Windows 7 BSOD Using Utorrent and Occassionally Web Browser
Sukkoi19
Everytime I try to download a torrent I get a few minutes into it and then the screen flickers and I get a BSOD saying IRQ_LESS_THAN_EQUAL. I thought perhaps it was my onboard LAN so switched out to a network card and experienced the same issue. Any help would be appreciated.
System specs:
Win7 Professional 64 bit retail version
Installed a few hours ago preceded by many reinstalls
Asus Crosshair IV
AMD Phenom II 1090T
Corsair Dominator GT cmg4gx3m2b1600c7 X2
ATI HD4850 X2
About 2 months old
Hello and Welcome !
Seems like the crashes has caused by PctWfpFilter64.sys i.e a part of PC Tools please uninstall it completely. Then uninstall your Network drivers completely and reinstall it from a fresh download since it's also pointing to NETIO.sys one of the Network related drivers.
Update the following Drivers:
timntr.sys   Wed Aug 29 18:08:23 2007
tifsfilt.sys Wed Aug 29 18:07:29 2007
tdrpman.sys  Mon Nov 12 19:06:33 2007
snapman.sys  Thu Nov 22 13:49:33 2007
For help in updating drivers follow this article Link Removed - Invalid URL
Bugcheck:
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or...
Hello and Welcome !
Bugcheck:
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8800188a7a0, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ef20e0
 0000000000000000
CURRENT_IRQL:  2
FAULTING_IP:
tcpip! ?? ::FNODOBFM::`string'+56f4
fffff880`0188a7a0 488b01          mov     rax,qword ptr [rcx]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff88004a0d5d0 -- (.trap 0xfffff88004a0d5d0)
rax=fffffa8005863af0 rbx=0000000000000000 rcx=0000000000000000
rdx=fffffa8005863af1 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800188a7a0 rsp=fffff88004a0d760 rbp=0000000000000000
 r8=fffffa8005863af0  r9=00000000000000d0 r10=fffff880009e9e80
r11=fffffa8004ab9340 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe nc
tcpip! ?? ::FNODOBFM::`string'+0x56f4:
fffff880`0188a7a0 488b01          mov     rax,qword ptr [rcx] ds:07ff:00000000`00000000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002cb9ca9 to fffff80002cba740
STACK_TEXT:
fffff880`04a0d488 fffff800`02cb9ca9 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`04a0d490 fffff800`02cb8920 : 00000000`00000011 fffffa80`088d4030 fffffa80`00000014 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`04a0d5d0 fffff880`0188a7a0 : fffffa80`088d4030 fffff880`01614aca fffff880`206c644d fffffa80`088a46b0 : nt!KiPageFault+0x260
fffff880`04a0d760 fffff880`0173f6a6 : fffffa80`088d4030 00000000`00000000 00000000`00000001 00000000`00000000 : tcpip! ?? ::FNODOBFM::`string'+0x56f4
fffff880`04a0d7b0 fffff880`0173d35d : 00000000`00000000 fffffa80`088a46b0 00000000`00000000 00000000`00000001 : NETIO!NetioDereferenceNetBufferList+0x86
fffff880`04a0d7e0 fffff880`0183cae6 : 00000000`00000000 fffffa80`04bcdb01 00000000`00000020 fffffa80`088d4030 : NETIO!NetioDereferenceNetBufferListChain+0x2dd
fffff880`04a0d860 fffff880`018bff7c : fffffa80`088a46b0 fffff880`0196c9a0 fffff880`0196c9a0 00000000`00000000 : tcpip!IppCompleteAndFreePacketList+0xc6
fffff880`04a0d890 fffff880`01935542 : fffffa80`07cace90 00000000`00000000 fffffa80`0596d801 00000000`00001460 : tcpip! ?? ::FNODOBFM::`string'+0x42f8d
fffff880`04a0da90 fffff880`01148afa : fffffa80`05eee002 fffffa80`05eee010 00000000`00000002 00000000`00000000 : tcpip!IppInspectInjectReceive+0xf2
fffff880`04a0dad0 fffff880`0160d71d : fffffa80`06a69530 fffffa80`0596d8e0 00000000`c0000000 fffff880`00000000 : fwpkclnt!FwpsInjectTransportReceiveAsync0+0x256
fffff880`04a0db80 fffffa80`06a69530 : fffffa80`0596d8e0 00000000`c0000000 fffff880`00000000 fffffa80`06640002 : PctWfpFilter64+0xd71d
fffff880`04a0db88 fffffa80`0596d8e0 : 00000000`c0000000 fffff880`00000000 fffffa80`06640002 fffffa80`00000001 : 0xfffffa80`06a69530
fffff880`04a0db90 00000000`c0000000 : fffff880`00000000 fffffa80`06640002 fffffa80`00000001 fffffa80`00000013 : 0xfffffa80`0596d8e0
fffff880`04a0db98 fffff880`00000000 : fffffa80`06640002 fffffa80`00000001 fffffa80`00000013 fffffa80`00000000 : 0xc0000000
fffff880`04a0dba0 fffffa80`06640002 : fffffa80`00000001 fffffa80`00000013 fffffa80`00000000 fffffa80`00000000 : 0xfffff880`00000000
fffff880`04a0dba8 fffffa80`00000001 : fffffa80`00000013 fffffa80`00000000 fffffa80`00000000 fffff880`0160d250 : 0xfffffa80`06640002
fffff880`04a0dbb0 fffffa80`00000013 : fffffa80`00000000 fffffa80`00000000 fffff880`0160d250 fffffa80`0596d8e0 : 0xfffffa80`00000001
fffff880`04a0dbb8 fffffa80`00000000 : fffffa80`00000000 fffff880`0160d250 fffffa80`0596d8e0 00000000`53636670 : 0xfffffa80`00000013
fffff880`04a0dbc0 fffffa80`00000000 : fffff880`0160d250 fffffa80`0596d8e0 00000000`53636670 fffffa80`088a46b0 : 0xfffffa80`00000000
fffff880`04a0dbc8 fffff880`0160d250 : fffffa80`0596d8e0 00000000`53636670 fffffa80`088a46b0 fffff880`0161c338 : 0xfffffa80`00000000
fffff880`04a0dbd0 fffffa80`0596d8e0 : 00000000`53636670 fffffa80`088a46b0 fffff880`0161c338 00000000`00000000 : PctWfpFilter64+0xd250
fffff880`04a0dbd8 00000000`53636670 : fffffa80`088a46b0 fffff880`0161c338 00000000`00000000 00000000`00000000 : 0xfffffa80`0596d8e0
fffff880`04a0dbe0 fffffa80`088a46b0 : fffff880`0161c338 00000000`00000000 00000000`00000000 00000000`53636670 : 0x53636670
fffff880`04a0dbe8 fffff880`0161c338 : 00000000`00000000 00000000`00000000 00000000`53636670 fffffa80`05b319a0 : 0xfffffa80`088a46b0
fffff880`04a0dbf0 00000000`00000000 : 00000000`00000000 00000000`53636670 fffffa80`05b319a0 fffff880`0161f128 : PctWfpFilter64+0x1c338
STACK_COMMAND:  kb
FOLLOWUP_IP:
NETIO!NetioDereferenceNetBufferList+86
fffff880`0173f6a6 4885ff          test    rdi,rdi
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  NETIO!NetioDereferenceNetBufferList+86
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: NETIO
IMAGE_NAME:  NETIO.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc18a
FAILURE_BUCKET_ID:  X64_0xD1_NETIO!NetioDereferenceNetBufferList+86
Followup: MachineOwner
Hope this helps,
Captain
I read your driver update utility and followed the steps to updating those drivers you listed. However they appear to be part of Acronis True Image and I am having difficulty finding an updated driver. This is perhaps caused my own ignorance. Do you perhaps know of a good place to find the drivers. Googling them seems to pull up only Acronis website and people asking what the heck they are. Thanks for the help.
I added a file from the Windows Diagnostic utility if that helps any. Again thanks for the help.
Remove PC Tools with the use of RevoUninstaller:
Download Revo Uninstaller Freeware - Free and Full Download - Uninstall software, remove programs, solve uninstall problems
Replace it with MS Security Essentials:
Link Removed due to 404 Error
Update or uninstall Acronis:
tifsfilt.sys Wed Aug 29 08:37:29 2007
Enjoy the holidays. : )
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\122910-23743-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c1a000 PsLoadedModuleList = 0xfffff800`02e57e50
Debug session time: Thu Dec 30 00:23:22.110 2010 (UTC - 5:00)
System Uptime: 0 days 0:05:02.453
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {0, 2, 0, fffff880018897a0}
Unable to load image \Device\Harddisk0\Partition2\Windows\system32\drivers\PctWfpFilter64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for PctWfpFilter64.sys
*** ERROR: Module load completed but symbols could not be loaded for PctWfpFilter64.sys
Probably caused by : NETIO.SYS ( NETIO!NetioDereferenceNetBufferList+86 )
2: kd> !analyze -v
Arguments:
Arg4: fffff880018897a0, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ec20e0
 0000000000000000
CURRENT_IRQL:  2
FAULTING_IP:
fffff880`018897a0 488b01          mov     rax,qword ptr [rcx]
BUGCHECK_STR:  0xD1
TRAP_FRAME:  fffff880035e85d0 -- (.trap 0xfffff880035e85d0)
rax=fffffa800419b750 rbx=0000000000000000 rcx=0000000000000000
rdx=fffffa800419b751 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880018897a0 rsp=fffff880035e8760 rbp=0000000000000000
 r8=fffffa800419b750  r9=00000000000000d0 r10=fffff88003163e80
r11=fffffa800779cb50 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po nc
fffff880`018897a0 488b01          mov     rax,qword ptr [rcx] ds:07ff:00000000`00000000=????????????????
LAST_CONTROL_TRANSFER:  from fffff80002c89ca9 to fffff80002c8a740
STACK_TEXT:
fffff880`035e8488 fffff800`02c89ca9 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`035e8490 fffff800`02c88920 : 00000000`00000011 fffffa80`07d94030 fffffa80`00000014 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`035e85d0 fffff880`018897a0 : fffffa80`07d94030 fffff880`042f4aca fffff880`206c644d fffffa80`05dbb2b0 : nt!KiPageFault+0x260
fffff880`035e8760 fffff880`017326a6 : fffffa80`07d94030 00000000`00000000 00000000`00000001 00000000`00000000 : tcpip! ?? ::FNODOBFM::`string'+0x56f4
fffff880`035e87b0 fffff880`0173035d : 00000000`00000000 fffffa80`05dbb2b0 00000000`00000000 00000000`00000001 : NETIO!NetioDereferenceNetBufferList+0x86
fffff880`035e87e0 fffff880`0183bae6 : 00000000`00000000 fffffa80`04bbac01 00000000`00000020 fffffa80`07d94030 : NETIO!NetioDereferenceNetBufferListChain+0x2dd
fffff880`035e8860 fffff880`018bef7c : fffffa80`05dbb2b0 fffff880`0196b9a0 fffff880`0196b9a0 00000000`00000000 : tcpip!IppCompleteAndFreePacketList+0xc6
fffff880`035e8890 fffff880`01934542 : fffffa80`07f7de00 00000000`00000000 fffffa80`03ff0501 00000000`00000528 : tcpip! ?? ::FNODOBFM::`string'+0x42f8d
fffff880`035e8a90 fffff880`01519afa : fffffa80`040f4902 fffffa80`040f4920 00000000`00000002 00000000`00000000 : tcpip!IppInspectInjectReceive+0xf2
fffff880`035e8ad0 fffff880`042ed71d : fffffa80`0702a140 fffffa80`03ff05f0 00000000`c0000000 fffff880`00000000 : fwpkclnt!FwpsInjectTransportReceiveAsync0+0x256
fffff880`035e8b80 fffffa80`0702a140 : fffffa80`03ff05f0 00000000`c0000000 fffff880`00000000 fffffa80`06cf0002 : PctWfpFilter64+0xd71d
fffff880`035e8b88 fffffa80`03ff05f0 : 00000000`c0000000 fffff880`00000000 fffffa80`06cf0002 fffffa80`00000001 : 0xfffffa80`0702a140
fffff880`035e8b90 00000000`c0000000 : fffff880`00000000 fffffa80`06cf0002 fffffa80`00000001 fffffa80`00000013 : 0xfffffa80`03ff05f0
fffff880`035e8b98 fffff880`00000000 : fffffa80`06cf0002 fffffa80`00000001 fffffa80`00000013 fffffa80`00000000 : 0xc0000000
fffff880`035e8ba0 fffffa80`06cf0002 : fffffa80`00000001 fffffa80`00000013 fffffa80`00000000 fffffa80`00000000 : 0xfffff880`00000000
fffff880`035e8ba8 fffffa80`00000001 : fffffa80`00000013 fffffa80`00000000 fffffa80`00000000 fffff880`042ed250 : 0xfffffa80`06cf0002
fffff880`035e8bb0 fffffa80`00000013 : fffffa80`00000000 fffffa80`00000000 fffff880`042ed250 fffffa80`03ff05f0 : 0xfffffa80`00000001
fffff880`035e8bb8 fffffa80`00000000 : fffffa80`00000000 fffff880`042ed250 fffffa80`03ff05f0 00000000`53636670 : 0xfffffa80`00000013
fffff880`035e8bc0 fffffa80`00000000 : fffff880`042ed250 fffffa80`03ff05f0 00000000`53636670 fffffa80`05dbb2b0 : 0xfffffa80`00000000
fffff880`035e8bc8 fffff880`042ed250 : fffffa80`03ff05f0 00000000`53636670 fffffa80`05dbb2b0 fffff880`042fc338 : 0xfffffa80`00000000
fffff880`035e8bd0 fffffa80`03ff05f0 : 00000000`53636670 fffffa80`05dbb2b0 fffff880`042fc338 00000000`00000000 : PctWfpFilter64+0xd250
fffff880`035e8bd8 00000000`53636670 : fffffa80`05dbb2b0 fffff880`042fc338 00000000`00000000 00000000`00000000 : 0xfffffa80`03ff05f0
fffff880`035e8be0 fffffa80`05dbb2b0 : fffff880`042fc338 00000000`00000000 00000000`00000000 00000000`53636670 : 0x53636670
fffff880`035e8be8 fffff880`042fc338 : 00000000`00000000 00000000`00000000 00000000`53636670 fffffa80`06c97db0 : 0xfffffa80`05dbb2b0
fffff880`035e8bf0 00000000`00000000 : 00000000`00000000 00000000`53636670 fffffa80`06c97db0 fffff880`042ff128 : PctWfpFilter64+0x1c338
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`017326a6 4885ff          test    rdi,rdi
MODULE_NAME: NETIO
Drivers:
fffff880`04424000 fffff880`04462000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00eac000 fffff880`00f03000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`04305000 fffff880`0438f000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`052a6000 fffff880`052bc000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`02f84000 fffff880`02f99000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00e96000 fffff880`00ea1000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`05285000 fffff880`0528d000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`02eb2000 fffff880`02eb8000   AsIO     AsIO.sys     Mon Aug 03 03:03:16 2009 (4A768BB4)
fffff880`09871000 fffff880`0987c000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e8d000 fffff880`00e96000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fcc000 fffff880`00ff6000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0586f000 fffff880`0588f000   AtihdW76 AtihdW76.sys Fri Sep 24 01:44:48 2010 (4C9C3AD0)
fffff880`04a0b000 fffff880`05200000   atikmdag atikmdag.sys Tue Oct 26 22:29:53 2010 (4CC78EA1)
fffff880`02f99000 fffff880`02fe4000   atikmpag atikmpag.sys Tue Oct 26 22:14:23 2010 (4CC78AFF)
fffff880`01634000 fffff880`0163b000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02ea1000 fffff880`02eb2000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02bdf000 fffff880`02bfd000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00790000 fffff960`007b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`099a4000 fffff880`099c1000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`01400000 fffff880`0142a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01594000 fffff880`015c4000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cfb000 fffff880`00d59000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0142a000 fffff880`0146c000   cmdguard cmdguard.sys Fri Sep 10 18:07:10 2010 (4C8AAC0E)
fffff880`0427f000 fffff880`0428a000   cmdhlp   cmdhlp.sys   Fri Sep 10 18:06:39 2010 (4C8AABEF)
fffff880`01482000 fffff880`014f5000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`05296000 fffff880`052a6000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0600e000 fffff880`0601c000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02e00000 fffff880`02e83000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`02e83000 fffff880`02ea1000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02f75000 fffff880`02f84000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01612000 fffff880`01628000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`058cc000 fffff880`058ee000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06028000 fffff880`06031000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0601c000 fffff880`06028000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`058f4000 fffff880`05907000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06031000 fffff880`0603d000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`044ae000 fffff880`045a2000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`045a2000 fffff880`045e8000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`09980000 fffff880`099a3980   E1G6032E E1G6032E.sys Wed May 28 19:14:51 2008 (483DE76B)
fffff880`01002000 fffff880`01016000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00f0c000 fffff880`00f58000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01506000 fffff880`01510000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0155a000 fffff880`01594000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01510000 fffff880`0155a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`031f6000 fffff800`0323f000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04400000 fffff880`04424000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0593e000 fffff880`05957000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`061f3000 fffff880`061fb080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`05930000 fffff880`0593e000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02b17000 fffff880`02bdf000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01a3b000 fffff880`01a44000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04226000 fffff880`0423e000   inspect  inspect.sys  Fri Sep 10 18:07:36 2010 (4C8AAC28)
fffff880`0537c000 fffff880`0538b000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05991000 fffff880`0599f000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bad000 fffff800`00bb7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0539c000 fffff880`053df000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0178e000 fffff880`017b9000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`058ee000 fffff880`058f3200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02aea000 fffff880`02aff000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`059ac000 fffff880`059cf000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cda000 fffff880`00ce7000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`05922000 fffff880`05930000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0538b000 fffff880`0539a000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0599f000 fffff880`059ac000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e73000 fffff880`00e8d000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02a00000 fffff880`02a18000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02a18000 fffff880`02a45000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`02a45000 fffff880`02a93000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`02a93000 fffff880`02ab6000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`013eb000 fffff880`013f6000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f58000 fffff880`00f62000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01196000 fffff880`011f4000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02f6a000 fffff880`02f75000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01600000 fffff880`01612000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0163c000 fffff880`0172e000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`052e0000 fffff880`052ec000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`052ec000 fffff880`0531b000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0585a000 fffff880`0586f000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`043e8000 fffff880`043f7000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`0438f000 fffff880`043d4000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0172e000 fffff880`0178e000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`04243000 fffff880`04254000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02f5e000 fffff880`02f6a000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c1a000 fffff800`031f6000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01248000 fffff880`013eb000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0146c000 fffff880`01475000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`05200000 fffff880`05218000   nusb3hub nusb3hub.sys Thu Jan 21 22:22:18 2010 (4B5919EA)
fffff880`04462000 fffff880`04492000   nusb3xhc nusb3xhc.sys Thu Jan 21 22:22:21 2010 (4B5919ED)
fffff880`04200000 fffff880`04226000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fa2000 fffff880`00fb7000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`099c1000 fffff880`099ca000   pbfilter pbfilter.sys Sat Nov 06 22:23:54 2010 (4CD60DBA)
fffff880`00f62000 fffff880`00f95000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e63000 fffff880`00e73000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01016000 fffff880`01059000   PCTCore64 PCTCore64.sys Wed Nov 24 00:16:29 2010 (4CEC9FAD)
fffff880`01059000 fffff880`010ca000   pctDS64  pctDS64.sys  Thu Jun 03 22:06:38 2010 (4C085FAE)
fffff880`010ca000 fffff880`01196000   pctEFA64 pctEFA64.sys Fri Jul 16 00:45:25 2010 (4C3FE3E5)
fffff880`0428a000 fffff880`042e0000   pctgntdi64 pctgntdi64.sys Tue Nov 16 15:07:31 2010 (4CE2E483)
fffff880`0992f000 fffff880`09948000   pctplsg64 pctplsg64.sys Wed Nov 24 15:31:41 2010 (4CED762D)
fffff880`09922000 fffff880`0992e0e0   PCTSDInj64 PCTSDInj64.sys Tue Aug 31 20:31:02 2010 (4C7D9EC6)
fffff880`042e0000 fffff880`04305000   PctWfpFilter64 PctWfpFilter64.sys Tue Nov 16 15:17:57 2010 (4CE2E6F5)
fffff880`014f5000 fffff880`01506000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`08c82000 fffff880`08d28000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0588f000 fffff880`058cc000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ce7000 fffff880`00cfb000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`052bc000 fffff880`052e0000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0531b000 fffff880`05336000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05336000 fffff880`05357000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05357000 fffff880`05371000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02f0d000 fffff880`02f5e000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`05371000 fffff880`0537c000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`015f5000 fffff880`015fe000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01475000 fffff880`0147e000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0123f000 fffff880`01248000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`017b9000 fffff880`017f3000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`09948000 fffff880`0994f000   RivaTuner64 RivaTuner64.sys Tue Jul 17 15:13:42 2007 (469D14E6)
fffff880`02aff000 fffff880`02b17000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`08d28000 fffff880`08d33000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01a00000 fffff880`01a3b000   snapman  snapman.sys  Thu Nov 22 03:19:33 2007 (47453B95)
fffff880`01be8000 fffff880`01bf0000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`09800000 fffff880`09871000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`0988c000 fffff880`09922000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`08d72000 fffff880`08dd9000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`08d33000 fffff880`08d60000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`0539a000 fffff880`0539b480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`08d60000 fffff880`08d72000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`04272000 fffff880`0427f000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01b54000 fffff880`01be8000   tdrpman  tdrpman.sys  Mon Nov 12 08:36:33 2007 (473856E1)
fffff880`04254000 fffff880`04272000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02ef9000 fffff880`02f0d000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff880`059cf000 fffff880`059e6000   tifsfilt tifsfilt.sys Wed Aug 29 08:37:29 2007 (46D56889)
fffff880`01a48000 fffff880`01af8000   timntr   timntr.sys   Wed Aug 29 08:38:23 2007 (46D568BF)
fffff960`00590000 fffff960`0059a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`02eb8000 fffff880`02ede000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`053df000 fffff880`053f1000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05957000 fffff880`05974000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04492000 fffff880`04493f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`05274000 fffff880`05285000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04494000 fffff880`044a1000   usbfilter usbfilter.sys Wed Oct 07 03:44:08 2009 (4ACC46C8)
fffff880`05800000 fffff880`0585a000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`044a1000 fffff880`044ac000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0521e000 fffff880`05274000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05974000 fffff880`05980000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`05980000 fffff880`05991000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`05907000 fffff880`05922000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00f95000 fffff880`00fa2000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`015d7000 fffff880`015e5000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`06042000 fffff880`061f3000   viahduaa viahduaa.sys Tue Mar 02 06:30:18 2010 (4B8CF6CA)
fffff880`0121a000 fffff880`0123f000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`06000000 fffff880`0600e000   VMfilt64 VMfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
fffff880`01af8000 fffff880`01b08000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fb7000 fffff880`00fcc000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01b08000 fffff880`01b54000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02ede000 fffff880`02ef9000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`015e5000 fffff880`015f5000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00d59000 fffff880`00dfd000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00cc0000 fffff880`00ccf000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`043df000 fffff880`043e8000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`00380000   win32k   win32k.sys   unavailable (00000000)
fffff880`0528d000 fffff880`05296000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f03000 fffff880`00f0c000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`043d4000 fffff880`043df000   ws2ifsl  ws2ifsl.sys  Mon Jul 13 20:10:33 2009 (4A5BCCF9)
fffff880`02ac9000 fffff880`02aea000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`0994f000 fffff880`09980000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`01bf0000 fffff880`01bfe000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01628000 fffff880`01634000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`017f3000 fffff880`017fc000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`015c4000 fffff880`015d7000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Maybe we need to clarify it a bit, do as follows:
1. Uninstall Acronis
2. Download the latest Acronis from Backup software for data backup and disaster recovery in Windows and Linux - Acronis
3. Acronis 2007 should not be used in Windows 7
