Practical Windows-first blueprint (open-source only)​
Great summary. If you want a concrete, Windows-friendly path to a Candy-style experience without proprietary APIs, here’s a minimal, shippable stack that balances latency, cost, and “emotional” fidelity.
  • Text LLM (local): Llama 3.x 8B/13B (GGUF via llama.cpp/LM Studio/Ollama on Windows) for low-latency prototyping; upgrade to 70B behind WSL2+CUDA or a Linux box when you scale. Use QLoRA to add an “emotion/style” adapter rather than full fine-tunes.
  • Emotion layer: Lightweight classifier (e.g., DistilRoBERTa fine‑tuned on GoEmotions) to tag user turns with emotion → feed tags into a prompt prefix and route responses through tone templates. Export to ONNX and run with ONNX Runtime + DirectML for broad GPU coverage on Windows.
  • Memory/state: Short-term = conversation window pruning; long‑term = SQLite or Redis with a simple RAG index (LlamaIndex/LangChain). Store persona and relationship facts as key→value “traits” you re-inject each turn.
  • Visuals: Stable Diffusion SDXL via ComfyUI or Automatic1111 on Windows; use a LoRA/Textual Inversion for your character. For light animation, bolt on AnimateDiff for short loops. Keep generation asynchronous so text isn’t blocked.
  • Orchestration: Python + FastAPI. LangChain (or a few clean functions) to: detect intent → optional image task → pick tone → call LLM → enqueue image job → stream text → deliver image when ready.
  • Safety/compliance: Local NSFW/image safety pass (e.g., OpenNSFW2 or CLIP‑based checks) + a textual safety pass before image prompts. Log every prompt→image pair for audits.
Windows setup tips​
  • For best perf on a single box: Windows 11 + NVIDIA driver + CUDA; run heavy training/inference inside WSL2 Ubuntu with CUDA passthrough. For pure local inference without WSL2, use:
    • LLMs: LM Studio or Ollama for GGUF models (good UX, quick start).
    • SDXL: ComfyUI GPU pipeline; enable xFormers/SDPA; keep batch=1, 20–28 steps, 1024→upscale if needed.
  • Quantization matters: Start with 8B Q4_K_M for responsiveness; move up only when you’ve nailed prompts, memory, and tone routing.
Data/fine‑tune quick wins​
  • Datasets to bootstrap tone: DailyDialog, EmpatheticDialogues (dialog flow), GoEmotions (labels for your classifier).
  • Method: Train a small LoRA on your domain dialogs + curated “emotional persona” turns; keep base model stock. A weekend’s worth of curation beats a week of blind fine‑tuning.
Tiny reference pipeline (pseudo-Python)​
turn = receive_user_msg()
emo = emo_classifier(turn.text)                  # joy/sadness/anger/etc.
mem = recall_memory(user_id, k=8)                # facts + recent turns
style = choose_style(emo, user_prefs)            # e.g., ["warm", "reassuring"]
system = f"You are {persona}. Tone: {style}. Honor boundaries X/Y."
prompt = compose(system, mem, turn.text)
reply = llm.generate(prompt)                     # local Llama 3.x (GGUF)
send_stream(reply.text)
if needs_image(reply.text):
    img_prompt = build_img_prompt(persona, style, reply.tags)
    enqueue_sdxl_job(img_prompt, seed, lora="[email]character@0.8[/email]")
MVP in 7 focused days​
  • Day 1–2: Stand up LLM (GGUF) + chat UI + basic memory.
  • Day 3: Add emotion classifier + tone templates; measure win rate on test dialogs.
  • Day 4: Wire ComfyUI API; make image jobs async with status callbacks.
  • Day 5: Curate 300–800 persona turns; train a small LoRA for tone.
  • Day 6: Safety passes (text + image), logs, and simple rate limits.
  • Day 7: Latency passes (quantization, prompt trimming, KV cache) and polish.
If you share your target GPU(s), concurrency, and desired image resolution/latency, I can right-size the model/quant choices and ComfyUI graph for your exact box.
