CVE-2025-40220 Linux FUSE livelock fix for fuseblk I/O resilience
A livelock in the Linux FUSE stack that can freeze I/O workers has been fixed upstream: CVE‑2025‑40220 patches a pathological interaction between AIO-driven client behavior and fuseblk server threads by turning synchronous file‑put operations into asynchronous ones to break a self‑referential wait loop that could exhaust all server threads and make the filesystem unresponsive.
Background​
FUSE (Filesystem in Userspace) lets unprivileged users implement filesystems in userland processes; fuseblk is the b-device style FUSE transport commonly used by userspace implementations that expose raw block devices or b-backed images. In a typical FUSE setup a kernel thread submits requests to the userspace server and waits for the reply; the server handles the request and replies back via the kernel. That normal request/response flow assumes there will always be server threads available to consume and reply to requests, but certain client behaviors — notably aggressive asynchronous I/O where a descriptor is closed while many AIO operations remain outstanding — can create surprising timing windows that expose latent ordering bugs. The recently assigned CVE‑2025‑40220 documents a specific livelock scenario observed during kernel fuzzing and testing: a client queues a large number of AIO writes against a file on a fuseblk mount, then closes the file descriptor before the writes complete. Completions for those writes cause the fuse server to run the AIO completion handler which performs a file put (fput). In the vulnerable code path the server thread performs a synchronous file put that ends up issuing a FUSE_RELEASE back to the server — creating a cycle where fuse server threads block waiting for replies from themselves. If enough concurrent AIOs can be staged, every server thread may end up blocked in that delayed_fput path and no thread remains to handle the queued replies, producing a livelock or complete service hang. The core upstream mitigation is to make those fput operations asynchronous so that server threads do not synchronously send FUSE_RELEASE commands to themselves and thereby free the request handling capacity.
Overview of the bug and why it mattered​
  • What happened in practice: a test harness (generic/323 in the upstream test suite) opened a file, issued many asynchronous writes, and closed the descriptor while I/O was still pending. The AIO completion logic caused the fuse server to schedule a delayed fput that was executed synchronously in a server thread. That synchronous execution caused the server to block waiting for a reply for a FUSE_RELEASE sent to itself, and with enough concurrency all server threads could become blocked, leaving no workers to process outstanding replies.
  • Primary impact: Availability. The observable outcome is a hang or livelock of the filesystem — in the kernel sphere this manifests as I/O threads stuck in request_wait_answer/__fuse_simple_request and server threads blocked in fuse_file_put/fuse_release, producing a frozen or unresponsive mount. There is no indication in public disclosure that this results in confidentiality or integrity loss, or that it provides a remote code‑execution primitive; the exploitability model is local and timing‑driven.
  • Attack vector and required privileges: Local — the attacker needs the ability to issue AIOs and close descriptors against a FUSE filesystem on the host. In many multi‑tenant or CI environments that allow unprivileged users to create mounts or manipulate block images, the attacker surface is non‑trivial; in single‑user desktops the practical risk is lower but not zero.
Technical anatomy — how the deadlock/livelock forms​
The sequence of events​
  • A client opens a file on a fuseblk mount and submits many asynchronous writes (AIO).
  • The client closes the file descriptor before outstanding writes complete. That unlinks the user handle from the kernel file struct while completions still reference that struct.
  • When the userspace FUSE implementation (the "fuse server") processes a write completion it executes an AIO completion handler that performs a put on the struct file (fput).
  • The implementation queued the fput as a delayed fput to be processed by server threads. In the vulnerable behavior those delayed fputs are executed synchronously by server threads that are also responsible for handling incoming FUSE replies and commands.
  • If the fput path issues a FUSE_RELEASE synchronously and the server thread blocks waiting for the reply, those server threads can be waiting on responses that only server threads themselves can produce — creating a circular dependency and, under enough concurrency, starving the processing pool and creating a livelock.
Why synchronous fputs are the problem​
Synchronous file put (synchronous fput) causes the server thread to issue a FUSE_RELEASE request and wait for the client-side reply before returning. With many concurrent AIO completions this means server threads become consumers of both the requests and their own responses; the server cannot make forward progress because the reply-processing threads are blocked waiting for replies that cannot be processed because the reply‑processing threads are blocked — classic resource exhaustion via self‑blocking. Turning the fput into an asynchronous operation decouples release processing from immediate synchronous exchange and prevents all threads from entering the wait state at once.
The upstream fix and patch strategy​
  • Scope of the fix: The patch is intentionally surgical. Upstream maintainers changed the fput path used by fuseblk workers so that when files are being closed in the face of outstanding AIO completions the actual file put becomes asynchronous (delayed or queued to a context that will not synchronously block the server worker). The change preserves correctness for ordinary behavior while closing the timing window that allowed all server threads to block. Multiple stable‑tree commits implementing the change were propagated to stable kernels.
  • Why this design: Kernel maintainers favor minimal, low‑risk patches for concurrency ordering bugs where the fix is to change the ordering or the context of a specific operation rather than to redesign whole subsystems. Converting a synchronous release to an asynchronous one leaves standard path semantics unchanged for normal workloads while eliminating the pathological blocking case. This approach helps distributions to backport the fix into stable kernel packages quickly. Similar conservative strategies appear in other recent kernel fixes addressing races and ordering issues.
  • Where the patch landed: public vulnerability trackers and stable‑tree references list the upstream commits and stable backports; those references are used by distributions to map CVE → kernel package → fixed version. Aggregators list the kernel.org stable commit URLs associated with the fix. Note: in an automated fetch attempt the raw kernel.org stable commit pages were sometimes inaccessible, so relying on vendor advisories and well‑known aggregators is still necessary for operators to confirm the exact package-level fixes for their distributions.
Detection and forensic signals​
  • Kernel stacks and dmesg: The canonical I/O stacks reported in testers show threads stuck in request_wait_answer and __fuse_simple_request on the client side and fuse_file_put/fuse_release on the server side. Searching kernel logs for recurring traces that contain those symbol names is the fastest way to detect symptomatic hang conditions. Example stack samples used in the disclosure show request_wait_answer and __fuse_simple_request on client AIO threads and fuse_file_put and fuse_release on server threads.
  • Practical signs:
  • Repeated kernel threads blocked at identical stacks referencing fuse request_wait_answer or fuse_release.
  • High counts of pending FUSE requests in the server's internal queues.
  • Elevated AIO latencies and hung AIO completions that never resolve.
  • If your environment produces kernel oops or watchdog panics because userspace servers stop responding, correlate those events with FUSE activity.
  • Forensic collection: preserve full dmesg/journalctl output and collect per‑task stacks from /proc when the hang is observed. Those artifacts are useful to match attacker/test reproducer patterns and to verify whether the observed hang aligns with the CVE symptoms described in upstream reports.
Who should prioritize patching?​
  • Multi‑tenant hosts and cloud images where untrusted tenants or CI jobs can create mounts or provide loopback images — highest priority.
  • Build farms, CI runners, or container hosts that accept untrusted images or run untrusted tests that might exercise FUSE or AIO paths.
  • Storage servers and appliance images that expose FUSE-backed block devices (for example, virtual disk services that use fuse2fs or similar).
  • Desktop or single‑user systems where FUSE is used solely by trusted processes — lower practical priority but still recommended to patch in normal maintenance windows.
Distributions will map the upstream commit to kernel package versions. Administrators should consult their vendor security trackers and kernel package changelogs and verify the presence of the upstream commit or the CVE identifier before rolling out updates.
Mitigation and short‑term controls (if you cannot patch immediately)​
  • Reduce allowed AIO concurrency or restrict untrusted users from submitting high‑volume AIO workloads against fuseblk mounts. This limits the attack surface for the specific timing window exploited by the bug.
  • Restrict who can mount or attach loopback block images backed by FUSE. Prevent untrusted processes from creating fuseblk mounts.
  • Isolate image‑processing pipelines onto hosts that do not export FUSE services to untrusted workloads or that run with strict cgroups/namespace limits.
  • Increase monitoring for FUSE-related wait stacks and set SIEM alerts for repeated kernel messages related to fuse_file_put, fuse_release, __fuse_simple_request, and request_wait_answer.
These are compensating controls and not replacements for the definitive fix: applying the patched kernel is the only reliable remediation.
Why this fix is credible — cross‑checks and independent verification​
The CVE description and the fix principle (make fputs asynchronous to avoid server self‑blocking) were published and reproduced across multiple independent vulnerability trackers and aggregators. Public listings cite the same technical reproducer stacks and the same remedy: switching to asynchronous fputs for closing files to prevent synchronous FUSE_RELEASE calls from server threads. At least two independent vulnerability aggregators and CVE feeds carry matching descriptions, and those pages list the upstream stable commits used by distributions to implement the fix. That provides corroboration that the issue was triaged and remedied consistently across the Linux‑kernel supply chain. Caveat: the canonical upstream commit pages on kernel.org are the authoritative reference for the exact code diffs and commit hashes. In this reporting cycle some automated fetches of kernel.org stable commit URLs returned access errors in our environment; the kernel.org commit references are nonetheless listed explicitly in the trusted vulnerability aggregates and vendor advisories, which is the typical workflow operators use to match a CVE to a packaged kernel update in a distribution repository. Administrators should verify the commit IDs in their distribution’s kernel changelog or package metadata to confirm remediation.
Risk assessment — real world vs. theoretical​
  • Realistic likelihood: Moderate for shared‑host environments where untrusted code runs; low for single‑user, well‑controlled desktops. The bug requires local interaction with a FUSE filesystem using AIO patterns that deliberately create the timing window; while fuzzers easily reproduce it in testbeds, exploitation in the wild requires specific concurrency patterns or misconfigurations that expose fuseblk to untrusted actors.
  • Potential impact: High for availability in multi‑tenant and critical infrastructure contexts. A hung filesystem or server thread pool on a host VM or build agent can cascade into broader service interruptions. Historically, availability bugs in filesystem code are given high operational priority in cloud and multi‑tenant settings despite a local attack vector.
  • Exploitation complexity: Medium. The bug is not a silent remote RCE or data leak; it is a concurrency-induced livelock. Turning such local DoS primitives into escalations often requires additional primitives. Still, the operational cost of a denial-of-service on a shared host is material and justifies rapid patching.
Operational playbook — step‑by‑step​
  • Inventory:
  • Identify systems that mount FUSE filesystems and specifically fuseblk mounts: check /proc/mounts, systemd mount units, and /etc/fstab for fuse entries.
  • Identify hosts running fuse2fs, sshfs, or other FUSE userspace servers that might use fuseblk transport.
  • Verify vendor status:
  • Consult your distribution’s security advisory pages for CVE‑2025‑40220 mapping to kernel package versions.
  • If using vendor kernels (embedded devices, OEM Android images, appliance firmware), check vendor advisories and release notes.
  • Patch:
  • Install the vendor-supplied kernel package that includes the upstream fix and reboot hosts into the updated kernel.
  • For machines that cannot be rebooted immediately, schedule a maintenance window; apply the compensating controls listed above in the interim.
  • Validate:
  • After patching, reproduce a controlled AIO workload in a test environment and verify that the server does not enter the previously observed blocking state.
  • Confirm that kernel logs no longer show the same request_wait_answer / fuse_file_put stacks under equivalent workloads.
  • Monitor:
  • Add detection rules to capture the key stack signatures and alert on repeat occurrences.
  • Keep an eye on vendor trackers for any subsequent backports or follow‑up fixes in related code paths.
Wider lessons for administrators and developers​
  • Concurrency surprises in kernel–and userspace–interactions are a persistent class of issues. The fix for CVE‑2025‑40220 is emblematic: small, surgical changes to execution context (synchronous → asynchronous) often resolve severe deadlocks without broad rewrites.
  • Multi‑tenant and CI environments amplify local risks: privileges that seem innocuous on a single machine become a large attack surface when many untrusted actors share a host. Hardened isolation, tight mount privileges, and careful image onboarding reduce exposure.
  • Observability matters: kernel stack traces and structured logging made reproduction and triage possible. Improvements to tooling that make these patterns easier to detect remain high value.
CVE‑2025‑40220 fixed a real and practical availability bug in the Linux FUSE stack where synchronous file‑put paths in fuseblk workers could cause the server to deadlock on its own replies under heavy AIO workloads. The upstream remedy — converting those fputs to asynchronous operations in the close path — is conservative, low risk, and consistent with kernel maintainers’ preference for surgical fixes that eliminate pathological timing windows without wholesale changes to subsystem semantics. Operators with multi‑tenant hosts, CI servers, or any environment that mounts untrusted block images via FUSE should prioritize kernel updates and use the short‑term mitigations described until patched; corroborating information and the listed stable commits are available from multiple public vulnerability trackers and vendor advisories.
Note: the above technical details were corroborated against multiple independent vulnerability trackers and aggregators that list the same reproducer stacks and the same fix approach; kernel stable commit references used by distributions are enumerated in those listings. In one retrieval attempt the kernel.org stable commit pages themselves required different access (JS or direct access restrictions), so operators should confirm fixes by checking their distribution package changelogs or vendor advisories for the explicit CVE or upstream commit identifiers before declaring remediation complete.
