Herk Orion Mini PC Review: Performance Meets Compact Design
In a world where small form-factor PCs are becoming increasingly popular, the Herk Orion is turning heads with its impressive performance and compact design. A recent article on ZDNET discusses a fascinating journey where the author transitioned a mini PC, initially running Windows 11, into a Linux powerhouse. What's compelling here isn't just about switching operating systems; it's about discovering how well small, surprisingly powerful machines like the Herk Orion can perform, especially when said shiny machine is powered by AMD's Ryzen 9 CPU.
The Herk Orion: A Mini Marvel​
The Herk Orion, as per the review, is driven by the AMD Ryzen 9 7940HS. With 8 cores and 16 threads running at speeds up to 5.2 GHz, combined with an AMD Radeon 780M GPU, this mini PC can tackle more than just the basics. This means it can effectively manage tasks that could range from casual browsing to intensive multimedia work. And while it initially comes pre-installed with Windows 11, the real fun starts when the author decides to throw Ubuntu 24.04 into the mix.
Specs That Surpass Expectations​
Here’s a quick look at the Herk Orion's specs, which showcase its prowess:
  • CPU: AMD Ryzen 9 7940HS
  • Clock Speed: 4.0 GHz (up to 5.2 GHz boost)
  • GPU: AMD Radeon 780M
  • RAM: 32 GB LPDDR5 dual channel
  • Storage: 1 TB SSD
  • Connectivity: 2.5 Gbps LAN, WiFi 6e, Bluetooth 5.2
  • Ports: Dual HDMI, USB 3.2, USB 4, USB 2.0
These specs not only confirm that the Orion can handle daily tasks effortlessly but also suggest it can provide a very satisfying experience for anyone skeptical about the capabilities of mini PCs.
My Experience with the Transition​
The transformative moment came when the author compared the performance of Windows 11 against Linux. Unsurprisingly, Linux delivered faster boot times, quicker application launches, and overall smooth operation. This is not a new revelation for Linux enthusiasts, but it serves as a significant endorsement for those sitting on the fence about making the switch.
Imagine this: you have a speedy little machine that is primed to run lightweight applications or just your daily work without constantly fighting slowdowns. For instance, the author managed to run a full upgrade with Ubuntu in no time, which might have led to a moment of pondering if this could indeed be the reality for those longing for efficiency. The machine displayed the agility and silence expected from high-quality hardware, making it a fantastic choice for home or office usage, especially if you want to keep noise levels down.
Ports and Connectivity​
Despite its size, the Herk Orion doesn't skimp on connectivity options. While the author was slightly disappointed by the absence of a DisplayPort (a common consideration for users needing multiple display configurations), its dual HDMI ports certainly mitigate this shortcoming. Equipped with adequate USB input options, setting up peripherals should be straightforward.
Performance Under Pressure​
It’s an interesting observations that, while the Orion won’t dethrone a high-end gaming rig when it comes to speed overall, it handles standard workloads such as web browsing, streaming, and productivity applications effortlessly. Even under relatively heavy tasks, like running local AI models, the Orion holds its ground, making it popular for developers and enthusiasts who do not wish to compromise on performance in a compact package.
Price Point and Considerations​
One might expect a system like this, especially packed with such strong specifications, to come with a hefty price tag. However, it competes in a much more reasonable range, retailing for approximately $649. This makes it an attractive consideration for users looking for a powerful machine without breaking the bank.
Conclusion: Is the Switch Worth It?​
As for the final verdict: if you're an everyday Windows user intrigued by Linux or someone who simply needs a reliable workstation, the Herk Orion presents a compelling case. For those already familiar with Linux's benefits, the Orion shines even brighter, demonstrating just how efficient and powerful a mini PC can be when properly utilized.
Powerful, compact, and more than capable of running your daily applications, the Herk Orion could indeed be one of the best mini PCs to consider for both Linux enthusiasts and general users alike. If you’re facing the dilemma of whether to cling to a bulkier machine or opt for a stylish, efficient mini PC like the Orion, it might just be time to embrace the change!
These insights highlight how suitable small form-factor PCs can be, particularly for users who appreciate the fusion of performance and space efficiency. With the transition from Windows 11 to Linux, the Herk Orion isn't just a machine; it's an experience waiting to be unleashed. Happy computing!
Source: ZDNET https://www.zdnet.com/article/i-converted-a-mini-pc-running-windows-11-into-a-linux-workstation-and-it-blew-me-away/
