K krkus New Member Joined Jun 6, 2014 Messages 1 Jun 6, 2014 Thread Author #1 Hi, today I turned on my computer and then i rightclicked and .. when i click in Chrome .. and MS paint any tips ?
Solution F F Fixer1234 Jun 6, 2014 On second thought, it's probably a Windows problem, something either corrupted or missing. Try running sfc /scannow from the Start menu Run window.
F Fixer1234 Senior Member Joined Aug 3, 2012 Messages 481 Jun 6, 2014 #2 Wow, that's one I've never seen before. There's two possibilities--the text is either missing or the same color as the background. Other than give you two directions to look, I can't help with either one. Upvote 0 Downvote
F Fixer1234 Senior Member Joined Aug 3, 2012 Messages 481 Jun 6, 2014 #3 On second thought, it's probably a Windows problem, something either corrupted or missing. Try running sfc /scannow from the Start menu Run window. Upvote 1 Downvote Solution
