When Windows 7 automatically creates directories on external USB hard drives, it typically adds the "System Volume Information" and "$RECYCLE.BIN" folders. These folders serve specific purposes:
System Volume Information: This folder contains system restore points and information related to the Volume Shadow Copy service used for system backups.
$RECYCLE.BIN: This folder holds files that are deleted from the external drive. It acts as the Recycle Bin for that specific drive. If you want to stop Windows 7 from creating these directories on your external USB hard drive, you can try the following methods:
Method 1: Disable System Restore on the External Drive
Disable System Restore:
Right-click on the external drive and select "Properties."
Go to the "System Protection" tab.
Select the external drive and click on "Configure."
Choose the option to disable System Protection and click "OK."
Method 2: Disable Recycle Bin for the External Drive
[]Adjust Recycle Bin Settings:
Right-click on the Recycle Bin on your desktop and select "Properties."
Select the external drive and choose "Don't move files to the Recycle Bin."
Method 3: Use Command Prompt to Prevent Folder Creation
[]Command Prompt Method:
Open Command Prompt as Administrator.
Use the following command to prevent the creation of these directories:
