Every possible bsod there is...
Hi!
Well Im not sure where to begin, I get all kinds off diffrent bluescreens and I don't mange to get rid of them. I have Reinstalled windows 7 two times and begin to think i might do it again, but it will probably not do anything good. I hope anyone here knows what to do!
System info:
ASUS SI-Socket 775 P5QL-I/SI
ATI Radeon HD 5700 Series
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
SAMSUNG HD103UJ ATA Device
Thanks!
push bump?
kaos
MINIDUMP
BugCheck D1, {180000002, 2, 1, fffff88002c6dc40}
Unable to load image \SystemRoot\system32\DRIVERS\avgtdia.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for avgtdia.sys
*** ERROR: Module load completed but symbols could not be loaded for avgtdia.sys
Probably caused by : avgtdia.sys ( avgtdia+dc40 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000180000002, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88002c6dc40, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800032bf0e0
 0000000180000002
CURRENT_IRQL:  2
FAULTING_IP:
avgtdia+dc40
fffff880`02c6dc40 e8d7a10000      call    avgtdia+0x17e1c (fffff880`02c77e1c)
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff88009ca5500 -- (.trap 0xfffff88009ca5500)
rax=00000000c0000001 rbx=0000000000000000 rcx=fffffa80071d62a8
rdx=fffff88009ca5930 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88002c6dc40 rsp=fffff88009ca5690 rbp=fffff88009ca5a40
 r8=00000000f000000f  r9=0000000000000000 r10=0000000000000000
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz ac po nc
avgtdia+0xdc40:
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80003086ca9 to fffff80003087740
STACK_TEXT:
fffff880`09ca53b8 fffff800`03086ca9 : 00000000`0000000a 00000001`80000002 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`09ca53c0 fffff800`03085920 : f00000b0`09ca5840 fffffa80`071d62a8 fffff880`02caefc0 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`09ca5500 fffff880`02c6dc40 : fffffa80`071d62a8 00000000`00000001 fffff880`09ca5a40 00000000`00000001 : nt!KiPageFault+0x260
fffff880`09ca5690 fffffa80`071d62a8 : 00000000`00000001 fffff880`09ca5a40 00000000`00000001 fffff880`09ca0001 : avgtdia+0xdc40
fffff880`09ca5698 00000000`00000001 : fffff880`09ca5a40 00000000`00000001 fffff880`09ca0001 fffff880`34677641 : 0xfffffa80`071d62a8
fffff880`09ca56a0 fffff880`09ca5a40 : 00000000`00000001 fffff880`09ca0001 fffff880`34677641 fffffa80`0528d770 : 0x1
fffff880`09ca56a8 00000000`00000001 : fffff880`09ca0001 fffff880`34677641 fffffa80`0528d770 fffff880`02d4608d : 0xfffff880`09ca5a40
fffff880`09ca56b0 fffff880`09ca0001 : fffff880`34677641 fffffa80`0528d770 fffff880`02d4608d 00000000`00000002 : 0x1
fffff880`09ca56b8 fffff880`34677641 : fffffa80`0528d770 fffff880`02d4608d 00000000`00000002 00000000`00000000 : 0xfffff880`09ca0001
fffff880`09ca56c0 fffffa80`0528d770 : fffff880`02d4608d 00000000`00000002 00000000`00000000 00000080`c0000000 : 0xfffff880`34677641
fffff880`09ca56c8 fffff880`02d4608d : 00000000`00000002 00000000`00000000 00000080`c0000000 fffffa80`072ff938 : 0xfffffa80`0528d770
fffff880`09ca56d0 fffff880`00000000 : 00000000`00000000 00000000`00000006 00000f38`418c2400 fffff880`09ca5918 : afd!AfdReturnBuffer+0x7d
fffff880`09ca5710 00000000`00000000 : 00000000`00000006 00000f38`418c2400 fffff880`09ca5918 00000000`00000006 : 0xfffff880`00000000
STACK_COMMAND:  kb
FOLLOWUP_IP:
avgtdia+dc40
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  avgtdia+dc40
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: avgtdia
IMAGE_NAME:  avgtdia.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d9a3e1b
FAILURE_BUCKET_ID:  X64_0xD1_avgtdia+dc40
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff880041152d0, Virtual address for the attempted write.
Arg2: 8000000127622121, PTE contents.
Arg3: fffff88002f1b550, (reserved)
Arg4: 000000000000000a, (reserved)
Debugging Details:
BUGCHECK_STR: 0xBE
CURRENT_IRQL: 2
TRAP_FRAME: fffff88002f1b550 -- (.trap 0xfffff88002f1b550)
rax=fffff880041152d0 rbx=0000000000000000 rcx=fffff88004116580
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88004111652 rsp=fffff88002f1b6e0 rbp=0000000000000018
r8=0000000000000004 r9=0000000000000030 r10=0000000000000020
r11=fffff88002f1b738 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl zr na po nc
mouclass!WPP_RECORDER_SF_qq+0x5e:
fffff880`04111652 488364244800 and qword ptr [rsp+48h],0 ss:0018:fffff880`02f1b728=0000000000000000
LAST_CONTROL_TRANSFER: from fffff80003154448 to fffff800030d5740
STACK_TEXT:
fffff880`02f1b3e8 fffff800`03154448 : 00000000`000000be fffff880`041152d0 80000001`27622121 fffff880`02f1b550 : nt!KeBugCheckEx
fffff880`02f1b3f0 fffff800`030d382e : 00000000`00000000 00000000`00000030 fffffa80`071d4010 fffffa80`071d4208 : nt! ?? ::FNODOBFM::`string'+0x409b4
fffff880`02f1b550 fffff880`04111652 : 00000000`0000002f fffff880`0411154e 00000000`0000002d fffff880`041110a0 : nt!KiPageFault+0x16e
fffff880`02f1b6e0 fffff880`041129ad : 00000000`00000018 fffffa80`05db71b0 fffffa80`05db71b0 00000000`00000007 : mouclass!WPP_RECORDER_SF_qq+0x5e
fffff880`02f1b740 fffff880`041ecc79 : 00000000`00000002 00000000`ffffffff fffffa80`06015960 fffffa80`05ffba00 : mouclass!MouseClassServiceCallback+0x155
fffff880`02f1b7c0 fffff800`030d7d26 : fffffa80`05622a63 fffff880`00000000 fffffa80`00000001 00000000`00000000 : mouhid!MouHid_ReadComplete+0x69d
fffff880`02f1b840 fffff880`03beaacc : fffffa80`056a5c68 fffffa80`056a5c06 fffffa80`0600dc00 00000000`00000000 : nt!IopfCompleteRequest+0x3a6
fffff880`02f1b920 fffff880`03bead35 : fffffa80`05676302 fffffa80`05676300 fffffa80`0600dcb0 00000000`00000006 : HIDCLASS!HidpDistributeInterruptReport+0x130
fffff880`02f1b9b0 fffff800`030d7d26 : fffffa80`054bf343 00000000`00000000 fffffa80`0600db01 fffffa80`054bf150 : HIDCLASS!HidpInterruptReadComplete+0x235
fffff880`02f1ba40 fffff880`03d7b5d9 : fffffa80`05510050 fffffa80`03bc1a00 00000000`00000000 00000000`00000000 : nt!IopfCompleteRequest+0x3a6
fffff880`02f1bb20 fffff880`03d7bab7 : fffffa80`03d09002 fffffa80`054bf150 00000000`ffffffff fffffa80`05510ea8 : USBPORT!USBPORT_Core_iCompleteDoneTransfer+0xa15
fffff880`02f1bc00 fffff880`03d7964f : fffffa80`05510ea8 fffffa80`055101a0 fffffa80`05511040 00000000`00000000 : USBPORT!USBPORT_Core_iIrpCsqCompleteDoneTransfer+0x3a7
fffff880`02f1bc60 fffff880`03d6af89 : fffffa80`05510050 00000000`00000000 fffffa80`05510e02 fffffa80`05510ea8 : USBPORT!USBPORT_Core_UsbIocDpc_Worker+0xf3
fffff880`02f1bca0 fffff800`030e0bfc : fffff880`009e9180 fffffa80`05510ea8 fffffa80`05510ec0 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`02f1bcd0 fffff800`030ddeea : fffff880`009e9180 fffff880`009f3f40 00000000`00000000 fffff880`03d6adb0 : nt!KiRetireDpcList+0x1bc
fffff880`02f1bd80 00000000`00000000 : fffff880`02f1c000 fffff880`02f16000 fffff880`02f1bd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_IP:
mouclass!WPP_RECORDER_SF_qq+5e
SYMBOL_NAME: mouclass!WPP_RECORDER_SF_qq+5e
MODULE_NAME: mouclass
IMAGE_NAME: mouclass.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc116
FAILURE_BUCKET_ID: X64_0xBE_mouclass!WPP_RECORDER_SF_qq+5e
[/code]
drivers
fffff800`00ba0000 fffff800`00baa000   kdcom    kdcom.dll    Sat Feb 05 12:21:45 2011 (4D4D40D9)
fffff800`03001000 fffff800`035de000   nt       ntkrnlmp.exe Wed Oct 27 03:43:09 2010 (4CC791BD)
fffff800`035de000 fffff800`03627000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`00c5c000 fffff880`00c6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00c6c000 fffff880`00c86000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c86000 fffff880`00ca4000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`00ca6000 fffff880`00cea000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`00cea000 fffff880`00cfe000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00cfe000 fffff880`00d5c000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d5c000 fffff880`00d8f000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00d8f000 fffff880`00da4000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00da4000 fffff880`00db9000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00db9000 fffff880`00de3000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`00e00000 fffff880`00e57000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`00e57000 fffff880`00e60000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00e60000 fffff880`00e6a000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00e6a000 fffff880`00e73000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e76000 fffff880`00f36000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`00f36000 fffff880`00fda000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00fda000 fffff880`00fe9000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00fe9000 fffff880`00ff6000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00ff6000 fffff880`00ffd000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`01000000 fffff880`01011000   avgfwd6a avgfwd6a.sys Mon Jul 12 02:38:24 2010 (4C3A7210)
fffff880`01011000 fffff880`0101e000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`0101e000 fffff880`0102a000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0102b000 fffff880`01072000   mv61xx   mv61xx.sys   Wed Jan 27 06:50:32 2010 (4B5FE238)
fffff880`01072000 fffff880`010a1000   SCSIPORT SCSIPORT.SYS Tue Jul 14 01:01:04 2009 (4A5BCAC0)
fffff880`010a1000 fffff880`010a9000   mv61xxmm mv61xxmm.sys Wed Jan 27 06:50:14 2010 (4B5FE226)
fffff880`010a9000 fffff880`010b4000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`010b4000 fffff880`01100000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`01100000 fffff880`01114000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01114000 fffff880`0111fe00   PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`01120000 fffff880`0117e000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`0117e000 fffff880`011f1000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`01204000 fffff880`013a7000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`013a7000 fffff880`013c1000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`013c1000 fffff880`013d2000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`013d2000 fffff880`013dc000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`013dc000 fffff880`013e7000   Msfs     Msfs.SYS     unavailable (00000000)
fffff880`013e7000 fffff880`013f8000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01409000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01409000 fffff880`01412000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01416000 fffff880`01508000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`01508000 fffff880`01568000   NETIO    NETIO.SYS    Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01568000 fffff880`01593000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`01593000 fffff880`015dd000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`015dd000 fffff880`015ed000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`015ed000 fffff880`015fd000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Mon Jun 14 04:39:04 2010 (4C15A458)
fffff880`01800000 fffff880`0180f000   avgmfx64 avgmfx64.sys Tue Mar 01 12:25:15 2011 (4D6CE5AB)
fffff880`0180f000 fffff880`01818000   Null     Null.SYS     unavailable (00000000)
fffff880`01818000 fffff880`0181f000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0181f000 fffff880`0182d000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0182d000 fffff880`01852000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01852000 fffff880`0185b000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0185e000 fffff880`018aa000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`018aa000 fffff880`018b2000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`018b2000 fffff880`018ec000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`018ec000 fffff880`018fe000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`018fe000 fffff880`01907000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`01907000 fffff880`01941000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`01941000 fffff880`01957000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01957000 fffff880`01987000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`01987000 fffff880`01993000   avgrkx64 avgrkx64.sys Wed Mar 16 14:06:34 2011 (4D80C3EA)
fffff880`01993000 fffff880`0199d000   AVGIDSEH AVGIDSEH.Sys Tue Feb 22 05:23:04 2011 (4D634838)
fffff880`019d3000 fffff880`019fd000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02c00000 fffff880`02c14000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff880`02c14000 fffff880`02c2a000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`02c2a000 fffff880`02c4e000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`02c54000 fffff880`02cb4000   avgtdia  avgtdia.sys  Mon Apr 04 22:54:35 2011 (4D9A3E1B)
fffff880`02cb4000 fffff880`02cf9000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`02cf9000 fffff880`02d83000   afd      afd.sys      Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`02d83000 fffff880`02d8c000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02d8c000 fffff880`02db2000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`02db2000 fffff880`02dc1000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02dc1000 fffff880`02dde000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`02dde000 fffff880`02df9000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`03a00000 fffff880`03a16000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`03a16000 fffff880`03a25000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`03a25000 fffff880`03a35000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`03a35000 fffff880`03a4e000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`03a50000 fffff880`03aa1000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`03aa1000 fffff880`03aad000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`03aad000 fffff880`03ab8000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`03ab8000 fffff880`03ac4000   ElbyCDIO ElbyCDIO.sys Thu Dec 16 22:58:13 2010 (4D0A9985)
fffff880`03ac4000 fffff880`03ad3000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`03ad3000 fffff880`03b56000   csc      csc.sys      Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`03b56000 fffff880`03b74000   dfsc     dfsc.sys     Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`03b74000 fffff880`03b85000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`03b85000 fffff880`03bd4000   avgldx64 avgldx64.sys Fri Jan 07 04:36:39 2011 (4D269857)
fffff880`03bd4000 fffff880`03bfa000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`03c00000 fffff880`03c56000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`03c56000 fffff880`03c74000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03c77000 fffff880`03cc7000   atikmpag atikmpag.sys Wed Apr 20 02:22:32 2011 (4DAE3558)
fffff880`03cc7000 fffff880`03dbb000   dxgkrnl  dxgkrnl.sys  Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`03dbb000 fffff880`03df9000   1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`04000000 fffff880`0405a000   usbhub   usbhub.sys   Sat Oct 24 05:28:24 2009 (4AE28268)
fffff880`0405a000 fffff880`04065000   flpydisk flpydisk.sys unavailable (00000000)
fffff880`04065000 fffff880`04072000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`04072000 fffff880`0407a000   wacommousefilter wacommousefilter.sys Fri Feb 16 18:12:17 2007 (45D5F401)
fffff880`0407a000 fffff880`0408f000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`040c4000 fffff880`040f3000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`040f3000 fffff880`0410e000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0410e000 fffff880`0412f000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`0412f000 fffff880`04149000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04149000 fffff880`04154000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`04154000 fffff880`04163000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04163000 fffff880`04172000   VClone   VClone.sys   Sat Jan 15 16:21:04 2011 (4D31C970)
fffff880`04172000 fffff880`04173480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`04174000 fffff880`041b7000   ks       ks.sys       Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`041b7000 fffff880`041c9000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`04800000 fffff880`04824000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04824000 fffff880`04831000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`04831000 fffff880`04842000   usbehci  usbehci.sys  Sat Oct 24 05:27:33 2009 (4AE28235)
fffff880`04842000 fffff880`04854000   L1E62x64 L1E62x64.sys Mon Mar 29 03:08:44 2010 (4BB00BAC)
fffff880`04854000 fffff880`04861000   fdc      fdc.sys      unavailable (00000000)
fffff880`04861000 fffff880`04869000   ASACPI   ASACPI.sys   Thu Jul 16 04:31:29 2009 (4A5E9F11)
fffff880`0486d000 fffff880`051a1000   atikmdag atikmdag.sys Wed Apr 20 02:53:29 2011 (4DAE3C99)
fffff880`051a1000 fffff880`051e7000   dxgmms1  dxgmms1.sys  Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`051e7000 fffff880`051f3000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`051f3000 fffff880`051f5a00   wacomvhid wacomvhid.sys Tue Sep 22 00:29:14 2009 (4AB80C4A)
fffff880`051f6000 fffff880`051fe080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05c00000 fffff880`05cc8000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`05cdf000 fffff880`05d26c00   RtHDMIVX RtHDMIVX.sys Tue Nov 23 10:27:12 2010 (4CEB9700)
fffff880`05d27000 fffff880`05d64000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`05d64000 fffff880`05d86000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05d86000 fffff880`05d8b200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05d8c000 fffff880`05dda000   mrxsmb10 mrxsmb10.sys Wed Feb 23 05:15:14 2011 (4D6497E2)
fffff880`05dda000 fffff880`05dfd000   mrxsmb20 mrxsmb20.sys Wed Feb 23 05:15:13 2011 (4D6497E1)
fffff880`05e00000 fffff880`05e23000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`05e23000 fffff880`05e44000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`05e44000 fffff880`05e59000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05e59000 fffff880`05e71000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05e71000 fffff880`05e8f000   bowser   bowser.sys   Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff880`05e8f000 fffff880`05ea7000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05ea7000 fffff880`05ed4000   mrxsmb   mrxsmb.sys   Wed Feb 23 05:15:23 2011 (4D6497EB)
fffff880`05ed4000 fffff880`05edf000   AVGIDSFilter AVGIDSFilter.Sys Thu Feb 10 04:59:37 2011 (4D5370B9)
fffff880`05ef6000 fffff880`06185280   RTKVHD64 RTKVHD64.sys Thu Dec 30 03:52:42 2010 (4D1C020A)
fffff880`06186000 fffff880`06194000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`06194000 fffff880`06195f00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`06196000 fffff880`061a4000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`061a4000 fffff880`061b2000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`061b2000 fffff880`061be000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`061be000 fffff880`061c7000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`061c7000 fffff880`061da000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`061da000 fffff880`061e6000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`061e6000 fffff880`061f4000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`06200000 fffff880`06267000   srv2     srv2.sys     Wed Feb 23 05:15:59 2011 (4D64980F)
fffff880`062a8000 fffff880`0634e000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0634e000 fffff880`06359000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`06359000 fffff880`06386000   srvnet   srvnet.sys   Wed Feb 23 05:15:49 2011 (4D649805)
fffff880`06386000 fffff880`06398000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`06398000 fffff880`063c3000   AVGIDSDriver AVGIDSDriver.Sys Thu Apr 14 18:11:05 2011 (4DA72AA9)
fffff880`06e52000 fffff880`06ee7000   srv      srv.sys      Wed Feb 23 05:16:24 2011 (4D649828)
fffff880`06ee7000 fffff880`06f1d000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`06f1d000 fffff880`06f8e000   spsys    spsys.sys    Mon May 11 18:20:58 2009 (4A085E7A)
fffff960`000e0000 fffff960`003f2000   win32k   win32k.sys   Thu Mar 03 03:58:01 2011 (4D6F11C9)
fffff960`005f0000 fffff960`005fa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00630000 fffff960`00657000   cdd      cdd.dll      unavailable (00000000)
fffff960`00940000 fffff960`009a1000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`0199d000 fffff880`019ab000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019ab000 fffff880`019b7000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019b7000 fffff880`019c0000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019c0000 fffff880`019d3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
ok,
remove AVG and replace with Microsoft essentials
run as administrator in command promt
sfc /scannow
chkdsk /f /r
also download MALWAREBYTES - ANTI MALWARE , install this, run in safemode
also try running TDSKILLER
Try this and let me no how it goes
good luck
Thank you for the replie! I will try! Though why do i need to get rid of avg, just asking?
Removed AVG and i got Microsoft essentials now.
The sfc scan:
C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
disk check went fine, but /f is just a virutal driver?
malwarebytes scan also went good!
Malwarebytes' Anti-Malware 1.51.0.1200
www.malwarebytes.org
Database version: 6779
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
6/6/2011 01:35:11
mbam-log-2011-06-06 (01-35-11).txt
Scan type: Full scan (C:\|)
Objects scanned: 343421
Time elapsed: 22 minute(s), 20 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 1
(No malicious items detected)
Folders Infected:
Files Infected:
c:\Users\hump\AppData\Local\Temp\7B85.tmp\adobe_cs5_activator.exe (RiskWare.Tool.CK) -> Quarantined and deleted successfully.
tdskiller? didn't find D:
I managed to get a NEW bsod atikmdag.sys .....
kaos
#7
Graphichs card driver you need to update :)
#8
I just did that yesterday! I read in another thread that someone had problem the catalyst control center, shall i remove it and use windows suggested drivers instead?
#9
Got one i don't think i had before, not for along time anyway page_fault_in_nonpaged_area....
