Dell Inspirion 530 Hang and BSOD at shutdown
Evening,
My grandfather has a Dell inspirion 530 that is hanging and then BSOD'ing when shutting down with windows 7. Here is the memory.dmp:
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 00000003, A device object has been blocking an Irp for too long a time
Arg2: 86c71348, Physical Device Object of the stack
Arg3: 8313bae0, Functional Device Object of the stack
Arg4: 85760ba8, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IRP_ADDRESS: 85760ba8
DEVICE_OBJECT: 86a3edd0
DRIVER_OBJECT: 870b73d8
IMAGE_NAME: HidBatt.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc0f9
MODULE_NAME: HidBatt
FAULTING_MODULE: 8e7e9000 HidBatt
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 83051054 to 830f1d10
STACK_TEXT:
8313ba94 83051054 0000009f 00000003 86c71348 nt!KeBugCheckEx+0x1e
8313bb00 830508e8 8313bba0 00000000 83148280 nt!PopCheckIrpWatchdog+0x1f5
8313bb38 8307f04d 83156a20 00000000 b4ae102a nt!PopCheckForIdleness+0x73
8313bb7c 8307eff1 8313ed20 8313bca8 00000002 nt!KiProcessTimerDpcTable+0x50
8313bc68 8307eeae 8313ed20 8313bca8 00000000 nt!KiProcessExpiredTimerList+0x101
8313bcdc 8307d20e 00013fa6 868ca7e0 83148280 nt!KiTimerExpiration+0x25c
8313bd20 8307d038 00000000 0000000e 00000000 nt!KiRetireDpcList+0xcb
8313bd24 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x38
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: 0x9F_IMAGE_HidBatt.sys
Followup: MachineOwner
It appears that the microsoft Hidbatt.sys is causing a BSOD on shut down due to some type of inconsistency. Anyone have any idea if there is a solution for this? it is one of the last two issues that I cannot resolve for him. I am in washington state and he is in california so we have been working through this via skype.
Sonny
I don't know if this will help you or not. I had a similar problem with Vista. It turned out after I disconnected my printer. It was ok. What I found out was my bios needed updating. Once that was done and I reconnected the printer, I had no more problems. That may not be your problem. Still it wouldn't hurt to see if the bios is the latest one. I also have a Dell Inspirion 530.
