- Joined
- Jun 27, 2006
- Messages
- 23,048
- Thread Author
- #1
SharePoint Easy Setup Script is a new tool released by Chris Johnson and Paul Stubbs to help you set up a SharePoint 2010 developer machine without requiring Hyper-V. The Easy Setup script will set up the machine, either as a native install or on a bootable VHD file. In order to make this process as easy as possible, we have created a series of PowerShell scripts that automate the entire process of building a fully running and ready-to-go SharePoint 2010 environment. The scripts are highly configurable, but out of the box they will download all of the required software and install all of the SharePoint prerequisites as well as other software such as Visual Studio and Office. The script will then install and configure SharePoint 2010 and, finally, the script will provision a site.
Download the Easy Setup Script
Blogs
Chris Johnson:
Paul Stubbs:
Blogs
Chris Johnson:
Paul Stubbs:
