksum:  00000000
    ImageSize:  00007000
fffff880`03db9000 fffff880`03dea000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`03d9e000 fffff880`03db9000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`03d97000 fffff880`03d9e000   RimUsb_AMD64
    Checksum:  00000000
    ImageSize:  00007000
fffff880`03d26000 fffff880`03d97000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01ee5000 fffff880`01ef3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01c16000 fffff880`01c22000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01c22000 fffff880`01c2d000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01c2d000 fffff880`01c40000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04333000 fffff880`04350000   serial.sys
    Checksum:  00000000
    ImageSize:  0001D000
#10
Just a quick update: still crashing, but not as often. I had waited to see if the Win7 SP1 would help, and it seems to have done a little at least. Anyway, went back thru the drivers and found 2 more to update. Gave that a try tonight; we'll see what comes of it. But from my research, it seems like the Atheros Wireless driver is not a friendly guy.
#11
partner.atheros.com/Drivers.aspx
