Windows 7 BSOD on Sony laptop
chojnacj
Hello,
I've been having intermittent BSOD on my 1-year old Sony laptop. I've read up about some of the problems but I'm still very confused. I've attached a .zip of a recent dump file.
Any help is greatly appreciated. This is driving me insane.
BugCheck 7F, {8, 80050031, 406f8, fffff800032c1510}
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )
The problem comes from a bunch of outdated drivers in your system. I think a 1 year old lappy should have 7-compatible updates at its support site:
Sony Firmware Extension Parser driver for VAIO Series
SFEP.sys Fri Aug 03 01:35:53 2007
ATI
atikmdag.sys Fri Jul 10 12:34:38 2009
Touchpad
Apfiltr.sys Tue Jun 16 18:09:26 2009
ArcSoft Magic-i Visual Effect
ArcSoftKsUFilter.sys Mon May 25 04:27:31 2009
Intel Matrix Storage
iaStor.sys Thu Jun 04 21:53:40 2009
Intel WiFi
netw5v64.sys Thu May 14 11:51:34 2009
VSO Software Patin...
ATI
Touchpad
Intel WiFi
VSO Software Patin Couffin
pcouffin.sys Tue Dec 05 09:39:30 2006
Inter Video
regi.sys Mon Apr 16 11:19:10 2007
Ricoh Memorystick Controller
rimssn64.sys Wed Jun 10 22:22:31 2009
risdsn64.sys Thu Jun 11 23:49:37 2009
Realtek HD Audio
RTKVHD64.sys Thu Jul 02 05:42:36 2009
RtHDMIVX.sys Thu Jul 16 23:52:36 2009
Marvell Yukon Ethernet Controller
yk62x64.sys Mon Feb 23 10:02:27 2009
I'm not telling you to replace Norton with MSE because it'll work well once you update the said drivers above.
CRASH DUMPS
Loading Dump File [F:\DMP\042611-42915-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.20826.amd64fre.win7_ldr.101026-1502
Machine Name:
Kernel base = 0xfffff800`0325d000 PsLoadedModuleList = 0xfffff800`03491eb0
Debug session time: Tue Apr 26 15:59:37.574 2011 (UTC - 4:00)
System Uptime: 0 days 5:39:28.493
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
0: kd> !analyze -v
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault).  The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
        use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
        use .trap on that value
Else
        .trap on the appropriate frame will show where the trap was taken
        (on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000406f8
Arg4: fffff800032c1510
Debugging Details:
BUGCHECK_STR:  0x7f_8
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  firefox.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffff8800b40cfc0 -- (.trap 0xfffff8800b40cfc0)
Unable to read trap frame at fffff880`0b40cfc0
LAST_CONTROL_TRANSFER:  from fffff800032c2ae9 to fffff800032c3580
STACK_TEXT:
fffff800`00ba4d28 fffff800`032c2ae9 : 00000000`0000007f 00000000`00000008 00000000`80050031 00000000`000406f8 : nt!KeBugCheckEx
fffff800`00ba4d30 fffff800`032c0fb2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`00ba4e70 fffff800`032c1510 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
fffff880`0b40cfc0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x10
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`032c0fb2 90              nop
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiDoubleFaultAbort+b2
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4cc792b2
FAILURE_BUCKET_ID:  X64_0x7f_8_nt!KiDoubleFaultAbort+b2
DRIVERS
fffff880`05d9e000 fffff880`05ddc000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00ec2000 fffff880`00f19000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`09a38000 fffff880`09a50000   adfs     adfs.SYS     Thu Jun 26 16:52:37 2008 (48640195)
fffff880`04006000 fffff880`04090000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`041cb000 fffff880`041e1000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0136d000 fffff880`01378000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`045aa000 fffff880`045ed000   Apfiltr  Apfiltr.sys  Tue Jun 16 18:09:26 2009 (4A381816)
fffff880`099e3000 fffff880`099ed000   ArcSoftKsUFilter ArcSoftKsUFilter.sys Mon May 25 04:27:31 2009 (4A1A5673)
fffff880`04af2000 fffff880`05109000   atikmdag atikmdag.sys Fri Jul 10 12:34:38 2009 (4A576D9E)
fffff960`008a0000 fffff960`00901000   ATMFD    ATMFD.DLL    Fri Feb 18 23:13:38 2011 (4D5F4372)
fffff880`00f8a000 fffff880`00f96000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`03e29000 fffff880`03e30000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04430000 fffff880`04548000   BHDrvx64 BHDrvx64.sys Wed Apr 13 20:16:01 2011 (4DA63CC1)
fffff880`04200000 fffff880`04211000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`029c7000 fffff880`029e5000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`006a0000 fffff960`006c7000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`02f45000 fffff880`02f6f000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cf1000 fffff880`00db1000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01400000 fffff880`01430000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c93000 fffff880`00cf1000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05df7000 fffff880`05dfb500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`01721000 fffff880`01794000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`00f81000 fffff880`00f8a000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`04211000 fffff880`04221000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`09a50000 fffff880`09a59000   cpuz133_x64 cpuz133_x64.sys Tue Mar 30 17:34:16 2010 (4BB26E58)
fffff880`099ed000 fffff880`099fb000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0435b000 fffff880`043de000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`043de000 fffff880`043fc000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0434c000 fffff880`0435b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0181b000 fffff880`01831000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05f93000 fffff880`05fb5000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05fe9000 fffff880`05ffc000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`02e12000 fffff880`02f2e000   dump_iaStor dump_iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`09b65000 fffff880`09b71000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`05109000 fffff880`051fd000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04a00000 fffff880`04a46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`042b1000 fffff880`04327000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`03e00000 fffff880`03e20000   ENG64    ENG64.SYS    Fri Mar 04 17:02:16 2011 (4D716168)
fffff880`04327000 fffff880`0434c000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`03e37000 fffff880`03ffa000   EX64     EX64.SYS     Fri Mar 04 17:10:51 2011 (4D71636B)
fffff880`013c4000 fffff880`013d8000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01378000 fffff880`013c4000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`017a5000 fffff880`017af000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0164c000 fffff880`01686000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`017af000 fffff880`017f9000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04400000 fffff880`0440d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03214000 fffff800`0325d000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04a46000 fffff880`04a6a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`09b9a000 fffff880`09ba2080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`028ff000 fffff880`029c7000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01812000 fffff880`0181b000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0458c000 fffff880`045aa000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01251000 fffff880`0136d000   iaStor   iaStor.sys   Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`04236000 fffff880`042b1000   IDSvia64 IDSvia64.sys Fri Mar 11 21:15:42 2011 (4D7AD74E)
fffff880`0440d000 fffff880`04423000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`03d6e000 fffff880`03d9b000   Ironx64  Ironx64.SYS  Fri Nov 12 18:06:50 2010 (4CDDC88A)
fffff880`04ade000 fffff880`04aed000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bc1000 fffff800`00bcb000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`00fab000 fffff880`00fee000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01707000 fffff880`01721000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0198d000 fffff880`019b8000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05fb5000 fffff880`05fba200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`09a00000 fffff880`09a15000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`09bb1000 fffff880`09bd4000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c3b000 fffff880`00c7f000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`09ba3000 fffff880`09bb1000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`045ed000 fffff880`045fc000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01154000 fffff880`0116e000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`029e5000 fffff880`029fd000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02800000 fffff880`0282d000   mrxsmb   mrxsmb.sys   Wed Feb 23 00:15:23 2011 (4D6497EB)
fffff880`0282d000 fffff880`0287b000   mrxsmb10 mrxsmb10.sys Wed Feb 23 00:15:14 2011 (4D6497E2)
fffff880`09a15000 fffff880`09a38000   mrxsmb20 mrxsmb20.sys Wed Feb 23 00:15:13 2011 (4D6497E1)
fffff880`03c50000 fffff880`03c5b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f22000 fffff880`00f2c000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`016a9000 fffff880`01707000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`041c0000 fffff880`041cb000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01800000 fffff880`01812000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0183b000 fffff880`0192d000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04423000 fffff880`0442f000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`028d4000 fffff880`028e7000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`01200000 fffff880`0122f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05f0f000 fffff880`05f24000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`040bf000 fffff880`040ce000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02f6f000 fffff880`02fb4000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0192d000 fffff880`0198d000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`05863000 fffff880`05d9e000   netw5v64 netw5v64.sys Thu May 14 11:51:34 2009 (4A0C3E06)
fffff880`02f2e000 fffff880`02f3d000   npf      npf.sys      Tue Oct 20 14:00:19 2009 (4ADDFAB3)
fffff880`03c5b000 fffff880`03c6c000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`041b4000 fffff880`041c0000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0325d000 fffff800`03831000   nt       ntkrnlmp.exe Tue Oct 26 22:47:14 2010 (4CC792B2)
fffff880`0143b000 fffff880`015de000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`03e20000 fffff880`03e29000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02881000 fffff880`028d4000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`04099000 fffff880`040bf000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f6c000 fffff880`00f81000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f2c000 fffff880`00f5f000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`04221000 fffff880`04235380   pcouffin pcouffin.sys Tue Dec 05 09:39:30 2006 (457584A2)
fffff880`01794000 fffff880`017a5000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`02a5b000 fffff880`02b01000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05f56000 fffff880`05f93000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c7f000 fffff880`00c93000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`013d8000 fffff880`013e4040   PxHlpa64 PxHlpa64.sys Tue Oct 20 14:08:42 2009 (4ADDFCAA)
fffff880`02fb4000 fffff880`02fd8000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`041e1000 fffff880`041fc000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`02fd8000 fffff880`02ff9000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`015de000 fffff880`015f8000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04163000 fffff880`041b4000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`03c97000 fffff880`03ca2000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`03c35000 fffff880`03c3e000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`036f4000 fffff880`03722000   rdpdr    rdpdr.sys    Mon Jul 13 20:18:02 2009 (4A5BCEBA)
fffff880`03c3e000 fffff880`03c47000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03c47000 fffff880`03c50000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0373c000 fffff880`03774000   RDPWD    RDPWD.SYS    Mon Jul 13 20:16:47 2009 (4A5BCE6F)
fffff880`019c0000 fffff880`019fa000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02b01000 fffff880`02b09000   regi     regi.sys     Mon Apr 16 11:19:10 2007 (462393EE)
fffff880`0456e000 fffff880`0458c000   rimssn64 rimssn64.sys Wed Jun 10 22:22:31 2009 (4A306A67)
fffff880`05ddc000 fffff880`05df4000   risdsn64 risdsn64.sys Thu Jun 11 23:49:37 2009 (4A31D051)
fffff880`028e7000 fffff880`028ff000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05f24000 fffff880`05f55300   RtHDMIVX RtHDMIVX.sys Thu Jul 16 23:52:36 2009 (4A5FF584)
fffff880`09808000 fffff880`099c3380   RTKVHD64 RTKVHD64.sys Thu Jul 02 05:42:36 2009 (4A4C810C)
fffff880`02b09000 fffff880`02b14000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05df4000 fffff880`05df6c80   SFEP     SFEP.sys     Fri Aug 03 01:35:53 2007 (46B2BEB9)
fffff880`019b8000 fffff880`019c0000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`03caf000 fffff880`03d6e000   SRTSP64  SRTSP64.SYS  Fri Nov 19 19:17:58 2010 (4CE713B6)
fffff880`03d9b000 fffff880`03db1000   SRTSPX64 SRTSPX64.SYS Fri Nov 19 19:18:10 2010 (4CE713C2)
fffff880`0365f000 fffff880`036f4000   srv      srv.sys      Wed Feb 23 00:16:24 2011 (4D649828)
fffff880`02b53000 fffff880`02bba000   srv2     srv2.sys     Wed Feb 23 00:15:59 2011 (4D64980F)
fffff880`02b14000 fffff880`02b41000   srvnet   srvnet.sys   Wed Feb 23 00:15:49 2011 (4D649805)
fffff880`05dfc000 fffff880`05dfd480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0116e000 fffff880`011df000   SYMDS64  SYMDS64.SYS  Fri Oct 15 13:53:54 2010 (4CB89532)
fffff880`01000000 fffff880`010c9000   SYMEFA64 SYMEFA64.SYS Mon Nov 15 16:56:23 2010 (4CE1AC87)
fffff880`03db1000 fffff880`03de7000   SYMEVENT64x86 SYMEVENT64x86.SYS Fri Jul 30 19:05:59 2010 (4C535AD7)
fffff880`040fd000 fffff880`04163000   SYMNETS  SYMNETS.SYS  Tue Nov 30 18:24:40 2010 (4CF587B8)
fffff880`01a03000 fffff880`01c00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`02b41000 fffff880`02b53000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`03c8a000 fffff880`03c97000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`03722000 fffff880`0372d000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`03c6c000 fffff880`03c8a000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`040e9000 fffff880`040fd000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004d0000 fffff960`004da000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0372d000 fffff880`0373c000   tssecsrv tssecsrv.sys Mon Jul 13 20:16:41 2009 (4A5BCE69)
fffff880`02e00000 fffff880`02e12000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`099c4000 fffff880`099e1000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`099e1000 fffff880`099e2f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04acd000 fffff880`04ade000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05eb5000 fffff880`05f0f000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04a77000 fffff880`04acd000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04a6a000 fffff880`04a77000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`05fbb000 fffff880`05fe8100   usbvideo usbvideo.sys Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`00f5f000 fffff880`00f6c000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`03de7000 fffff880`03df5000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`03c00000 fffff880`03c25000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00f96000 fffff880`00fab000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010f8000 fffff880`01154000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01600000 fffff880`0164c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`040ce000 fffff880`040e9000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`03c25000 fffff880`03c35000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e0f000 fffff880`00eb3000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00eb3000 fffff880`00ec2000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04090000 fffff880`04099000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00312000   win32k   win32k.sys   Wed Mar 02 22:58:01 2011 (4D6F11C9)
fffff880`00f19000 fffff880`00f22000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`09bd4000 fffff880`09bf5000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`05800000 fffff880`05863000   yk62x64  yk62x64.sys  Mon Feb 23 10:02:27 2009 (49A2BA83)
Unloaded modules:
fffff880`03774000 fffff880`037e5000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`09b81000 fffff880`09b9a000   HIDCLASS.SYS
    Checksum:  00000000
    ImageSize:  00019000
fffff880`09b7d000 fffff880`09b81000   btwrchid.sys
    Checksum:  00000000
    ImageSize:  00004000
fffff880`05ea4000 fffff880`05eb4000   BthEnum.sys
    Checksum:  00000000
    ImageSize:  00010000
fffff880`05e18000 fffff880`05ea4000   bthport.sys
    Checksum:  00000000
    ImageSize:  0008C000
fffff880`05e00000 fffff880`05e18000   BTHUSB.sys
    Checksum:  00000000
    ImageSize:  00018000
fffff880`010c9000 fffff880`010f5000   rfcomm.sys
    Checksum:  00000000
    ImageSize:  0002C000
fffff880`04548000 fffff880`04568000   bthpan.sys
    Checksum:  00000000
    ImageSize:  00020000
fffff880`09adf000 fffff880`09b65000   btwaudio.sys
    Checksum:  00000000
    ImageSize:  00086000
fffff880`09a64000 fffff880`09adf000   btwavdt.sys
    Checksum:  00000000
    ImageSize:  0007B000
fffff880`09b71000 fffff880`09b7d000   btwl2cap.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01686000 fffff880`01694000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`02e16000 fffff880`02f32000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`02f32000 fffff880`02f45000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04548000 fffff880`0456e000   tunnel.sys
    Checksum:  00000000
    ImageSize:  00026000
Thanks!
I found and updated most of the drivers. I uninstalled the VSO patin couffin driver, since I'm not using that software anymore. So far so good!
