Catalyst Mods and Tweaks
1.
Removing Narrow and Wide-tent filters and replacing them with the drop-down options as in 6000 series, Standard and Edge-detect:
[B]Windows Registry Editor Version 5.00[/B]
[B][HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\UMD][/B]
[B]"AAF_Value_SET"="Standard:0,Edge-detect:3"[/B]
[B]"AAF_Mapping_SET"="0(Standard:2,Edge-detect:12) 2(Standard:2) 4(Standard:4,Edge-detect:12) 8(Standard:8,Edge-detect:24) 16(Standard:16)"[/B]
Standard-Edge-detect.reg
If you want them as in 5000 series Box/Narrow/Wide/Edge:
[B]"AAF_Value_SET"="Box:0,Narrow-tent:1,Wide-tent:2,Edge-detect:3"[/B]
[B]"AAF_Mapping_SET"=""0(Box:2,Narrow-tent:4,Wide-tent:6,Edge-detect:12) 2(Box:2,Narrow-tent:4,Wide-tent:6) 4(Box:4,Narrow-tent:6,Wide-tent:8,Edge-detect:12) 8(Box:8,Narrow-tent:12,Wide-tent:16,Edge-detect:24) 16(Box:16,Narrow-tent:24,Wide-tent:32)"[/B]
2.
EQAA
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000]
"EQAA_NA"="0"
[/B]
3.
Morphological AA
[B]
"MLF_NA"="0"
[/B]
4.
Catalyst A.I. Texture Filtering Quality
[B]
"TFQ_NA"="0"
[/B]
5.
Enable Surface Format Optimization
"SurfaceFormatReplacements_NA"="0"
[/B]
6.
Enable Geometry Instancing
[B]
"GI_NA"="0"
[/B]
7.
High Quality AF
[B]
"AreaAniso_NA"="0"
[/B]
8.
Tesselation slider
[B]
"Tessellation_NA"="0"
[/B]
Before:
After:
Of course the Catalyst version should support these features, otherwise you won't see them.
To unlock all:
Catalyst.reg
"GI_NA"="0"
"AreaAniso_NA"="0"
"EQAA_NA"="0"
"MLF_NA"="0"
"TFQ_NA"="0"
[/B]
View attachment Catalyst.zip
what's the best settings for my integrated ATI Radeon 2100..
pc specs: ATI Radeon 2100 , 3Gb ram @400mhz , AMD Athlon™ x2 64bit 5000+ , Windows 7 Ultimate 64bit Build 7600
