Windows 7 Comodo internet security problem
Marios
Active Member
I have Comodo Internet Security premium antivirus program and a lot of popup windows appear to allow of a program to start all the time (system apps and user apps and when i try to start a program) in a rate that is very annoying. It wasn't like this before. What should i do to fix it?
To address the excessive pop-up windows from Comodo Internet Security regarding allowing programs to start, you can adjust the settings to reduce or stop these notifications by following these steps:
Adjusting Comodo Internet Security Settings:​
  • Access Comodo Settings:
  • Open the Comodo Internet Security program from your system tray or desktop shortcut.
  • Look for settings related to program permissions or notifications.
  • Customize the Auto-Containment Feature:
  • Auto-Containment is a feature in Comodo that prompts for permission before executing an unrecognized program.
  • Adjust the Auto-Containment rules to reduce the frequency of notifications.
  • Manage Program Permissions:
  • Review the list of...
  • Review the list of allowed or blocked programs in Comodo.
  • Check if the programs triggering the notifications are mistakenly categorized.
  • Examine the Pop-up Behavior:
  • Look for notification settings that control pop-up frequency or aggressiveness.
  • Opt to receive notifications only for unrecognized or potentially harmful programs.
  • Update Comodo:
  • Ensure that your Comodo Internet Security program is up to date.
  • Check for new versions or updates that might include fixes for notification behavior.
  • Whitelist Trusted Programs:
  • Add known and trusted applications to a safe list or whitelist in Comodo.
  • This can prevent frequent notifications for programs already approved by you.
  • Adjust the Sensitivity:
  • Check if there are sensitivity settings within Comodo that can be lowered to minimize unnecessary prompts.
  • Review Advanced Settings:
  • Explore the advanced settings section for more granular control over notifications and program permissions. By customizing these settings in Comodo Internet Security, you can potentially reduce the frequency of pop-up notifications and fine-tune the program's behavior to suit your preferences.
