Windows 10 Getting odd error, please help
Jason E
I've searched for someone with a similar error as me and haven't found anyone. Hopefully someone could help me here?
This is the error I'm getting:
If you can reboot and get back into windows, you may want to look at the Windows Update log (assuming you are doing the upgrade) and not a clean install for some clue as to the issue. C:\Windows\WindowsUpdate.log or it may log update details in C:\$Windows.~BT which is a hidden folder.
ussnorway
Windows Forum Team
Can you boot to desktop
Did you turn the anti virus off before trying to update
Is the system on the internet and not using a WiFi...
Whatever system that happens to be?
Jason E
Yes I can boot to desktop, No I'm not using WiFi, and yes I turned off Anti Virus but it still doesn't work :C
Neemobeer
Windows Forum Team
ussnorway
Windows Forum Team
That looks like a two part error code... the first is (0x8009000f) Object already exists, the second is a line code for a part and could be anything plugged into a pci slot… I assume something network related first because of the timing so what network card have you got… a PCI-E Gigabit Ethernet Controller (known to have windows driver issues) perhaps try putting a cheap intel card instead?
