Windows 11 build number 26200.8655 for win 11 home
David Hewitt
Hi all - newbie here
I have a win 11 home pc I bought on 8/04/2026. it has build number 26200.8655. I have spent at least 30 hours over the last 2 days trying to set up a betterdesk server/rustdesk client scenario on it only to finally realise it is missing a whole heap of critical components such as:
  • Entire Terminal Services feature group
  • Multiple System32 administrative tools
  • Windows Installer infrastructure
  • Networking/TLS components
  • Feature payloads required for normal operation
I have now found out that official release date of this build was 9/06/2026. Would this be because at the time it was built , the build the vendors used was incomplete/experimental? I really would like some confirmation to take back to the store to get a fix/compensation etc. Any replies would be much appreciated
NoWuckens
Hi David, welcome to the forum.
Short answer​
No — build 26200.8655 by itself is not evidence that the vendor used an incomplete or experimental Windows image. Microsoft lists 26200.8655 as the June 9, 2026 KB5094126 OS build for Windows 11 version 25H2, applying to all editions of Windows 11 25H2. (support.microsoft.com)
Since you bought the PC on 8 April 2026 and you are checking it on/after 15 June 2026, the most likely explanation is that Windows Update brought the machine up to 26200.8655 after Microsoft released the June update.
About the “missing Terminal Services” part​
Some of what you are seeing may be normal for Windows 11 Home.
Microsoft’s Remote Desktop documentation says the remote PC you connect to must be running Windows Pro, while the client device can be Home/Pro/other OS. (support.microsoft.com) So if by “Terminal Services” you mean RDP host / Remote Desktop server capability, that is not included in Windows 11 Home.
That said, Windows Installer, basic networking/TLS components, System32 tools like services.msc, eventvwr.msc, msiexec.exe, etc. should not simply be missing from a normal Windows 11 Home installation. If those are genuinely absent, that points more toward:
  • A corrupt Windows installation
  • A bad OEM/vendor image
  • A “debloated” or modified Windows image
  • A failed/partial cumulative update
  • Security software or policy damage
  • Disk/file-system corruption
What I’d take back to the store​
I would not lead with “they used an experimental build.” I’d say something like:
“This PC is running an official Microsoft Windows 11 build, but the installation appears incomplete or corrupted. Core Windows components such as Windows Installer and administrative tools appear to be missing or broken. Please restore it with a clean, supported OEM Windows 11 image or replace the unit.”
That is a stronger and more defensible argument.
Quick checks to gather evidence​
Run these in Terminal / Command Prompt as Administrator.
1. Confirm edition, version, and install date​
winver
Then:
systeminfo
Look for:
  • OS Name
  • OS Version
  • Original Install Date
  • System Manufacturer
  • System Model
2. Check whether Windows Installer exists​
where msiexec
sc query msiserver
Expected result:
  • msiexec.exe should normally be found in C:\Windows\System32
  • msiserver should exist as the Windows Installer service
3. Check Windows component health​
DISM /Online /Cleanup-Image /ScanHealth
Then:
sfc /scannow
If DISM or SFC reports corruption that cannot be repaired, that is useful evidence for the store.
4. Check whether it is enrolled in Insider builds​
reg query HKLM\SOFTWARE\Microsoft\WindowsSelfHost\Applicability
If it shows Insider ring/channel information, that would be relevant. Also check:
  1. Open Settings.
  2. Go to Windows Update.
  3. Open Windows Insider Program.
  4. Confirm whether the PC is enrolled.
My recommendation​
Before spending more time on RustDesk/BetterDesk, I would either:
  1. Ask the store to factory reimage the machine with a clean OEM Windows 11 Home image.
  2. Or do a clean reinstall yourself using Microsoft installation media.
  3. If you need proper built-in Remote Desktop hosting or business admin tools, consider Windows 11 Pro, because Home deliberately lacks some of those features.
Do back up your files first before any reset/reinstall. Also, if the PC is only a couple of months old, I’d push the vendor to fix the Windows installation rather than you spending more hours repairing what may be a bad image.
Short answer​
winver
Then:
systeminfo
Look for:
  • OS Name
  • OS Version
  • System Model
where msiexec
sc query msiserver
Expected result:
Then:
sfc /scannow
  1. Open Settings.
My recommendation​
checked registry insider key - exists and contains details - should this key exist on a normal build. Also checked the WinSxS on the installation usb versus WinSxS on on the PC - USB has 16788 items whereas PC has 27818 items. - beginning to think this was demo/testing PC that was repurposed will contact venor tomorrow and ask questions
Great news, David — glad you got it sorted.
For anyone else reading the thread later: Windows 11 Home build 26200.8655 is not automatically a sign of an experimental or incomplete install. If core components seem missing, it is worth double-checking the Windows edition limits, update status, and whether the component/service is genuinely absent before assuming the image is bad.
Glad everything is AOK now.
No worries, David.
I don’t have moderator controls to close the thread from here, but a moderator should be able to do it.
In the meantime, you can usually do one of these:
  1. Click Report on your own post and write: Issue sorted — please close thread.
  2. If available, mark the thread/post as Solved.
  3. Edit the thread title and add [Solved] if the forum allows title edits.
Glad it’s all working now.
