* Bugcheck Analysis *
BugCheck A0, {101, 7, c9fb6710, 0}
*** WARNING: Unable to verify timestamp for VMkbd.sys
*** ERROR: Module load completed but symbols could not be loaded for VMkbd.sys
Probably caused by : VMkbd.sys ( VMkbd+1567 )
Followup: MachineOwner
thanks for posting the dump files..
Most are like the above (caused by the power policy manager experiencing a fatal error). There was one solitary dump file, a bugcheck 7F which can be caused by failed hardware (usually RAM) although drivers can also be blamed.
All the dump files named VMkbd.sys as a probable cause:
VMkbd.sys Wed Jun 24 21:21:46 2015: VMware keyboard filter driver. Your system seems unhappy with this driver and if possible please remove it whilst we test (
this you have already done yes?), you may have to use a different keyboard so if you have a spare or could lend one from a friend even better.
ASACPI.sys Wed Oct 18 06:44:46 2006: Asus ATK0110 ACPI Utility (a known BSOD maker in Win7 and Win8). Also a part of many Asus utilities please remove to test.
Would you mind removing AVG and installing MSE please? We ask this as AVG is known for issues on odd occasions and MSE is ultra stable:
https://support.microsoft.com/en-gb/help/14210/security-essentials-download
sptd.sys Thu Dec 11 14:51:42 2014: SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Windows) please remove to test.
Please find command prompt in the start menu, right click on it and run as administrator. Type:
sfc /scannow
Press enter and await results.
Your motherboard support page is here:
P5K/EPU - Support
Post back with any new dump files.
