genius3008
sorry for my bad English. I'm a Vietnamese so if there were any problem with my language, please ignore it. I've known a password of a wifi and have connected it for 4 months with no problem. But on a beautiful day, it turned out to be "unidentified network" and "limited access". I tried everything I search on Google but nothing seem can fix my problem. Here what I tried:
1. Go to services, try to find ##Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9.762 but couldn't find it.
2. Configure the "wireless network connection" --> tab advanced --> set the value of Network Address with 12 any numberic digit but nothing happened.
Is there anything else I can do?
here's the "ipconfig/all" of my laptop:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DUC-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Con
troller (NDIS 6.20)
Physical Address. . . . . . . . . : E0-CB-4E-57-6B-BC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter
Physical Address. . . . . . . . . : 00-25-D3-CE-C2-79
Link-local IPv6 Address . . . . . : fe80::48ef:c10:5a2e:c86f%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, 02 April, 2011 10:25:19 AM
Lease Expires . . . . . . . . . . : Sunday, 03 April, 2011 10:25:19 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234890707
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-C9-9C-CB-00-25-D3-CE-C2-79
DNS Servers . . . . . . . . . . . : 203.162.4.190
203.162.4.191
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{19674EB5-1840-4D36-9D68-9A8CE7798115}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{27EAC015-0E02-4357-B48A-FA9DDF180C18}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
thanks so much if someone can help me fix it! :frown:
It seems like you're experiencing connectivity issues with your Wi-Fi network, resulting in an "unidentified network" and "limited access" error. Let's address the steps you've already taken:
  1. Searching for the ##Id_String2.6844F930_1628_4223_B5CC_5BB94B879.762 Service: This service you mentioned seems to be related to a specific network configuration but may not be directly related to your current Wi-Fi issue.
  2. Configuring the "Wireless Network Connection" Settings: Changing the Network Address (MAC address) to 12 numerical digits is not a common solution for fixing Wi-Fi connectivity problems. It's not recommended to modify this setting without a specific reason. Given the information you provided, here are some...
  2. Configuring the "Wireless Network Connection" Settings: Changing the Network Address (MAC address) to 12 numerical digits is not a common solution for fixing Wi-Fi connectivity problems. It's not recommended to modify this setting without a specific reason. Given the information you provided, here are some troubleshooting steps you can try to resolve the "unidentified network" and "limited access" issue:
  3. Reboot Your Router: Sometimes, issues with the router can cause connectivity problems. Try restarting your router by unplugging it, waiting for a few minutes, and then plugging it back in.
  4. Forget and Reconnect to the Wi-Fi Network:
    • Go to your Wi-Fi settings on your laptop.
    • Forget the Wi-Fi network you're having trouble with.
    • Reconnect to the network by entering the password again.
  5. Update Wi-Fi Adapter Drivers:
    • Visit the website of your laptop manufacturer or the Wi-Fi adapter manufacturer to download and install the latest drivers for your Wi-Fi adapter.
  6. Check for Windows Updates:
    • Ensure that your Windows OS is up to date by checking for and installing any pending updates.
  7. Disable IPv6:
    • Sometimes, issues with IPv6 can cause network problems. Try disabling IPv6 on your Wi-Fi adapter.
    • Go to your network adapter settings, locate the properties of your Wi-Fi adapter, and uncheck the box for IPv6.
  8. Run Network Troubleshooter:
    • Use the built-in network troubleshooter in Windows to diagnose and fix common network issues.
    • Go to Settings > Network & Internet > Status > Network troubleshooter.
  9. Check Firewall and Antivirus Settings:
    • Temporarily disable your firewall and antivirus software to see if they are blocking the network connection. Please try these steps and see if they help in resolving the Wi-Fi connectivity issue. If the problem persists, let me know so we can explore further solutions.
