ok when I open the file its huge,,,11k files,,,i delete them all and in 5 minutes there are thousands back...doesn't this slow my system down ?? How do I disable caching ?? I see it in "internet options" file...
Have you tried using something like ccleaner or the disk clean app? Link Removed
That should clear the cache.
Windows 7 isn't free and you cannot change operating systems unless there was already a deal in place with the store you bought from (sometimes called a downgrade)
